How to use webots with ROS2 – ROS2 Q&A # 235
  1. How to use Webots with ROS2
  1. Use the rosject: https://app.theconstructsim.com/l/5020588f/
  2. Webots Simulator: https://github.com/cyberbotics/webots
  3. Webots documentation: https://cyberbotics.com/doc/guide/index
  4. The Construct: https://app.theconstructsim.com/
  5. ROS2 Courses –▸
    3. ROS2 Navigation training: https://www.theconstruct.ai/ros2-navigation-training/
In this post, we will learn how to use a simulator other than Gazebo in ROS. We are going to use the Webots Simulator, whose code is available at https://github.com/cyberbotics/webots
ROS inside
ROS inside
Before anything else, in case you want to use the logo above on your own robot, feel free to download it for free and attach it to your robot. It is really free. Find it in the link below:
ROS Inside logo
In order to work with Webots with ROS 2, we need to have ROS2 installed in our system, and ideally a ros2_ws (ROS2 Workspace). To make your life easier, we already prepared a rosject with a simulation for that: https://app.theconstructsim.com/l/5020588f/.
Opening the Code Editor
Let’s start by opening the Code Editor by clicking on the second link:
Open the IDE - Code Editor
Open the IDE – Code Editor
Once the Code Editor is open, you should be able to see that we have the webots folder in the root.
That folder contains the Webots version R2022b compiled from source.
If you are really new to Webots, you can follow the complete guide available at https://cyberbotics.com/doc/guide/index.
Starting Webots Simulator
In order to start Webots using the command line, let’s start by opening a terminal:
Now, to open Webots we only need the two following commands:
cd ~/webots
./webots
After a few seconds, you should have a pop-up with a Webots ROS2 Simulation (by default it shows the last simulation we used). If the pop-up doesn’t open, you can have it by clicking on the 4th Icon of the bottom bar.
Ok, now that you know how to open Webots manually, feel free to close the simulator by pressing CTRL+C on the command line, or manually pressing the Close Webots button available on the top right corner of the simulator.
Launching a Webots world
As you may have noticed, we have a workspace named ros2_ws. That workspace contains ROS2 packages ready for Webots.
Let’s launch a simulation using the following command:
ros2 launch webots_ros2_epuck robot_launch.py
That command will basically load the world that we saw in the previous picture.
You can now go to a second terminal and check the topics with:
ros2 topic list
If you want to move a robot, you would need external controllers, but that is a topic for another post.
In any case, you can always refer to the official documentation. For External Controllers, the documentation is available at https://cyberbotics.com/doc/guide/running-extern-robot-controllers?tab-os=linux
Another simulation you could launch with Webots is Turtlebot:
ros2 launch webots_ros2_turtlebot robot_launch.py
It may take a while to load because Webots downloads the assets in the background. But after a while, you should have the Turtlebot simulation up and running:
Turtlebot robot on Webots Simulator
You can list the ros2 topics just as you did for the previous simulation:
ros2 topic list
You can even load a Tesla simulation with Webots, in which you have a Tesla in a city:
Testa Simulation in Webots
Webots guided tour
You can also follow the Webots Guided Tour by clicking Help -> Webots Guided Tour, although most of the tours right now are still for ROS (ROS1).
Congratulations. You have just learned the basics of how to start a Webots simulation using ROS2. We hope this post was really helpful to you. If you want a live version of this post, please check the video in the next section.
How to create a ros2 C++ Library
In this post, you will learn how to create and use your own ros2 C++ library. I’ll show you how to create the library and then use it in a demo package.
Once logged in, click on My Rosjects, then Create a New Rosject, supply the information as shown in the video and click Create. Then RUN the rosject.
Create a new Rosject
Step 2: Create a new package that contains the library’s source code (logic)
Open Code Editor
Open a web shell
cd ros2_ws/src
source /opt/ros/humble/setup.bash/
ros2 pkg create my_value_converter_library --build-type ament_cmake --license BSD-3-Clause
Now that your package is created, we need to create a header file for the library. Move inside the include/my_value_converter_library directory and create a header file named library_header.h.
cd ~/ros2_ws/src/my_value_converter_library/include/my_value_converter_library
touch library_header.h
Now head over to the Code Editor to make changes to the header file. Check the image below for how to open the Code Editor.
