[Gazebo in 5 minutes] 005 – How to use a mesh file to create a gazebo model
In this video we’ll learn How to use a mesh file to create a gazebo model. Different than URDF format, SDF is also used for entire robotic simulation environments.
[Gazebo in 5 minutes] 006 – How to use an image file as texture for gazebo model
In this video we’ll learn how to use an image file as texture for gazebo model.
[Gazebo Q&A] 004 – How to create a Planar Moving Element in Gazebo ROS
In this video, you will learn two methods to move an element on the plane, ground level. This first one is using two prismatic joints working together to achieve this planar movement. The second is creating a custom plugin that sets the speeds of the model to move around the plane.
Related resources:
Testing Different OpenAI RL Algorithms With ROS And Gazebo
This post was written by Miguel A. Rodriguez and Ricardo Tellez
In this post we are going to see how to test different reinforcement learning (RL) algorithms from the OpenAI framework in the same robot trying to solve the same task. We are going to use the openai_ros package, which allows to change algorithms very easily and hence compare performances.
For the whole process, we are going to use the ROS Development Studio (ROSDS), which you can use for free. Also you can reproduce the results in your own local computer following these instructions.
The task to solve
We are going to use for this post the typical example in reinforcement learning of the cartpole. On the cartpole task, a pole mounted on top of a cart has to be balanced by the cart by moving left or right.
This problem is defined in the OpenAI Gym in the following links:
However, the OpenAi Gym just solves the problem on a 2D flat simulated environment with no real controllers for the cart and very limited physics simulation. That environment and its training looks something like the following video.
In this post, we are going to solve the same problem but using a 3D Gazebo simulation which includes full ROS controllers. The simulation includes physics and controllers behavior which makes the problem to solve even more complicated, but closer to reality.
Remember that the same thing we are doing in this post can be applied to ANY ROS BASED ROBOT.
The ROSject containing the simulation and pre-made code
We have created a ROSject containing the Gazebo simulation we are going to use, as well as some classes that interconnect the simulation to OpenAI. Those classes use the openai_ros package for easy definition of the RobotEnvironment (defines the connection of OpenAI to the simulated robot) and the TaskEnvironment (defines the task to be solved). This is already provided by the openai_ros package, so we’ll have to do nothing.
We provide all that work already done because in this post we want to concentrate only on comparing RL algorithms on the same robot and the same task.
You can get the code up and running on the ROSDS by getting this ROSject (click on the link to get the code). You can create a free account on ROSDS if you don’t have one. From the rest of tutorial we will assume you have the ROSject open in ROSDS (click on the link, then press Open ROSject on the ROSDS screen).
The Cartpole Simulation
You can launch the simulation inside the ROSDS going to the Simulations Drop Down Menu select Select Launch File and then select:
cartpole_description main.launch
You should get something like this:
cartpole Gazebo openai_ros
That is the simulation we are going to use. Remember that you have to have it launched for the rest of the tutorial.
The algorithms we are going to test
We took several of the best algorithms posted by the users on the OpenAI Gym website to solve the 2D cartpole system:
We adapted them for ROS and to use our Cartpole3D environment. For that we just had to do mainly 2 things:
  • Load the learning parameters from a yaml file instead of loading them from global variables. This allows us to change the values easily and fast. So we are going to create a yaml file for each algorithm that will be loaded before the algorithm is launched.
  • We have changed the OpenAI environment from the 2DCartpole provided by OpenAI (see video above) to the one provided by openai_ros package which interfaces with ROS and Gazebo.
Create the training code
First let’s create the ROS package that will contain everything
Create the ROS package for training
Let’s first create a ROS package where to put all the code we are going to develop. For that, open a shell (Tools->Shell) and type:
$ cd catkin_ws/src
$ catkin_create_pkg cartpole_tests rospy
Create the config files
Here you have an example of of the yaml file for the n1try. Its divided in two main parts:
  • Parameters for Reinforcement Learning algorithm: Values to needed by your learning algorithm, in this case would be n1try, but could be any.
