In order to install the cv_camera driver, the first thing you have to do is to connect to your real robot.
If you are reading this tutorial, then we assume you already know how to connect to your own robot using SSH.
After you have connected, you can install the cv_camera package either by directly compiling the https://github.com/OTL/cv_camera package or by using apt-get, which is what we are going to do.
Important things about the cv_camera package:
It publishes the images on the ~image_raw topic (sensor_msgs/Image)
It uses camera as the default value of the ~frame_id parameter.
Ok, let’s finally install the cv_camera package. The commands would be the following:
If it works, then create a launch file for the node and also a static transform publisher from base_link to camera_link, indicating the approximate distance to where you end up placing your camera. The file would look something like this:
After launching the launch file we just created, using roslaunch your_package_name_here your_launch_file.launch, you should be able to list the topics by using rostopic list. Among other topics, the output of rostopic list should show the following topic:
/cv_camera
If you now open RViz, you should be able to see the camera.
If you want a step-by-step walk-through of the instructions above, you can check out this video below.
In order to learn how to spawn many robots in ROS2, we need to have ROS installed. We already prepared a rosject ready for that: https://app.theconstructsim.com/#/l/47f74f81/. You can download the rosject on your own computer if you want to work locally, but just by copying the rosject (clicking the link above), you will have a setup already prepared for you.
RUN rosject – Multiple Box Bot in ROS2
Setting up our environment to use purely ROS2 Foxy
On The Construct, when you open the rosject, the system will have ROS1 Noetic and ROS2 Foxy installed.
Let’s start by making our system able to compile purely with ROS2. For that, let’s first open a terminal:
After opening the terminal, let’s now override the default ~/.bash_aliases to remove some ROS1-related settings :
After having replaced the ~/.bash_aliases file, please close the terminal window and open a totally new one, in order to make sure you will have ROS2 setup.
After that, you should be able to type now the command:
whoistheboss
Compiling our ~/ros2_ws and launching the simulation
Before launching the simulation, let’s first compile our box_bot_description package with ROS2. Let’s open a terminal and run the following commands:
cd
cd ros2_ws/
rm -rf build install log
colcon build --symlink-install --packages-select box_bot_gazebo box_bot_description
Now that our box_bot_description package is compiled, let’s run it with the following commands:
Now that the robots have been spawned, you can click the Open Gazebo to see the 10 robots that were spawned:
Click Open Gazebo to see the 10 robots spawned
Making sure the robots are each under their own namespace
To make sure our robots are each one under a specific namespace, one namespace for each robot, let’s list the topics in another terminal by running ros2 topic list:
Here you can see that we really have each robot under a different namespace.
Moving robots independently
We see that we have namespaces going from 0 to 9
In order to run a specific robot, let’s say the robot under the namespace box_bot9 , we can do it by running the following command:
ros2 run teleop_twist_keyboard teleop_twist_keyboard --ros-args --remap cmd_vel:=/box_bot9/cmd_vel
In this command, we are basically running the teleop_twist_keyboard, and remapping the cmd_vel topic to /box_bot9/cmd_vel. This way, we are moving the 10th robot. You can control different robots just by replacing box_bot9 with box_bot3 or box_bot7, for example.
If everything went well, you should see the following:
This node takes keypresses from the keyboard and publishes them
as Twist messages. It works best with a US keyboard layout.
Moving around:
u i o
j k l
m , .
For Holonomic mode (strafing), hold down the shift key:
U I O
J K L
M < >
t : up (+z)
b : down (-z)
anything else : stop
q/z : increase/decrease max speeds by 10%
w/x : increase/decrease only linear speed by 10%
e/c : increase/decrease only angular speed by 10%
CTRL-C to quit
By pressing the keys “i“, “o“, “k“, you can see in Gazebo that a specific robot will be moving around.
Understanding how the multiples robots are spawned
You may be wondering how the spawn configuration actually worked.