Open the Code Editor
Locate the header file in the code editor: ros2_ws > src > my_value_converter_library > include > my_value_converter_library > library_header.h and paste in the following code.
#ifndef MAP_VALUE_H
#define MAP_VALUE_H
double map_value(double x, double in_min, double in_max, double out_min, double out_max);
#endif
Next, we create the C++ source code file for the library. In the same web shell:
cd ~/ros2_ws/src/my_value_converter_library/src
touch my_value_converter_library.cpp
Locate the my_value_converter_library.cpp file in the code editor and paste in the following code:
#include "my_value_converter_library/library_header.h"
double map_value(double x, double in_min, double in_max, double out_min, double out_max) {
  return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
Now we need to edit the CMakeLists.txt file of our package to recognize the source code we have just added. Open the file ros2_ws > src > my_value_converter_library > CMakeLists.txt and add the following lines before the ament_package() call.
# let the compiler search for headers in the include folder
include_directories(include)
# define a library target called my_value_converter_library
add_library(my_value_converter_library src/my_value_converter_library.cpp)
# this line to exports the library
ament_export_targets(my_value_converter_library HAS_LIBRARY_TARGET)
# install the include/my_cpp_library directory to the install/include/my_cpp_library
install(
  DIRECTORY include/my_value_converter_library
  DESTINATION include
install(
  TARGETS my_value_converter_library
  EXPORT my_value_converter_library
  LIBRARY DESTINATION lib
  ARCHIVE DESTINATION lib
  RUNTIME DESTINATION bin
  INCLUDES DESTINATION include
colcon build
Success! We have now created our library. Next, we are going to use it!
Step 3: Create a new package that uses the library you just created
Create the new package in the open shell. Note that my_value_converter_library is passed as a dependency during the creation of the new package. This will simplify some of the work that needs to be done when modifying the CMakeLists.txt file.
cd ros2_ws/src
ros2 pkg create my_value_converter_node --build-type ament_cmake --license BSD-3-Clause --dependencies rclcpp std_msgs my_value_converter_library
Now verify that the dependencies have been properly added. If the build runs successfully, it is so. If not, please correct the errors before you proceed.
colcon build
If you got to this point, great! Now we will create the C++ source code that will use your library.
cd ~/ros2_ws/src/my_value_converter_node/src
touch my_value_converter_node.cpp
Now locate the my_value_converter_node.cpp file in the code editor and paste in the following source code.
#include <memory>
#include <string>
#include "rclcpp/rclcpp.hpp"
#include "std_msgs/msg/float32.hpp"
class ConverterNode : public rclcpp::Node {
public:
  explicit ConverterNode() : Node("converter_node") {
    auto callback =
        [this](const std_msgs::msg::Float32::SharedPtr input_msg) -> void {
      RCLCPP_DEBUG(this->get_logger(), "I heard: [%f]", input_msg->data);
      // Use the library
      // Map an value from 0 - 1023 range to -1.0 to +1.0 range
      double new_value = map_value(input_msg->data, 0, 1023, -1.0, 1.0);
      output_msg_ = std::make_unique<std_msgs::msg::Float32>();
      output_msg_->data = new_value;
      RCLCPP_DEBUG(this->get_logger(), "Publishing: '%f'", output_msg_->data);
      pub_->publish(std::move(output_msg_));
    sub_ = create_subscription<std_msgs::msg::Float32>("output_topic", 10,
                                                       callback);
    // Create a publisher
    rclcpp::QoS qos(rclcpp::KeepLast(7));
    pub_ = this->create_publisher<std_msgs::msg::Float32>("input_topic", qos);
private:
  std::unique_ptr<std_msgs::msg::Float32> output_msg_;
  rclcpp::Publisher<std_msgs::msg::Float32>::SharedPtr pub_;
  rclcpp::Subscription<std_msgs::msg::Float32>::SharedPtr sub_;
  rclcpp::init(argc, argv);
  auto node = std::make_shared<ConverterNode>();
  RCLCPP_INFO(node->get_logger(), "My value converter node started.");
  rclcpp::spin(node);
  rclcpp::shutdown();
As you might have expected, we need to modify the CMakeLists.txt file for our new package. Locate the ros2_ws > src > my_value_converter_node > CMakeLists.txt in the code editor and paste in the following code before the ament_package() call.
