My Robotic Manipulator #1: Basic URDF & RViz
Updated: 07 of August 2023
  1. How to build a robot in a matter of minutes
  2. How to see the robot in RViz
  3. How to move the parts of the robot using Joint State Publisher
  1. Use the rosject: https://app.theconstructsim.com/l/5a5b6f9f/
  3. My Robot Manipulator repository: https://bitbucket.org/theconstructcore/my-robotic-manipulator
  4. ROS Courses:
    1. URDF for Robot modeling: https://app.theconstructsim.com/Course/13
  5. ROS2 Courses:
    1. URDF for Robot Modeling in ROS2 : https://app.theconstructsim.com/courses/83
    2. ROS2 Basics in 5 Days Humble (Python): https://app.theconstructsim.com/Course/132
    3. ROS2 Basics in 5 Days Humble (C++): https://app.theconstructsim.com/Course/133
From the URDF model, we’re going to define the first two links and visualize them in RViz. Up to the end of the video, we’ll have a basic model, a launch file to visualize it and a RViz configuration file for this specific project.
ROS Inside
ROS Inside
ROS Inside logo
In order to follow this tutorial, we need to have ROS installed in our system, and ideally a ROS Workspace (it can be named simulation_ws). To make your life easier, we have already prepared a rosject with a simulation for that: https://app.theconstructsim.com/l/5a5b6f9f/.
My Robotic Manipulator #1: Basic URDF & RViz – Run rosject (example of the RUN button)
Compiling the workspace
As you may already know, instead of using a real robot, we are going to use a simulation. In order to see that simulated robot, we need to have our workspace compiled, and for that, we need a terminal.
Once inside the first terminal, let’s run the commands below, to compile the workspace
cd ~/simulation_ws/
How the mrm_description package was created
If you check the contents of the ~/simulation_ws/src folder using the Code Editor or the terminal, you will see that it already contains a package named mrm_description there (mrm stands for My Robotic Manipulator). In case you want to know the commands we used to create that package, the commands were the following (you don’t need to run these commands if you already have the rosject).
To create the package that has the urdf package as a dependency, the commands were the following after opening a terminal:
cd ~/simulation_ws/src
catkin_create_pkg mrm_description urdf
We then created a urdf folder inside the mrm_description package with:
cd mrm_description/
mkdir urdf
After the folder was created, we created a file named mrm.xacro using these commands:
cd urdf/
touch mrm.xacro
and we also created the rviz.launch file, used for launching RViz (Robot Visualization tool) with the following commands:
cd ~/simulation_ws/src/mrm_description/
mkdir launch
touch rviz.xacro
You can see the content of these files using the Code Editor, also known as IDE (Integraded Development Environment). In order to open the IDE, just click the Code Editor button, as we can see in the image below:
Open the IDE - Code Editor
Open the IDE – Code Editor
Once the Code Editor is open, just navigate to simulation_ws/src/mrm_description/launch/rviz.launhc and simulation_ws/src/mrm_description/urdf/mrm.xacro to see the content of those files.
After opening the IDE, you can browse through folders by double-clicking them.  In case you want to create a new folder, right click on the parent folder and choose the option New Folder and type in the name you want to give to the folder.
The mrm.xacro file (My Robot Manipulator xacro file)
If we check the content of the mrm.xacro file, be it using the Code Editor or using the terminal (cat ~/simulation_ws/src/mrm_description/urdf/mrm.xacro), we will find the following:
<?xml version="1.0" ?>
    <link name="base_link">
        <visual>
          <origin rpy="0 0 0" xyz="0 0 0" />
            <box size="1 1 1" />
    <joint name="base_link__link_01" type="revolute">
        <axis xyz="0 0 1"/>
        <limit effort="1000.0" lower="-3.14" upper="3.14" velocity="0.5"/>
        <origin rpy="0 0 0" xyz="0 0 0.5"/>
        <parent link="base_link"/>
        <child link="link_01"/>
    <link name="link_01">
        <visual>
          <origin rpy="0 0 0" xyz="0 0 0.2" />
            <cylinder radius="0.35" length="0.4" />
</robot>
In the IDE (Code Editor), you can find it under the urdf folder:
Let’s understand the parts of this file.
The xacro file contains the description of our manipulator.