For that, you can have a look at the following file:
ls ~/ros2_ws/src/box_bot/box_bot_description/launch/multi_spawn_robot_launch.py
You can for sure see the file in the Code Editor. For that, just open the File Editor and open that multi_spawn_robot_launch.py file.
Open the IDE – Code Editor
The many robots are created basically in the gen_robots_list function.
Congratulations. You now know how to spawn many robots under different namespaces using ROS2.
In this series, we are going to explain how to add elements to RViz2. We will start with TF, then we will continue with Robots Description, then Cameras, PointClouds, Lasers, and so on.
In this first post, we are going to see how to add TFs in RViz2.
In order to learn how to add TFs in RViz2, we need to have ROS installed. We already prepared a rosject ready for that: https://app.theconstructsim.com/#/l/47f74f81/. You can download the rosject on your own computer if you want to work locally, but just by copying the rosject (clicking the link), you will have a setup already prepared for you.
Run rosject: RVIZ2 Tutorials Episode1: TF
Running the rosject
After you have clicked the Run button, the rosject should load and you should see a notebook that is open automatically:
Notebook – Run rosject: RVIZ2 Tutorials Episode1: TF
The notebook contains the instructions to launch a simulation.
Launching the BOX_BOT simulation
In order to launch the simulation, let’s start by opening a new terminal:
After having the first terminal open, let’s run the following commands to launch a simulation:
The commands we just executed only launch the world, but there is no robot on it yet.
Now, in a second terminal, let’s spawn the robot with the commands below:
cd ~/ros2_ws/
ros2 launch box_bot_gazebo spawn_robot_ros2.launch.py
Now that the robot has been successfully spawned, let’s now open RViz2. For that, let’s run the following commands in a third terminal.
cd ~/ros2_ws/
rviz2
See the simulation
In order to see the simulation, you can click on the Open Gazebo button:
Open Gazebo by clicking Open Gazebo
Click Open Gazebo to view the Gazebo simulation
The final image you get should be similar to the following:
Open Gazebo – RVIZ2 Tutorials Episode1 TF
See rviz2 in the Graphical Tools
In order to see rviz2 (RViz2), you have to click the Open Graphical Tools button, in case the graphical window did not open automatically:
Open Graphical Tools / rviz
Now that you can see rviz2, let’s set the fixed frame on the top left to /odom (Odometry), then let’s click the Add button on the bottom left and add a TF.
Once TF is added, let’s disable the “All Enabled” option to avoid getting confused with all those TFs that are shown. Let’s shown only specific frames: chassis, left_wheel, odom, right_wheel. In the end, our rviz2 should look similar to the following:
Specific Frames – RVIZ2 Tutorials Episode1_ TF 3
We must also click Show Names to show the frame names in RViz2.
Moving the robot with teleop
In order to see the frames of the robot moving in rviz2, let’s run the Keyboard Teleop in a fourth terminal using the following commands:
cd ~/ros2_ws/
If you now press the keys to move the robot around, you should be able to see the robot moving in the simulation, and you should also see the TFs moving in RViz2.
Moving the robot with teleop – Specific Frames – RVIZ2 Tutorials Episode1 TF
Connecting to a real robot
In order to see the TFs of a real robot, let’s click on the Real Robot Lab button that is available when you are not on the “Desktop” page of The Construct. After clicking Real Robot Lab, please select a robot and click Book Now. It’s free.
Real Robot Lab – Make a reservation
When you have the robot available for you, open the rosject and click on the button to connect to the real robot.
Connecting to the Real Robot Lab
After the connection is successfully established, you should have something similar to the following:
Real Robot Lab connected
Launch ros1_bridge
Before loading ros1_bridge, let’s load the parameters that we want to do the bridge.
Open a terminal and type the following:
roslaunch load_params load_params.launch
The command above loads basically the instructions saying: Hey, ros1, publish these specific topics because I want them to be available on ROS2.
Now, let’s run the parameter_bridge in a second terminal:
cd ~/ros2_ws/
ros2 run ros1_bridge parameter_bridge
Now that ros1_bridge is running, we should be able to easily see ros2 topics in a third terminal:
cd ~/ros2_ws/
ros2 topic list
You should see some topics listed, and the one we are most interested in today is the /tf topic.