# define the binary to be built and identify the source files with with which to build it
add_executable(main src/my_value_converter_node.cpp)
# tell CMake that the executable "main" depends on the library "my_value_converter_library"
ament_target_dependencies(main my_value_converter_library rclcpp std_msgs)
# install the executable in the lib folder to make it detectable through setup.bash
install(TARGETS
  main
  DESTINATION lib/${PROJECT_NAME}/
Now build and use your package!
colcon build
ros2 run my_value_converter_node main
Step 4: Check your learning
Do you understand how to create a ros2 C++ library? If you don’t know it yet, please go over the post again, more carefully this time.
(Extra) Step 5: Watch the video to understand how to install a ros2 binary package
Did you like this post? Do you have any questions about how to create a ros2 C++ library? Please leave a comment in the comments section below, so we can interact and learn from each other.
How to release a ROS 2 binary package [Part 2/3]
  • How to create a ros/rosdistro source entry so that your package can be released with ROS. Something like: sudo apt-get install ros-humble-my-package-name
  1. Part 1 of this series: https://www.theconstruct.ai/how-to-release-a-ros-2-binary-package-part-1-2
  2. Use the rosject: https://app.theconstructsim.com/l/50995c4e/
  3. The Construct: https://app.theconstructsim.com/
  4. ROS2 Courses –▸
ROS2, the improved version of ROS (ROS1), is quickly becoming the standard for developing robotics applications.
In this post, we will learn the second part on how to release a ROS2 package as a binary file. Binary files are pre-built executables. They are easier to install because they do not require building from the source code. Binary files are perfect if you want to easily distribute a package to other people.
You can easily install them with apt-get install PKG_NAME, or sudo dpkg -i pkg-name.deb, for example.
It is highly recommended that you follow that Part 1, since it is a requirement for following this post:
Also, the third part of this series can be found in the link below:
ROS Inside
ROS Inside
Before anything else, in case you want to use the logo above on your own robot or laptop, feel free to download it for free and attach it to your robot. It is really free. Find it in the link below:
ROS Inside logo
Acknowledgment
This post is based on ROS2’s official documentation, check it out here:
https://docs.ros.org/en/humble/How-To-Guides/Releasing/Releasing-a-Package.html
In order to release a ROS 2 binary package, we need to have ROS2 installed in our system, and it is also useful to have some simulations. To make your life easier, we already prepared a rosject with a simulation for that: https://app.theconstructsim.com/l/50995c4e/.
How to release a ROS 2 binary package – Run rosject (example of the RUN button)
Assumptions
  • Existing ROS2 Package, publicly available for everyone to use
  • Git and GitHub basics
  • You have completed the first part aforementioned:
    • Created a release repository
    • Started a new release team (pull request is pending)
    • Installed the tools required on our machine
    • Created a GIT access token to authenticate
Open a terminal
You will need to clone a repository soon, so, in order to do that, you will need a terminal. If you are new to the platform, you can easily open a terminal by clicking on the first button on the bottom left.
Create a ros/rosdistro source entry
What is ros/rosdistro? https://github.com/ros/rosdistro is a GitHub repository that maintains information describing ROS packages and repositories. The build process accesses this information to build packages.
The rosdistro repository also stores the rules used by rosdep to install external dependencies.
To see all ROS Packages included in ROS Humble, for example, you can have a look at this file: https://github.com/ros/rosdistro/blob/master/humble/distribution.yaml
Validation process
When you create a ros/rosdistro source entry for a package that you release for the very first time, your repository will be reviewed to check whether it conforms to some basic rules.