The first line tells us that this is an XML fie:
The next line we define a robot using the <robot> tag, that ends in the last line with </robot>:
</robot>
Then we define a link named base_link , with his visual being a box of width, depth, and height of 1 meter. The origin of the base_link is at the center of the simulated world, at position 0 0 0:
  <visual>
Then we create a joint to connect the base_link we just created, with a link named link_01 that we are about to create. The joint was defined with this code:
  <axis xyz="0 0 1"/>
As we can see in the parent and child tags, we connect base_link to link_01. The link_01 link was defined as follows:
  <visual>
The link visual is represented by a cylinder.
In summary, this xacro file is a description of our robot in xml language. The robot is composed of various links and joints. In the above xacro we have two links base_link and link1. The base_link is fixed to the ground. It is connected to the link1 with a revolute joint. The joint allows the link1 to rotate about z-axis. We are defining the visual properties in this file.
The geometry property controls the appearance and origin property controls the positioning of the elements.
The joint element has an axis property which defines the degree of freedom of the links connected with joint. In addition to the axis property, the joint element has limit property to control the range of motion, parent and child property to control the relative motion (the child link moves with respect to the parent link).
Now that we have our robot defined, we need a way of launhcing it. For that, we have the rviz.launch file mentioned earlier. Let understand it:
The rviz.launch file
The content of the rviz.launch file that we created in the previous sections can be seen either using the Code Editor or through the terminal using this command:
cat ~/simulation_ws/src/mrm_description/launch/rviz.launch
Its content is as following:
  <param name="robot_description" command="$(find xacro)/xacro --inorder '$(find mrm_description)/urdf/mrm.xacro'"/>
  <!-- Combine joint values -->
  <node name="robot_state_publisher" pkg="robot_state_publisher" type="robot_state_publisher"/>
  <!-- Show in Rviz   -->
  <node name="rviz" pkg="rviz" type="rviz" args="-d $(find mrm_description)/launch/config.rviz" />
  <!-- send joint values -->
  <node name="joint_state_publisher_gui" pkg="joint_state_publisher_gui" type="joint_state_publisher_gui">
    <param name="use_gui" value="true"/>
In the fist line we start the definition of the launch file using the <launch> tag.
In the second line, we load a ROS parameter called robot_description using the content of of the urdf/mrm.xacro file that is found on the mrm_description package. It is basically the xacro file explained in the previous section.
In order to “put the robot pieces together“, we use the robot_state_publisher:
We also launch RViz in that launch file, and tell it to load the launch/config.rviz file that is also inside our package. Having that config.rviz file, we don’t have to reconfigure the RViz displays each time we open RViz.
Finally, we load the Joint State Publisher that allows us to move/rotate the links of our robot using a Graphical Tool:
To summarize, this launch file helps in the task of launching different nodes together. The rviz.launch file above creates three nodes. The first node is for publishing the robot state, the second node starts RViz and the last node starts a GUI tool that helps in manipulating the joint angle of the robot. The first line (param) helps in locating and loading the xacro file that contains the robot description.
Now that we have everything in place, we need to compile our workspace. For that, we use the following commands:
cd ~/simulation_ws/
If everything went well, you should have an output similar to the following:
-- catkin 0.8.10
-- BUILD_SHARED_LIBS is on
-- ~~  traversing 1 packages in topological order:
-- ~~  - mrm_description
-- +++ processing catkin package: 'mrm_description'
-- ==> add_subdirectory(mrm_description)
-- Configuring done
-- Generating done
-- Build files have been written to: /home/user/simulation_ws/build
#### Running command: "make -j8 -l8" in "/home/user/simulation_ws/build"
Lauching RViz to see our robot model
In the previous sections we already learned how to open a terminal.
Now, in order to launch RViz, let’s run the following commands in the first terminal:
roslaunch mrm_description rviz.launch
After running this launch file, you should have seen RViz and the Joint State Publisher. If RViz does not open automatically, just click the Graphical Tools button on the bottom bar of The Construct Desktop. If you don’t know which button is, just hover your mouse over the buttons to know which one opens the Graphical Tools.
After having the Graphical Tools open, feel free to move the joining using the Joint State Publisher. It is going to be difficult to see the joint moving because it has the same red color as the base link, but if you look at RViz closely, you will see it moving.
The GUI tool is like a remote desktop, when it starts you can see there are two tabs at the bottom. One is the RViz tool, and the other is the joint_state_publisher GUI as shown below:
In the RViz window, we should have everything in place. We shouldn’t have the red errors like in the image above, because in the rosject we already provided the config.rviz in the launch file, if you remember well.