  • Parameters for the RobotEnvironment and TaskEnvironment: These variables are used to tune the task and simulation during setup. These variables have already been set up for you to be optimum, and if you are asking where you would get them from the first place, you can just copy paste the ones in the git example for openai_ros, where you can find examples for all the supported simulations and tasks.  https://bitbucket.org/theconstructcore/openai_examples_projects/src/master/
To create the file do the following:
$ roscd cartpole_tests
$ mkdir config
$ mkdir scripts
$ mkdir launch
Now open the IDE of the ROSDS (Tools->IDE), navigate to the config directory and create there the config file with name cartpole_n1try_params.yaml
Then paste the following content to it and save it:
cartpole_v0: #namespace
    #qlearn parameters
    alpha: 0.01 # Learning Rate
    alpha_decay: 0.01
    gamma: 1.0 # future rewards value 0 none 1 a lot
    epsilon: 1.0 # exploration, 0 none 1 a lot
    epsilon_decay: 0.995 # how we reduse the exploration
    epsilon_min: 0.01 # minimum value that epsilon can have
    batch_size: 64 # maximum size of the batches sampled from memory
    episodes_training: 1000
    n_win_ticks: 250 # If the mean of rewards is bigger than this and have passed min_episodes, the task is considered finished
    min_episodes: 100
    #max_env_steps: None
    monitor: True
    quiet: False
    # Cartpole3D environment variables
    control_type: "velocity"
    min_pole_angle: -0.7 #-23°
    max_pole_angle: 0.7 #23°
    max_base_velocity: 50
    max_base_pose_x: 1.0
    min_base_pose_x: -1.0
    n_observations: 4 # Number of lasers to consider in the observations
    n_actions: 2 # Number of actions used by algorithm and task
    # those parameters are very important. They are affecting the learning experience
    # They indicate how fast the control can be
    # If the running step is too large, then there will be a long time between 2 ctrl commans
    # If the pos_step is too large, then the changes in position will be very abrupt
    pos_step: 1.0     # increment in position/velocity/effort, depends on the control for each command
    init_pos: 0.0 # Position in which the base will start
Modify the learning algorithm for openai_ros
On the IDE create the following file on the scripts folder of your package: cartpole3D_n1try_algorithm_with_rosparams.py
# Inspired by https://keon.io/deep-q-learning/
import random
import gym
import numpy as np
from collections import deque
from keras.models import Sequential
from keras.layers import Dense
from keras.optimizers import Adam
from openai_ros.task_envs.cartpole_stay_up import stay_up
class DQNRobotSolver():
    def __init__(self, environment_name, n_observations, n_actions, n_episodes=1000, n_win_ticks=195, min_episodes= 100, max_env_steps=None, gamma=1.0, epsilon=1.0, epsilon_min=0.01, epsilon_log_decay=0.995, alpha=0.01, alpha_decay=0.01, batch_size=64, monitor=False, quiet=False):
        self.memory = deque(maxlen=100000)
        self.env = gym.make(environment_name)
        if monitor: self.env = gym.wrappers.Monitor(self.env, '../data/cartpole-1', force=True)
        self.input_dim = n_observations
        self.n_actions = n_actions
        self.gamma = gamma
        self.epsilon = epsilon
        self.epsilon_min = epsilon_min
        self.epsilon_decay = epsilon_log_decay
        self.alpha = alpha
        self.alpha_decay = alpha_decay
        self.n_episodes = n_episodes
        self.n_win_ticks = n_win_ticks
        self.min_episodes = min_episodes
        self.batch_size = batch_size
        self.quiet = quiet
        if max_env_steps is not None: self.env._max_episode_steps = max_env_steps
        # Init model
        self.model = Sequential()
        self.model.add(Dense(24, input_dim=self.input_dim, activation='tanh'))
        self.model.add(Dense(48, activation='tanh'))
        self.model.add(Dense(self.n_actions, activation='linear'))
        self.model.compile(loss='mse', optimizer=Adam(lr=self.alpha, decay=self.alpha_decay))
    def remember(self, state, action, reward, next_state, done):
        self.memory.append((state, action, reward, next_state, done))
    def choose_action(self, state, epsilon):