Here is an example of some of the validations performed:
To add create a ros/rosdistro source entry one can manually open a pull request to the corresponding GitHub repository:
Steps:
  1. Fork the https://github.com/ros/rosdistro repository on GitHub by clicking https://github.com/ros/rosdistro/fork.
  2. Clone the repo fork, so you can edit the contents locally. Something like:
    cd ~/ros2_ws/src
    git clone https://github.com/YOUR-USERNAME/rosdistro
    cd rosdistro
    Add your repository to the repository listing:
    • Open the appropriate directory for the distribution that you would like to add a listing to through the IDE.
    • Inside this directory, edit the distribution.yaml file.
    • Add your repository information with a doc section as shown below.Considerations:
      • You should maintain the alphabetic order of the repositories
      • The repository URL should point to the upstream repository, not the release repository.
Example distro file: humble/distribution.yaml
wall_follower_ros2:
  source:
    type: git
    url: https://github.com/rfzeg/wall_follower_ros2.git
    version: master
  status: maintained
Now, go back to the rosdistro root directory and run the following command:
rosdistro_reformat file://"$(pwd)"/index.yaml
This will make the files comply with rosdistro’s special formatting rules.
Check the differences made by the script you just ran:
git diff distribution.yaml
which should show something like this:
git diff
git diff
If everything looks good, you are ready to commit your changes:
git commit -m "Add wall_follower_ros2 repo"
Push your changes to your remote GitHub repository:
git push origin master
Create and Submit a pull request on GitHub to the rosdistro project to add your source entry to the indexer.
To create a new request, go to your repository and click the Contribute -> Open pull request button:
Open a Pull Request for rosdistro
After that, git a title to the Pull Request. Title example:
Add wall_follower_ros2 repo to humble
Then the body of the Pull Request goes like this:
Adding new repository: https://github.com/rfzeg/wall_follower_ros2.git to humble
as requested in https://github.com/ros2-gbp/ros2-gbp-github-org/issues/99
for the purpose of releasing the package wall_follower_ros2
# Checks
[x] All packages have a declared license in the package.xml
[x] This repository a LICENSE file
[x] This package is expected to build on the submitted rosdistro
Remember that after submitting your pull request, some changes may be requested, and since the reviews are done asynchronously, it can sometimes take a few days until the review is completed.
Now, if they ask you to modify anything, you just go ahead and do the modifications.
You may now want to go ahead and check how to build a Debian file locally:
Congratulations. We have finished the second part about the release of a ROS2 Binary package. We hope this post was really helpful to you. We soon may have an extra part related to this subject.
Please bear in mind that the third part of this series can be found in the link below:
How to release a ROS 2 binary package [Part 1/3]
  1. How to create a new release repository
  2. How to create a new release team
  3. How to install the tools that you will use
  4. How to create a Personal Access Token on GitHub
  1. Use the rosject: https://app.theconstructsim.com/l/4f2b155e/
  3. ROS 2 Documentation: https://docs.ros.org/en/humble/How-To-Guides/Releasing/Releasing-a-Package.html
  4. ROS2 basic Courses –▸
    1. ROS2 Basics in 5 Days (Python): https://app.theconstructsim.com/Course/73
    2. ROS2 Basics in 5 Days (C++): https://app.theconstructsim.com/Course/61
    3. ROS2 Basics in 5 Days Galactic (C++): https://app.theconstructsim.com/Course/117
In this post, we will learn how to release a ROS2 package as a binary file. Binary files are pre-built executables. They are easier to install because they do not require building from the source code. Binary files are perfect if you want to easily distribute a package to other people.
This is the first post in a series of two posts.
The second post can be found at:
ROS inside
ROS inside
ROS Inside logo
Acknowledgment
In order to release a ROS 2 binary package, we need to have ROS2 installed in our system, and it is also useful to have some simulations. To make your life easier, we already prepared a rosject with a simulation for that: https://app.theconstructsim.com/l/4f2b155e/.
