[ROS Projects] – ROS with Raspberry Pi 3 using Gazebo Face Simulation #Part 4
In this video, you will learn how to use the Face Landmarks published in Part2 to make the MagicMirror Face move in simulation.
Want to start developing for ROS now? Check out RDS:
https://goo.gl/Lud9hQ
Want to learn more about how to move a robot in ROS? Check out the RobotIgniteCourse on URDF robot generation:
https://goo.gl/9kUsS9
[ROS Projects] – ROS with Raspberry Pi 3 using Gazebo Face Simulation #Part3
In this video you will learn how to use the sound_play package for working with sound in ROS. You can use it for playing sounds from sound files or to make Text to Speech. Here you will also learn how to play sounds in a python notebook in ROS Development Studio. At the end you will learn how to apply all this to your Raspberry Pi.
Thank you very much to:
Play Sound in Python Notebooks:
https://gist.github.com/aisipos/8640905
ROS sound play package:
http://wiki.ros.org/sound_play
Work with pyaudio sound streams:
https://www.swharden.com/wp/2016-07-19-realtime-audio-visualization-in-python/
[ROS Projects] – ROS with Raspberry Pi 3 using Gazebo Face Simulation #Part2
In this video we continue with what you learned in the previous one, we connect to RaspBerryPi through ssh and OpenVPN. We will record a ROSbag in ROS Developement Studio to avoid memory issues that RaspBerry Pi has when recording rosbags. We will then use FaceLandmark python code to detect facial landmarks and publish them in ROS. Finally we will visualise those markers in RVIZ. We will also do as extra, the head orientation detection and publish it in ROS topics also.
LearnOpenCV for the HeadOrientation algorithm, check it out here:
https://www.learnopencv.com/head-pose-estimation-using-opencv-and-dlib/
Pyimagesearch for the faceLandmark tracking and usefull tools ( imutils )
https://www.pyimagesearch.com/2017/04/10/detect-eyes-nose-lips-jaw-dlib-opencv-python/
https://github.com/jrosebr1/imutils
Want to learn more ROS, go to RobotIgniteAcademy
https://www.robotigniteacademy.com/en/
Want to Develope for ROS and have unlimited power with RaspberryPi? Ros Developement Studio
https://www.theconstruct.ai/rds-ros-development-studio/
[ROS Projects] – ROS with Raspberry Pi 3 using Gazebo Face Simulation #Part1
Learn how to use a Gazebo simulation in Raspberry Pi through OpenVPN. Access ROS topics published in ROS Developement Studio in RaspberryPi and also access images published by Raspberry Pi in ROS Developement Studio.
Access ROS Developement Studio Now: https://goo.gl/8PR8TE
Learn also how to access Raspberry Pi through SSH or RDP from your local computer.
See all this in action through a simulation of a Face created with blender in Gazebo.
Learn all the ROS needed and more to use this simulation in Robot Ignite Academy: https://goo.gl/eHtW7h
Know how to get your Raspberry Pi ready with Ubuntu Mate , camera publishing in ROS in this blog Post: https://goo.gl/b8LTkX
Reference Sources:
SSH instructions :
https://goo.gl/bJ7XXr
https://goo.gl/JPMhLj
RDP instructions:
https://goo.gl/Kig4ck
[ROS Projects] – Build the Sentinel Robots from Matrix for Gazebo Simulator #Part3
The third video on the series where you learn how to build the sentinel of TheMatrix film, which is an octopus like robot. Learn how to build it in Gazebo and use ROS to move it around. Next set of videos will be about adding the meshes. Remember  to post your crazy robot projects in this video and I’ll pick a winner on the next videos ;). Have fun with robotics.
