[ROS Beginner Mistakes] – 1. Missing execute permission on the Python file
Written by Bayode Aderinola
07/10/2019
In this short post, we will show how to avoid a very common mistake most ROS beginners make: missing execute permission on the Python file.
Step 1: Create a Project (ROSject) on ROSDS
Head to http://rosds.online and create a project with a similar configuration as the one shown below. You can change the details as you like, but please make sure you select “Ubuntu 16.04 + ROS Kinetic + Gazebo 7” under “Configuration”.
Once done with that, open your ROSject. This might take a few moments, please be patient.
Step 2: Create a ROS package with a Python program
Pick a Shell from the Tools menu and create a Python package.
user:~$ cd catkin_ws/
user:~/catkin_ws$ cd src
user:~/catkin_ws/src$ catkin_create_pkg missing_permission
Created file missing_permission/package.xml
Created file missing_permission/CMakeLists.txt
Successfully created files in /home/user/catkin_ws/src/missing_permission. Please adjust the values in package.xml.
user:~/catkin_ws/src$ cd missing_permission/
user:~/catkin_ws/src/missing_permission$ mkdir -p src/
user:~/catkin_ws/src/missing_permission$ cd src
user:~/catkin_ws/src/missing_permission/src$ touch missing_perm.py
Fire up the IDE from the Tools menu, find the missing_perm.py file in the missing_permission package, open the file and paste the following code into it.
#! /usr/bin/env python
import rospy
rospy.init_node("Obiwan")
rate = rospy.Rate(2)
    print "Help me Obi-Wan Kenobi, you're my only hope"
    rate.sleep()
Save().
Step 3: Compile and source the workspace.
cd ~/catkin_ws
catkin_make
source devel/setup.bash
Step 4: Run the package with rosrun and roslaunch.
First, we check that the package has been recognized, with rospack list. Then we run it with rosrun.
user:~/catkin_ws$ rospack list | grep missing
missing_permission /home/user/catkin_ws/src/missing_permission
user:~/catkin_ws$ rosrun missing_permission missing_perm.py
[rosrun] Couldn't find executable named missing_perm.py below /home/user/catkin_ws/src/missing_permission
[rosrun] Found the following, but they're either not files,
[rosrun] or not executable:
[rosrun]   /home/user/catkin_ws/src/missing_permission/src/missing_perm.py
user:~/catkin_ws$
The program did not run! What’s that error? Surely that not what we expected. Maybe rosrun does not like us – let’s try roslaunch!
Create a launch file and use it to launch the python program:
user:~/catkin_ws$ cd src/missing_permission/
user:~/catkin_ws/src/missing_permission$ mkdir -p launch
user:~/catkin_ws/src/missing_permission$ cd launch
user:~/catkin_ws/src/missing_permission/launch$ touch missing_perm.launch
Open the launch file in the IDE and paste in the following code:
<launch>
    <node name="missing_permission_ex" pkg="missing_permission" type="missing_perm.py" output="screen" />
</launch>
Launch!
user:~/catkin_ws/src/missing_permission$ cd ~/catkin_ws
user:~/catkin_ws$ source devel/setup.bash
user:~/catkin_ws$ roslaunch missing_permission missing_perm.launch
... logging to /home/user/.ros/log/e3188a2e-e921-11e9-8ac1-025ee6e69cec/roslaunch-rosdscomputer-11105.log
NODES
    missing_permission_ex (missing_permission/missing_perm.py)
auto-starting new master
process[master]: started with pid [11147]
ROS_MASTER_URI=http://master:11311
setting /run_id to e3188a2e-e921-11e9-8ac1-025ee6e69cec
process[rosout-1]: started with pid [11170]
started core service [/rosout]
ERROR: cannot launch node of type [missing_permission/missing_perm.py]: can't locate node [missing_perm.py] in package [missing_permission]
Oops! It didn’t run again. Now we have another error screaming:
What do we do now?
Step 5: Fix the missing execute permission on the Python file and be happy!
user:~/catkin_ws$ cd src/missing_permission/src/
user:~/catkin_ws/src/missing_permission/src$ chmod +x missing_perm.py
Now let’s try again with both roslaunch and rosrun:
user:~/catkin_ws/src/missing_permission/src$ roslaunch missing_permission missing_perm.launch
NODES
process[master]: started with pid [13206]
setting /run_id to eec6e306-e922-11e9-b72a-025ee6e69cec
process[rosout-1]: started with pid [13229]
process[missing_permission_ex-2]: started with pid [13242]
Running fine with roslaunch. Press Ctrl + C on the roslaunch program and try rosrun:
user:~/catkin_ws/src/missing_permission/src$ rosrun missing_permission missing_perm.py
Unable to register with master node [http://master:11311]: master may not be running yet. Will keep trying.
If you get the error above, please spin another Shell from the Tools menu, and run the following to start the ROS master:
user:~$ roscore
After this, the roscore command should resume and you’ll get:
And that was it. As it turned out, roscore had no ill-feeling towards us!
Related Resources
Feedback
Did you like this post? Do you have questions about what was explained? Whatever the case, please leave a comment on the comments section below, so we can interact and learn from each other.
If you want to learn about other ROS or ROS2 topics, please let us know in the comments area and we will do a video or post about it 🙂