Assumptions
We assume you have a GitHub account. If you don’t have it yet, you can easily create it by following this link: https://github.com/signup
Creating a ‘release repository’
When a release process runs, it outputs files for instance .md and .yaml files. This output is known as release artifacts. In ROS2, these artifacts need to be stored in a separate repository from the source code files. This repository is what we call the release repository.
So, if your repository name is wall_follower_ros2, you have to create a new repository that you can call, for instance, wall_follower_ros2-release to be used as a release repository for your package.
The ROS2 release process will use that repository to store artifacts as the automated release process runs.
I’m going to create a release repository for https://github.com/rfzeg/wall_follower_ros2
To make your life easier, assuming you may not have a repository with the same name, you can start by forking the repository aforementioned.
After that, please go to https://github.com/new and create a repository. The package name can be wall_follower_ros2-release.
You can leave the repository Public, and hit the “Create repository” button.
Creating a release package on GitHub
Start a new release team
release team is a group of users within an organization who has permission to manage all release operations.
If a release team exists in your organization, you can join that team by completing the Update Release Team Membership issue template.
Here, we will assume that no release team exists for our package yet. To request a new release team to be created we must complete the New Release Team issue template.
This form will allow you to create a new release team and add the release repository to your new team in one go.
Below we have an example of the New Release Team issue filled:
Starting a new ros2 release team on GitHub
After creating the issue, you submit it and wait for the ROS2 team to take it into account.
Installing the tools required on your machine
In order to install the required tools, we need to have a terminal. If you are on The Construct, after having opened a rosject, let’s open a terminal:
Let’s take the chance and also open the Code Editor to be easier to modify our files:
Now, let’s go to the terminal and use apt to install bloom together with the python3-catkin-pkg modules.
sudo apt update
sudo apt install python3-bloom python3-catkin-pkg
The package should have been installed with no problems.
Let’s now move to the next step.
Creating a GIT access token to authenticate
Every time you interact with a remote Git repository on the command line (for example, doing a pull, or push operation), you are asked for your GitHub username and password. In this step, we create a Git Access Token to prevent Git from repeatedly prompting for your username and password during the release operation.
You can create an Access Token by clicking the “Generate new token” button in the link below:
When filling out the form, set Note to a descriptive name such as Bloom, set Expiration to No expiration, and select the public_repo and workflow checkboxes.
After clicking on Generate token the page will display a string like CTA2AK1UMAPKSJGSZDR8HWS3GVRAFIQYYETWELT4.
This string is the token, copy it to your clipboard. Make sure to store it safely since you can’t display the token again in the GitHub interface.
In case you need more information on personal access tokens, please follow the link below:
https://docs.github.com/en/authentication/keeping-your-account-and-data-secure/creating-a-personal-access-token
Use the GIT access token to authenticate
Now that we have the Access Token, using the terminal, let’s create a folder named .config:
mkdir -pv ~/.config
Inside that folder, let’s create a file named boom:
cd ~/.config
touch bloom
Using the code editor, insert your GitHub username and PAT into it with the format shown below:
    "github_user": "<your-github-username>",
    "oauth_token": "<token-you-created-for-bloom>"
Since hidden files do not appear by default in the Code Editor, you have to click File Open in order to find the .config folder.
Please remember to save your ~/config/boom file by pressing CTRL+S (or File -> Save)
Congratulations. We are halfway through the release of a ROS2 Binary package. We hope this post was really helpful to you. The second post is coming soon. If you want a live version of this post, please check the video in the next section.
How to install a ros2 binary package
In this post, you will learn how to install a ros2 binary package and make it available for use. This post was written in response to this question on ROS Answers.
“Hey, do you mean I have to install ros2 first?” Absolutely not! Just login to The Construct to get access to virtual machines pre-installed with ROS.