What we did for creating that config.rviz file was the following, in RViz:
  • Changed Fixed Frame to base_link
  • Added an Axis element
  • Added a RobotModel element
The images below show the operations described above:
Congratulations. Now you know how to create a basic robot with two links and a joint using Xacro files.
We hope this post was really helpful to you. If you want a live version of this post with more details, please check the video in the next section. Although the video was recorded in a previous version of The Construct platform, it still adds a lot of value:
  1. ROS Courses:
    1. URDF for Robot modeling (ROS 1): https://app.theconstructsim.com/Course/13
  2. ROS2 Courses:
[ROS Projects] – ROS with Raspberry Pi 3 using Gazebo Face Simulation #Part 4
In this video, you will learn how to use the Face Landmarks published in Part2 to make the MagicMirror Face move in simulation.
Want to start developing for ROS now? Check out RDS:
https://goo.gl/Lud9hQ
Want to learn more about how to move a robot in ROS? Check out the RobotIgniteCourse on URDF robot generation:
https://goo.gl/9kUsS9
[ROS Projects] – ROS with Raspberry Pi 3 using Gazebo Face Simulation #Part3
In this video you will learn how to use the sound_play package for working with sound in ROS. You can use it for playing sounds from sound files or to make Text to Speech. Here you will also learn how to play sounds in a python notebook in ROS Development Studio. At the end you will learn how to apply all this to your Raspberry Pi.
Thank you very much to:
Play Sound in Python Notebooks:
https://gist.github.com/aisipos/8640905
ROS sound play package:
http://wiki.ros.org/sound_play
Work with pyaudio sound streams:
https://www.swharden.com/wp/2016-07-19-realtime-audio-visualization-in-python/
[ROS Projects] – ROS with Raspberry Pi 3 using Gazebo Face Simulation #Part2
In this video we continue with what you learned in the previous one, we connect to RaspBerryPi through ssh and OpenVPN. We will record a ROSbag in ROS Developement Studio to avoid memory issues that RaspBerry Pi has when recording rosbags. We will then use FaceLandmark python code to detect facial landmarks and publish them in ROS. Finally we will visualise those markers in RVIZ. We will also do as extra, the head orientation detection and publish it in ROS topics also.
LearnOpenCV for the HeadOrientation algorithm, check it out here:
https://www.learnopencv.com/head-pose-estimation-using-opencv-and-dlib/
Pyimagesearch for the faceLandmark tracking and usefull tools ( imutils )
https://www.pyimagesearch.com/2017/04/10/detect-eyes-nose-lips-jaw-dlib-opencv-python/
https://github.com/jrosebr1/imutils
Want to learn more ROS, go to RobotIgniteAcademy
https://www.robotigniteacademy.com/en/
Want to Develope for ROS and have unlimited power with RaspberryPi? Ros Developement Studio
https://www.theconstruct.ai/rds-ros-development-studio/
[ROS Projects] – ROS with Raspberry Pi 3 using Gazebo Face Simulation #Part1
Learn how to use a Gazebo simulation in Raspberry Pi through OpenVPN. Access ROS topics published in ROS Developement Studio in RaspberryPi and also access images published by Raspberry Pi in ROS Developement Studio.
Access ROS Developement Studio Now: https://goo.gl/8PR8TE
Learn also how to access Raspberry Pi through SSH or RDP from your local computer.
See all this in action through a simulation of a Face created with blender in Gazebo.
Learn all the ROS needed and more to use this simulation in Robot Ignite Academy: https://goo.gl/eHtW7h
Know how to get your Raspberry Pi ready with Ubuntu Mate , camera publishing in ROS in this blog Post: https://goo.gl/b8LTkX
Reference Sources:
SSH instructions :
https://goo.gl/bJ7XXr
https://goo.gl/JPMhLj
RDP instructions:
https://goo.gl/Kig4ck
[ROS Projects] – Build the Sentinel Robots from Matrix for Gazebo Simulator #Part3
The third video on the series where you learn how to build the sentinel of TheMatrix film, which is an octopus like robot. Learn how to build it in Gazebo and use ROS to move it around. Next set of videos will be about adding the meshes. Remember  to post your crazy robot projects in this video and I’ll pick a winner on the next videos ;). Have fun with robotics.