        return self.env.action_space.sample() if (np.random.random() <= epsilon) else np.argmax(self.model.predict(state)) def get_epsilon(self, t): return max(self.epsilon_min, min(self.epsilon, 1.0 - math.log10((t + 1) * self.epsilon_decay))) def preprocess_state(self, state): return np.reshape(state, [1, self.input_dim]) def replay(self, batch_size): x_batch, y_batch = [], [] minibatch = random.sample( self.memory, min(len(self.memory), batch_size)) for state, action, reward, next_state, done in minibatch: y_target = self.model.predict(state) y_target[0][action] = reward if done else reward + self.gamma * np.max(self.model.predict(next_state)[0]) x_batch.append(state[0]) y_batch.append(y_target[0]) self.model.fit(np.array(x_batch), np.array(y_batch), batch_size=len(x_batch), verbose=0) if self.epsilon > self.epsilon_min:
            self.epsilon *= self.epsilon_decay
    def run(self):
        rate = rospy.Rate(30)
        scores = deque(maxlen=100)
        for e in range(self.n_episodes):
            init_state = self.env.reset()
            state = self.preprocess_state(init_state)
            done = False
            i = 0
            while not done:
                # openai_ros doesnt support render for the moment
                #self.env.render()
                action = self.choose_action(state, self.get_epsilon(e))
                next_state, reward, done, _ = self.env.step(action)
                next_state = self.preprocess_state(next_state)
                self.remember(state, action, reward, next_state, done)
                state = next_state
                i += 1
            scores.append(i)
            mean_score = np.mean(scores)
            if mean_score >= self.n_win_ticks and e >= min_episodes:
                if not self.quiet: print('Ran {} episodes. Solved after {} trials'.format(e, e - min_episodes))
                return e - min_episodes
            if e % 1 == 0 and not self.quiet:
                print('[Episode {}] - Mean survival time over last {} episodes was {} ticks.'.format(e, min_episodes ,mean_score))
            self.replay(self.batch_size)
        if not self.quiet: print('Did not solve after {} episodes'.format(e))
        return e
    rospy.init_node('cartpole_n1try_algorithm', anonymous=True, log_level=rospy.FATAL)
    environment_name = 'CartPoleStayUp-v0'
    n_observations = rospy.get_param('/cartpole_v0/n_observations')
    n_actions = rospy.get_param('/cartpole_v0/n_actions')
    n_episodes = rospy.get_param('/cartpole_v0/episodes_training')
    n_win_ticks = rospy.get_param('/cartpole_v0/n_win_ticks')
    min_episodes = rospy.get_param('/cartpole_v0/min_episodes')
    max_env_steps = None
    gamma =  rospy.get_param('/cartpole_v0/gamma')
    epsilon = rospy.get_param('/cartpole_v0/epsilon')
    epsilon_min = rospy.get_param('/cartpole_v0/epsilon_min')
    epsilon_log_decay = rospy.get_param('/cartpole_v0/epsilon_decay')
    alpha = rospy.get_param('/cartpole_v0/alpha')
    alpha_decay = rospy.get_param('/cartpole_v0/alpha_decay')
    batch_size = rospy.get_param('/cartpole_v0/batch_size')
    monitor = rospy.get_param('/cartpole_v0/monitor')
    quiet = rospy.get_param('/cartpole_v0/quiet')
    agent = DQNRobotSolver(     environment_name,
                                n_observations,
                                n_actions,
                                n_episodes,
                                n_win_ticks,
                                min_episodes,
                                max_env_steps,
                                gamma,
                                epsilon,
                                epsilon_min,
                                epsilon_log_decay,
                                alpha,
                                alpha_decay,
                                batch_size,
                                monitor,
                                quiet)
    agent.run()
As you can see the main differences are the rosparam gets and the rosnode init. Also one element that has to be removed is the render method. Just because in Gazebo Render makes no sense, unless is for recording purposes, that will be supported in OpenAI_ROS RobotEnvironments in the future updates.