Step 2: Check the ros2 binaries currently installed
Open Code Editor
Open a web shell
Open a web shell and run the following commands. You should see a long list of many binaries!
cd /opt/ros/foxy/share/
ls -al
ROS binaries are stored in /opt/ros/{distro}/share/ If you would like to check if some binary is already installed without going through the long list, use grep. In this case we want to check binaries related to joint_state.
user:/opt/ros/foxy/share$ ls -al | grep joint_state
drwxr-xr-x  1 root root 4096 Sep 17  2021 joint_state_broadcaster
drwxr-xr-x  1 root root 4096 Sep 17  2021 joint_state_controller
drwxr-xr-x  1 root root 4096 Sep 17  2021 joint_state_publisher
drwxr-xr-x  1 root root 4096 Sep 17  2021 joint_state_publisher_gui
Heck, if you were the user in this post, you wouldn’t need to install anything. “What would I do then?!” Read on to find out!
Step 3: Install the ros2 binary package
We will demo this with the same package the user was struggling with: ros-foxy-joint-state-publisher-gui. Since the package is already installed in our case, we need to uninstall it first, just to demonstrate. Run the following on the current shell:
sudo apt update -y
sudo apt remove ros-foxy-joint-state-publisher-gui -y
Now verify that this GUI binary is no longer present.
user:/opt/ros/foxy/share$ ros2 pkg list | grep joint_state
Gone! Now we will install this package again.
sudo apt install ros-foxy-joint-state-publisher-gui -y
Before anything else, and this is probably what was missing for our friend who also installed the package successfully, SOURCE the ros2 distribution!
And that’s it! Installation complete. We are going to use the package now, but let’s check that it’s in the list of binaries.
drwxr-xr-x  2 root root 4096 Oct 11 15:10 joint_state_publisher_gui
Step 4: Use the ros2 binary package
The user got an error when they tried to launch the GUI binary. Let’s see what we get (fingers crossed).
ros2 run joint_state_publisher_gui joint_state_publisher_gui
You should get a GUI like the image below pop up, confirming that the binary is really there. Cheers!
Hello, I am Joint State GUI
Step 5: Check your learning
Do you understand how to install a ros2 binary package and make it available for use? The magic word here is source.
If you didn’t get the point above, please go over the post again, more carefully this time.
(Extra) Step 6: Watch the video to understand how to install a ros2 binary package
Did you like this post? Do you have any questions about how to install a ros2 binary package? Please leave a comment on the comments section below, so we can interact and learn from each other.
[ROS2 How-to] ROS2 Topics vs Services vs Actions #5
  1. When to use Topics
  2. When to use Services
  3. When to use Actions
  1. Use the rosject: https://app.theconstructsim.com/l/4dc71d42/
  3. ROS2 Courses –▸
In this post, we will quickly compare the differences between three main ROS2 ways of interacting with nodes: topics, services, and actions.
We will have some insights on when to use each of them.
ROS inside
ROS inside
ROS Inside logo
What is a ROS2 Action
  1. Go to the Laundry service provider
    1. Put your clothes to wash.
    2. Wait until the clothes are washed.
    3. Get your clothes.
  2. If you have a washing machine at home:
    2. Instead of waiting, you can do other things and leave the watching machine doing its jobs
    3. Check once in a while if the clothes are finished
    4. Do other things.
    5. Clothes are washed.
Option 1 is a blocking activity because you have to wait (in theory not able to do anything else) for the clothes to be washed, while option 2 is non-blocking because you can do some other things while your clothes are being washed.
In order to understand ROS2 Topics, Services, and Actions, we need to have ROS2 installed in our system, and it is also useful to have some simulations. To make your life easier, we already prepared a rosject with a simulation for that: https://app.theconstructsim.com/l/4dc71d42/.
Launching the simulation
Let’s run a simulation before actually starting with the comparison between these three ways of interacting with ROS2 nodes.
Let’s start by opening a terminal:
Now, in the first terminal that we just open, let’s setup our environment:
colcon build
After our workspace is compiled, let’s source it:
Now, we can start our simulation with the following commands:
cd ~/ros2_ws/src/t3_galactic
./start_sim_house.sh
If everything went well, you should have a simulation running, similar to what we have in the image below:
[ROS2 How-to] #5 - ROS2 Topics vs Services vs Actions - Simulation
[ROS2 How-to] #5 – ROS2 Topics vs Services vs Actions – Simulation
ROS2 Topics
Topics are the channel of communication between a Publisher node and a Subscriber node.