If we now just open rviz2:
rviz2
we should now do the same procedure that we did previously, in order to see the TF data in RViz. Please refer to the section See rviz2 in the Graphical Tools already explained above (set /odom as the Fixed frame, and add the TF panel).
Moving the robot with ROS1
Now that we are connected to our robot and we have RViz2 setup ready, we can move the robot either with ROS1 or ROS2.
Let’s move it with ROS1, by running the following commands in a fourth terminal:
If you now move the robot by following the instructions, you should see the reflections in the camera of the Real Robot, and also in the RViz2:
Seeing real robot TFs in RVIZ2
Congratulations. You now know how to see TF data in RViz2.
This post tries to answer the following question: ROS1 vs ROS2: Which one is the best for launching faster a better product?
The post is an intro to the webinar where we discussed which version of ROS to use (ROS1 or ROS2) for your next robotics product.
We analyzed the question from the point of view of a company that wants to deliver a professional product, not from the point of view of a ROS Developer.
Use ROS1: if your product is going to be released before the end of 2021
Use ROS2: if you plan to release your product after 2021
Longer answer (Using ROS1)
The reason why ROS1 may be a good choice for you is that ROS1 is already really mature, which allows you to move really fast since it has a ton of mature features ready to use.
The ideal would be: You make the robot available with ROS1, check if it is successful. If that is the case, you can always make a transition from ROS1 to ROS2 in the next years, once you know from the market that your product is something valid.
Longer answer (Using ROS2)
If you are planning to release your product after 2021, go and take ROS2.
The reason why you should ideally start already with ROS2 is that ROS2 is the future of ROS, therefore, the future of robotics. Your robot will already be ready for what is coming for the next years.
ROS1 vs ROS2 Evaluation Questions for Companies
If you want to know the answers for deeper ROS-related important questions for companies, like the ones below:
Which ROS version has all the technical requirements that my product needs?
Important things you have to know before starting with ROS2:
Doing everything in ROS2 is going to be a little more difficult than if you were to do with ROS1. You will need more time to do anything in ROS2.
The reason is the same already explained: ROS1 is more mature, so, it is very likely that whatever you want to do in ROS1, someone may have already done it, therefore, you don’t have to reinvent the wheel, whereas in ROS2, is less likely to have everything that you need already implemented.
In order to learn how to see data coming from ROSBags in ros2 depth camera data, we need to have ROS installed. We already prepared a rosject ready for that: https://app.theconstructsim.com/#/l/4733ef97/. You can download the rosject on your own computer if you prefer to work locally.
If you want to create your own rosject instead of using the link we just provided, you can do it also. We are going to use The Construct (https://www.theconstruct.ai/) for this tutorial, but if you have ROS2 installed on your own computer, you should be able to do ~everything on your own computer, except this creating a rosject part.
Once inside, let’s create My Rosjects and then, Create a new rosject if you decided taking this route:
My Rosjects
For the rosject, let’s select ROS2 Foxyfor the ROS Distro, let’s name the rosject as you want. You can leave the rosject public. You should see the rosject you just created in your rosjects list (the name is certainly different from the example below that was added just for learning purposes)
List of rosjects – Using Depth camera in ROS2 to determine object distance
Launching the laser_scan_assember server to convert from laser scan to point cloud
Assuming you have a copy of the rosject, after opening it by clicking the Run button mentioned earlier, let’s open the IDE (Code Editor) to see its content.
You should see a rosbag file named 2022-01-17-11-40-32.bag, which is a rosbag for the turtlebot simulation.
In order to launch the laser_scan_assembler, we need a launch file. If you check carefully, you may notice that we already have a launch file under the path ~/catkin_ws/src/laser_assembler_demo/launch/assembler.launch.