Create a launch file
And now you have to create a launch file thats loads those paramateres from the YAML file and starts up your script. Go to the launch directory and create the file start_training_n1try.launch
    <rosparam command="load" file="$(find cartpole_tests)/config/cartpole_n1try_params.yaml" />
    <node pkg="cartpole_tests" name="cartpole3D_mbalunovic_algorithm" type="cartpole3D_n1try_algorithm_with_rosparams.py" output="screen"/>
Adapt the algorithm to work with openai_ros TaskEnvironment
And this is the easiest part. You just have to change the name of the OpenAI Environment to load, and in this case import the openai_ros module. And that is, you change the 2D cartpole by the 3D gazebo realistic cartpole. That SIMPLE
This at the top in the import section:
And this line
self.env = gym.make('CartPole-v0')
To a different Task and its loaded through a variable of the class:
And that’s it, you can now launch it with your original algorithm pretty much untouched.
Launch the training
On a shell type the following:
$ roslaunch cartpole_tests start_training_n1try.launch
After a few seconds you should see the cartpole start moving and trying to learn.
Results you may obtain
These are tests made with 1000 epsidoes maximum and it will stop the learning if:
  • We depleat our episodes ( more than 1000 )
  • We Get a Mean Episode Reward bigger than n_win_ticks and we have executed more than min_episodes number of episodes. In this case of n_win_ticks = 250 and min_episodes = 100. This is the reason why the 3D version stoped before the 1000 episodes had ended. Because the mean value of the episode rewards was bigger then 250. While the 2D had values not exceeding 200.
Note: to see the reward chart, got to Tools->OpenAI Reward Chart
How to change the learning algorithm
What if you want to change your algorithm for the same TaskEnvironment, like the CartPoleStayUp-v0? Well, with openai_ros is really fast. You just have to change the following:
  • Change the ROS Param YAML file loaded in the Launch file
  • Change the algorithm python script to be launched in the launch file to your new one.
  • Inside your new algorithm main script, place the same TaskEnvironment you had in the previous algorithm script.
For example lets say you need to change from the n1try to the mbalunovic or the ruippeixotog.
  • You will have to create new YAML files with the RL algorithm parameters you need, but with the same simulation parameters
For the mbalunovic algorithm
Create the config file cartpole_mbalunovic_params.yaml
    #qlearn parameters
    state_size: 4 # number of elements in the state array from observations.
    learning_rate: 0.001
    #num_epochs: 50
    replay_memory_size: 1000
    target_update_freq: 100
    initial_random_action: 1
    gamma: 0.99 # future rewards value, 0 none 1 a lot
    epsilon_decay: 0.99 # how we reduse the exploration
    done_episode_reward: -200 # Reward given when episode finishes before interations depleated.