Let’s see an example of ROS2 Topics.
Let’s open a second terminal and run the following command:
ros2 topic pub /cmd_vel geometry_msgs/msg/Twist "{linear: {x: 0.2, y: 0.0, z: 0.0}, angular: {x: 0.0, y: 0.0, z: 0.0}}" -1
The above command will command the robot to drive with a forward velocity of 0.2 m/s.
We can now create a subscriber to the /odom topic in a third terminal with the command below:
ros2 topic echo /odom
You should see odometry messages published to the /odom topic in the console
Many messages will start coming. You can stop the subscriber by pressing CTRL+C in the terminal where you launched it.
To stop the robot, we can use the command below in the second terminal:
ros2 topic pub /cmd_vel geometry_msgs/msg/Twist "{linear: {x: 0.0, y: 0.0, z: 0.0}, angular: {x: 0.0, y: 0.0, z: 0.0}}" -1
When should you use a topic?
Topics are used for one-way communication. The publisher just sends messages, and the subscriber just “listen” to the messages being published.
Topics are useful when you need to react quickly, and useful also if you want to publish updates at a high frequency, like the values of the /odom topic, used to determine the position of the robot.
You can use topics to change the speed of a robot, for example, to accelerate or reduce its speed.
We could say that it is mostly used for real-time communication.
Topics provide a continuous flow of data, and can be used for one-to-many and many-to-many communications, which means you can have many publishers  publishing on a given topic, and many subscribers subscribed to a given topic.
ROS2 Services
ROS2 Services allow connections between a Service Client and a Service Server. It’s used basically for “instant questions and answers“, like “retrieving the current time“, for example, or “getting the current battery state” of the robot.
Let’s create a Service Server using the following commands in the second terminal:
ros2 run services_pkg service
Now that the service server is created, let’s create the Service Client in the third terminal, that sends a request to the Service Server:
ros2 service call /moving std_srvs/srv/Empty
If everything went well, the robot should have started moving in circles.
To stop the robot, we can make use of ROS2 Topic again, just like we did in the previous section, by running the command below:
If we want to make the robot move to its initial position (reset the simulation), we can call the following service:
ros2 service call /reset_simulation std_srvs/srv/Empty
You can also call a service to get the list of models in the gazebo world:
ros2 service call /get_model_list gazebo_msgs/srv/GetModelList "{}"
When should you use a ROS2 Service?
ROS2 Services could be used ideally when the number of data requests is really small, especially if compared with ROS2 Topics.
With ROS2 Services, you have a request and a response, so, it is useful for communication that happens quickly.
ROS2 Actions
Somehow similar to ROS2 Services, for ROS2 Actions we need a server and a client. In this case, it would be an Action Server node and the Action Client node.
ROS2 Actions are more indicated for situations where you give a task to the robot, and you are not going to be there waiting until the task has finished. You could do other things while the robot is doing his work. An example of an action would be: Robot, please clean the house. You just give it a task, you don’t know when the task is going to finish, but you can have constant feedback on how the task is going.
Let’s start an action server, by running the following command in the second terminal:
ros2 launch turtlebot3_as action_server.launch.py
Now, in the third terminal, let’s send the goal to the Action Service:
ros2 action send_goal /turtlebot3_as t3_action_msg/action/Move "{secs: 20}"
Now, the robot will be moving for 20 seconds, but the Client used to send the goal has finished “instantly”. The terminal does not have to be stuck for 20 seconds until the robot finishes its task.
When should you use ROS2 Actions?
The ideal scenario when ROS2 Actions could be used is when the task takes several seconds to complete or minutes to complete.
ROS Actions are used mainly for the processing of longer tasks in the background.
Use it also for operations that might me terminated or canceled before completion.
Congratulations. You have just learned when to use Topics, Services, and Actions. We hope this post was really helpful to you. If you want a live version of this post, please check the video in the next section.