So, in order to record all topics in a rosbag file, you can just run the rosbag record -a command. You can press CTRL+C to stop recording, or youcan also especify the –duration param if you want to record only for a few seconds or minutes (because rosbag files grow really fast):
rosbag record -a --duration=1m
The logs should be similar to the following:
[ INFO] [1643640738.398965449, 298.390000000]: Recording to '2022-01-31-14-52-18.bag'.
[ INFO] [1643640738.402667915, 298.395000000]: Subscribing to /rosout_agg
[ INFO] [1643640738.408196688, 298.402000000]: Subscribing to /rosout
[ INFO] [1643640738.417414694, 298.406000000]: Subscribing to /clock
[ INFO] [1643640738.492442317, 298.422000000]: Subscribing to /gazebo/link_states
[ INFO] [1643640738.511223062, 298.468000000]: Subscribing to /gazebo/model_states
[ INFO] [1643640738.518154757, 298.481000000]: Subscribing to /gazebo/performance_metrics
[ INFO] [1643640738.526057506, 298.488000000]: Subscribing to /gazebo/parameter_descriptions
[ INFO] [1643640738.598167676, 298.535000000]: Subscribing to /gazebo/parameter_updates
[ INFO] [1643640738.784914410, 298.633000000]: Subscribing to /scan
[ INFO] [1643640738.795856579, 298.650000000]: Subscribing to /joint_states
[ INFO] [1643640738.806535006, 298.665000000]: Subscribing to /tf
[ INFO] [1643640738.817849095, 298.673000000]: Subscribing to /odom
[ INFO] [1643640738.901146360, 298.732000000]: Subscribing to /imu
Let’s use the rosbag file that already exists, called 2022-01-17-11-40-32.bag.
Playing a rosbag file
Now that we have learned how to record a rosbag file, let’s play the one that we already had, called 2022-01-17-11-40-32.bag.
Before that, let’s kill the simulation we launched previously (pressing CTRL+C in the terminal where we launched the simulation).
If we now check the topics again, we should have only the following 3 topics:
rostopic list
/clock
/rosout_agg
Let’s first start roscore:
roscore &
If you wait about ~5 seconds, roscore will be running. After that, we can run rosbag:
rosbag play 2022-01-17-11-40-32.bag
The output would be similar to the following:
setting /run_id to 5cbe4c68-82c9-11ec-bbc7-0242c0a86007
[ INFO] [1643656195.261386757]: Connected to master at [1_xterm:11311]
[ INFO] [1643656195.265748530]: Opening 2022-01-17-11-40-32.bag
process[rosout-1]: started with pid [1430]
Waiting 0.2 seconds after advertising topics... done.
Hit space to toggle paused, or 's' to step.
[RUNNING] Bag Time: 345.418104 Duration: 13.739104 / 70.197000
If we now check the topics again in another terminal, we will have the topics listed again:
You can now kill the rosbag play process, now that you learned how to play it and how it works.
Let’s start by opening 6 terminals. If you want, you can name them like the names below to easily know what each terminal is doing:
1 – roscore
2 – rosbag
3 – assembler
4 – call_assembler
5 – bridge
6 – rviz2
In the end, you would have something like the following image:
How to work with rosbags and laser_assembler in ROS2 14-36
Let’s launch roscore in the first terminal (named roscore) if you have killed it:
roscore
Now let’s run rosbag play in the second terminal:
while true; do rosbag play 2022-01-17-11-40-32.bag; sleep 1; done
The reason why we are running inside a while loop is because it finishes after ~70 seconds, which is the duration of the rosbag file. By being inside the while loop, it keeps running “forever” until we stop it with CTRL+C.