    batch_size: 32 # maximum size of the batches sampled from memory
    max_iterations: 1000 # maximum iterations that an episode can have
    # Environment variables
Create the launch file start_training_mbalunovic.launch
    <rosparam command="load" file="$(find cartpole_tests)/config/cartpole_mbalunovic_params.yaml" />
    <node pkg="cartpole_tests" name="cartpole3D_mbalunovic_algorithm" type="cartpole3D_mbalunovic_algorithm_with_rosparams.py" output="screen"/>
Create the script file cartpole3D_mbalunovic_algorithm_with_rosparams.py (modification from original learning algorithm)
import gym
import keras
import numpy as np
import random
from gym import wrappers
class ReplayBuffer():
  def __init__(self, max_size):
    self.max_size = max_size
    self.transitions = deque()
  def add(self, observation, action, reward, observation2):
    if len(self.transitions) > self.max_size:
      self.transitions.popleft()
    self.transitions.append((observation, action, reward, observation2))
  def sample(self, count):
    return random.sample(self.transitions, count)
  def size(self):
    return len(self.transitions)
def get_q(model, observation, state_size):
  np_obs = np.reshape(observation, [-1, state_size])
  return model.predict(np_obs)
def train(model, observations, targets, actions_dim, state_size):
  np_obs = np.reshape(observations, [-1, state_size])
  np_targets = np.reshape(targets, [-1, actions_dim])
  #model.fit(np_obs, np_targets, epochs=1, verbose=0)
  model.fit(np_obs, np_targets, nb_epoch=1, verbose=0)
def predict(model, observation, state_size):
def get_model(state_size, learning_rate):
  model.add(Dense(16, input_shape=(state_size, ), activation='relu'))
  model.add(Dense(16, input_shape=(state_size,), activation='relu'))
  model.add(Dense(2, activation='linear'))
  model.compile(
    optimizer=Adam(lr=learning_rate),
    loss='mse',
    metrics=[],
  return model
def update_action(action_model, target_model, sample_transitions, actions_dim, state_size, gamma):
  random.shuffle(sample_transitions)
  batch_observations = []
  batch_targets = []
  for sample_transition in sample_transitions:
    old_observation, action, reward, observation = sample_transition
    targets = np.reshape(get_q(action_model, old_observation, state_size), actions_dim)
    targets[action] = reward
    if observation is not None:
      predictions = predict(target_model, observation, state_size)
      new_action = np.argmax(predictions)
      targets[action] += gamma * predictions[0, new_action]
    batch_observations.append(old_observation)
    batch_targets.append(targets)
  train(action_model, batch_observations, batch_targets, actions_dim, state_size)
def main():
  state_size = rospy.get_param('/cartpole_v0/state_size')
  action_size = rospy.get_param('/cartpole_v0/n_actions')
  target_update_freq = rospy.get_param('/cartpole_v0/target_update_freq')
  initial_random_action = rospy.get_param('/cartpole_v0/initial_random_action')
  replay_memory_size = rospy.get_param('/cartpole_v0/replay_memory_size')
  episodes_training = rospy.get_param('/cartpole_v0/episodes_training')
  max_iterations = rospy.get_param('/cartpole_v0/max_iterations')
  epsilon_decay = rospy.get_param('/cartpole_v0/max_iterations')
  learning_rate = rospy.get_param('/cartpole_v0/learning_rate')
  done_episode_reward = rospy.get_param('/cartpole_v0/done_episode_reward')
  steps_until_reset = target_update_freq
  random_action_probability = initial_random_action
  # Initialize replay memory D to capacity N
  replay = ReplayBuffer(replay_memory_size)
  # Initialize action-value model with random weights
  action_model = get_model(state_size, learning_rate)
  env = gym.make('CartPoleStayUp-v0')
  env = wrappers.Monitor(env, '/tmp/cartpole-experiment-1', force=True)
  for episode in range(episodes_training):
    observation = env.reset()
    for iteration in range(max_iterations):
      random_action_probability *= epsilon_decay
      random_action_probability = max(random_action_probability, 0.1)
      old_observation = observation
      # We dont support render in openai_ros
      if episode % 1 == 0:
        env.render()
      if np.random.random() < random_action_probability: action = np.random.choice(range(action_size)) else: q_values = get_q(action_model, observation, state_size) action = np.argmax(q_values) observation, reward, done, info = env.step(action) if done: print 'Episode {}, iterations: {}'.format( episode, iteration ) # print action_model.get_weights() # print target_model.get_weights() #print 'Game finished after {} iterations'.format(iteration) reward = done_episode_reward replay.add(old_observation, action, reward, None) break replay.add(old_observation, action, reward, observation) if replay.size() >= batch_size:
        sample_transitions = replay.sample(batch_size)
        update_action(action_model, action_model, sample_transitions, action_size, state_size, gamma)
        steps_until_reset -= 1
if __name__ == "__main__":
    rospy.init_node('cartpole_mbalunovic_algorithm', anonymous=True, log_level=rospy.FATAL)
Results
$ roslaunch cartpole_tests start_training_mbalunovic.launch
For the ruippeixotog algorithm
Create the config file cartpole_ruippeixotog_params.yaml
    #qlearn parameters
    gamma: 0.95 # future rewards value, 0 none 1 a lot
    epsilon_min: 0.1 # minimum value that epsilon can have
    episodes_running: 500
    #environment variables
Create the launch file start_training_ruippeixotog.launch
    <rosparam command="load" file="$(find cartpole_tests)/config/cartpole_ruippeixotog_params.yaml" />
    <node pkg="cartpole_tests" name="cartpole3D_ruippeixotog_algorithm" type="cartpole3D_ruippeixotog_algorithm.py" output="screen"/>
Create the training script cartpole_ruippeixotog_algorithm.py
import os
from gym_runner import GymRunner
from q_learning_agent import QLearningAgent
class CartPoleAgent(QLearningAgent):
        epsilon_decay = rospy.get_param('/cartpole_v0/epsilon_decay')
        QLearningAgent.__init__(self,
                                state_size=state_size,
                                action_size=action_size,
                                gamma=gamma,
                                epsilon=epsilon,
                                epsilon_decay=epsilon_decay,
                                epsilon_min=epsilon_min,
                                batch_size=batch_size)
        #super(CartPoleAgent, self).__init__(4, 2)
    def build_model(self):
        model.add(Dense(12, activation='relu', input_dim=4))
        model.add(Dense(12, activation='relu'))
        model.add(Dense(2))
        model.compile(Adam(lr=0.001), 'mse')
        # load the weights of the model if reusing previous training session
        # model.load_weights("models/cartpole-v0.h5")
        return model
    rospy.init_node('cartpole3D_ruippeixotog_algorithm', anonymous=True, log_level=rospy.FATAL)
    episodes_running = rospy.get_param('/cartpole_v0/episodes_running')
    max_timesteps = rospy.get_param('/cartpole_v0/max_timesteps', 10000)
    gym = GymRunner('CartPoleStayUp-v0', 'gymresults/cartpole-v0', max_timesteps)
    agent = CartPoleAgent()
    gym.train(agent, episodes_training, do_train=True, do_render=False, publish_reward=False)
    gym.run(agent, episodes_running, do_train=False, do_render=False, publish_reward=False)
    agent.model.save_weights("models/cartpole-v0.h5", overwrite=True)
    #gym.close_and_upload(os.environ['API_KEY'])
Results obtained
$ roslaunch cartpole_tests start_training_ruippeixotog.launch
Exercise for you!
Do the same process we did for the cartpole but for a Turtlebot robot that has to learn how to move around a round maze. Check the openai_ros package for the required RobotEnvironment and TaskEnvironment to use. You will see how easy it is to change what we have developed for the cartpole into a different robot and task!
Related Course
Using OpenAI with ROS Course Cover - ROS Online Courses - Robot Ignite Academy
[Gazebo Q&A] 003 –  How to spawn an SDF custom model in Gazebo with ROS
In this video, we are going to show you how to spawn an SDF model correctly using a ROS package.
You will learn
  • what to exactly setup so that gazebo can find the model
  • and how to structure the model file to include all the elements needed for any model in GAzebo.
In this case, we will be spawning a pillow answering to the question posted by a user in Gazebo ANSWERS.
Related resources mentioned in the video:
All about Gazebo ROS (Gazebo 9)
Let’s see how to install Gazebo 9 simulator to work with your ROS system. We are going to see how to replace the default version of Gazebo that comes with the installation of ROS and if previously existing simulations work (or not) with this new version of the simulator.
How to install Gazebo ROS (Gazebo 9) in an existing ROS environment
I presume that you already have a ROS distribution in your system. If you do, you probably installed the version of Gazebo that came by default with that ROS distribution. If you check the documentation of Gazebo, you will see that the following table corresponds to the default versions of Gazebo that automatically install with ROS:
  • ROS Indigo: Gazebo 2.x
  • ROS Kinetic:  Gazebo 7.x
  • ROS Lunar: Gazebo 7.x
Let’s see now, how can you proceed to change the default Gazebo version by the newest one (9.x as for 3rd May 2018).
First, uninstall the default Gazebo
If you want to install the latest version, you will have to remove first your default installed Gazebo (which was probably installed when you installed ROS). That is easy, because, independently of the ROS distro, the same command applies to all the distributions to remove the default Gazebo installation:
$ sudo apt-get remove ros-ROS_DISTRO-gazebo*
$ sudo apt-get remove libgazebo*
$ sudo apt-get remove gazebo*
(replace ROS_DISTRO by your distro name.
After having done the uninstall, no Gazebo files will be in your system, neither the ROS related packages. Let’s now install the new Gazebo 9.
Update the repository
You will need to add the osrfoundation repo to your Linux package system in order to get the new packages of Gazebo.
$ sudo sh -c 'echo "deb http://packages.osrfoundation.org/gazebo/ubuntu-stable `lsb_release -cs` main" /etc/apt/sources.list.d/gazebo-stable.list'
$ wget http://packages.osrfoundation.org/gazebo.key -O - | sudo apt-key add -
Then update the repo of packages:
$ sudo apt-get update
The integration of Gazebo with ROS is performed by means of the series of ros-<ROS_VERSION>-gazebo9 packages. The list of ROS – Gazebo packages that OpenRobotics is usually offering is the following (where in our case, we used ROS_VERSION=kinetic):
  • ros-kinetic-gazebo9-dev
  • ros-kinetic-gazebo9-plugins
  • ros-kinetic-gazebo9-ros-control
  • ros-kinetic-gazebo9-msgs
  • ros-kinetic-gazebo9-ros-pkgs
Install Gazebo 9
A very simple command will do it:
$ sudo apt-get install ros-kinetic-gazebo9-*
That command will install all dependencies. To test if everything is properly working, just type:
$ gazebo
A window like the this should appear on your screen.
Gazebo_ROS_install_gazebo
Gazebo 9 robot simulator start screen
[irp posts=”8825″ name=”Launching Husarion ROSbot navigation demo in Gazebo simulation”]
Testing Gazebo with a battery of ROS based simulations
So if you are reading this post is because you are interested in the combo Gazebo / ROS. And your next question should be: will this new version work with our previously working ROS based simulations? The answer to that question is… it depends. It depends for which Gazebo version your simulation was made, and which parts of Gazebo does that simulation use. We have done the following experiments with some of our simulations.
Testing with a robotic arm simulation
Let’s do a simple example: let’s launch a Wam arm robot, which includes several models, a kinect, a laser and an arm robot with joint controllers. The simulation was created for Gazebo 7.x
First, you need to create a catkin_ws:
$ mkdir -p ~/catkin_ws/src
$ cd ~/catkin_ws
$ catkin_make
You can clone and compile the Wam simulation from The Construct public simulations repo with the following commands:
$ cd ~/catkin_ws/src
$ git clone https://TheConstruct@bitbucket.org/theconstructcore/iri_wam.git -b kinetic
$ cd ..
$ catkin_make
$ roslaunch iri_wam_gazebo main.launch
The result is the simulation running just showing some warnings related to xacro namespace redefinitions.
inconsistent namespace redefinitions for xmlns:xacro:
 old: http://ros.org/wiki/xacro
 new: http://www.ros.org/wiki/xacro (/home/ricardo/catkin_ws/src/iri_wam/iri_wam_description/xacro/iri_wam_1.urdf.xacro)
That warning can be resolved by changing in all the affected files, the xacro definition from this:
xmlns:xacro="http://ros.org/wiki/xacro"
to this:
xmlns:xacro="http://www.ros.org/wiki/xacro"
There was no problem executing any of those. Bear in mind that it includes joint controllers as well as a couple of sensor plugins. So no modification was required in the simulation (remember, originally created for Gazebo 7.x).
Gazebo ROS Gazebo9 simulation Wam robot ros
Gazebo 9 simulation of the Wam robot with ROS
Testing with a wheeled robot simulation
Next simulation we tested was the Summit XL robot simulation by Robotnik. We used the following commands:
$ git clone https://TheConstruct@bitbucket.org/theconstructcore/summit_xl.git -b kinetic
$ cd ..
$ catkin_make
In this case, we also had no problem when launching the simulation with the following command:
$ roslaunch sumit_xl_course_basics main.launch
Gazebo ROS Gazebo9 Summit XL robot simulation
Summit XL robot simulation running in Gazebo 9
Testing with a full environment simulation
In this case, we decided to test a simulation created by the Gazebo team themselves, which they used for a competition and that was created for Gazebo 8. It is also an interesting simulation because includes a complete biped robot with several sensors, in a full office environment with people moving around, and plenty of stuff. Have a look at it here.
$ hg clone https://TheConstruct@bitbucket.org/osrf/servicesim
$ cd ..
$ catkin_make
$ roslaunch servicesim servicesim.launch
The simulation worked nicely off-the-shelf.
Gazebo ROS ServiceSim Gazebo9
ServiceSim running in Gazebo 9
Gazebo ROS ServiceSim Gazebo9 robot
Gazebo ROS Rviz data produced by ServiceSim in Gazebo 9
Rviz showing the data produced by ServiceSim in Gazebo 9
Problems when working with ROS with Gazebo 9
Gazebo is still and will always be a standalone program completely independent from ROS. This makes the work between them is not as smooth as it could be.
No ROS controllers provided
One of the problems I see with Gazebo 9 when working with ROS is that Gazebo provides a lot of interesting robot models through their Ignition Fuel library. However, none of the models includes the ROS controllers. So in case that you want to use the models for a ROS based situation, you need to create the controllers by yourself. One example of this case is the beautiful simulation of the autonomous car environment created by the Gazebo team. The simulation is perfect for a work with autonomous cars, but the only support it has is for Gazebo topics.
Use of SDF format instead of URDF
An additional problem with the models is that they have been created in SDF format. SDF is the default format for creating models and whole simulations in Gazebo 9, but that format is not supported by ROS. This makes more difficult to use the models in Gazebo + ROS simualtions since ROS requires a URDF description of the model to show it on Rviz. (just in case you want to convert SDF models into URDF, check the following tutorial about it).
You may be thinking why to use then SDF instead of URDF for defining the simulations. One of the reasons for using SDF in Gazebo instead of URDF (as indicated by Louise Poubel in this interview of the ROS Developers Podcast) is that SDF overcomes some of the limitations of URDF, like for example the creation of closed loops in a robot model. URDF does not allow to create a robot that has a kinematic chain that splits into two at some point and then unite again. SDF handles that with easy. Watch this video to understand the problem:
Based on that, could it be that the most convenient solution would be to change ROS to support SDF instead of changing Gazebo to support URDF?
What about ROS plugins?
The ROS plugins for Gazebo 9 are the plugins that provide the access to the different sensors and actuators and other functionalities of the simulator through a ROS interface. ROS plugins packages are provided as a different set of ROS packages from the main Gazebo 9 distribution. Usually, those packages are provided some weeks after the new Gazebo version has been released. The good new is that those packages for Gazebo 9 are already available (good job Jose Luis Rivero 😉 and you already installed them at the beginning of this post.
If you where using standard plugins provided by ROS in your simulations, it is very likely that they will still work off-the-shelf. On the other side, if you have created your own plugins using the Gazebo API for that, chances are that they may not work and may need to adapt small changes done in the plugins API.
With Gazebo 9, the simulator reaches a very mature version were quite detailed simulations can be created. Just check for example the impressive simulation created by OSRF of an autonomous cars environment.  Every new version we find new features, but more important than that, we find more stability (that is, less crashes).
If you want to know what features will be included in the future versions of Gazebo and when are they going to be released, just check the Gazebo roadmap.
Related and useful links