Now in the third terminal, let’s run the laser assembler:
Still in the 4th terminal, we can now run the node used to call the assembler:
rosrun laser_assembler_demo call_assembler.py
The output you should get must be similar to the following:
Got cloud with 2592000 points
Everything so far was running in ROS1. Let’s now run ros1_bridge in the 5th terminal to be able to see the topics in ROS2.
ros2 run ros1_bridge dynamic_bridge --bridge-all-topics
Among other text output, you should see the following:
created 1to2 bridge for topic '/clock' with ROS 1 type 'rosgraph_msgs/Clock' and ROS 2 type 'rosgraph_msgs/msg/Clock'
created 1to2 bridge for topic '/gazebo/link_states' with ROS 1 type 'gazebo_msgs/LinkStates' and ROS 2 type 'gazebo_msgs/msg/LinkStates'
created 1to2 bridge for topic '/gazebo/model_states' with ROS 1 type 'gazebo_msgs/ModelStates' and ROS 2 type 'gazebo_msgs/msg/ModelStates'
created 1to2 bridge for topic '/imu' with ROS 1 type 'sensor_msgs/Imu' and ROS 2 type 'sensor_msgs/msg/Imu'
created 1to2 bridge for topic '/joint_states' with ROS 1 type 'sensor_msgs/JointState' and ROS 2 type 'sensor_msgs/msg/JointState'
created 1to2 bridge for topic '/laser_pointcloud' with ROS 1 type 'sensor_msgs/PointCloud2' and ROS 2 type 'sensor_msgs/msg/PointCloud2'
created 1to2 bridge for topic '/odom' with ROS 1 type 'nav_msgs/Odometry' and ROS 2 type 'nav_msgs/msg/Odometry'
created 1to2 bridge for topic '/rosout' with ROS 1 type 'rosgraph_msgs/Log' and ROS 2 type 'rcl_interfaces/msg/Log'
created 1to2 bridge for topic '/rosout_agg' with ROS 1 type 'rosgraph_msgs/Log' and ROS 2 type 'rcl_interfaces/msg/Log'
created 1to2 bridge for topic '/scan' with ROS 1 type 'sensor_msgs/LaserScan' and ROS 2 type 'sensor_msgs/msg/LaserScan'
created 1to2 bridge for topic '/tf' with ROS 1 type 'tf2_msgs/TFMessage' and ROS 2 type 'tf2_msgs/msg/TFMessage'
created 1to2 bridge for topic '/tf_static' with ROS 1 type 'tf2_msgs/TFMessage' and ROS 2 type 'tf2_msgs/msg/TFMessage
Now, let’s launch rviz2 in the 6th terminal:
rviz2
If you now open the Graphical Tools, you should be able to see rviz:
Once you have opened the Graphical Tools, let’s change the Fixed Frame in rviz2 to /base_footprint instead of /map.
Let’s also click Add (in the left bottom of rviz2) and select a Point Cloud2. After the PointCloud2 was added, let’s select the topic /laser_pointcloud (as defined on ~/catkin_ws/src/laser_assembler_demo/src/call_assembler.py):
Now, you should be able to see the laser being shown in rviz2 (in red).
Laser Pointcloud being output in rviz2 with ros1_bridge
Congratulations. You now know how to work with rosbags and laser_assembler in ROS2.
Once inside, let’s create My Rosjects and then, Create a new rosject if you decided decided taking this route:
My Rosjects
Starting a simulation
In order to launch a simulation, let’s start by opening a new terminal:
We can actually open 3 terminals (just by clicking the plus “+” button that appears besides the number #569 in the image above).
At the moment there are not a lot of simulations that include depth cameras for ros2, therefore, we are going to use ros1 to launch a simulation, then use ros1_bridge to make the topics available in ros2.
After having the terminals open, let’s source ros1 noetic in the first terminal, and also source the workspace that contains the simulation:
The simulation should have been launched. You can ignore some error messages that appear for the moment. The logs should be something similar to the following:
Checking log directory for disk usage. This may take a while.
Press Ctrl-C to interrupt
xacro: in-order processing became default in ROS Melodic. You can drop the option.
started roslaunch server http://4_xterm:32787/
SUMMARY
PARAMETERS
* /gazebo/enable_ros_network: True
* /gripper_controller/joint: egh_gripper_finge...
* /gripper_controller/type: position_controll...
* /joint_group_position_controller/joints: ['shoulder_pan_jo...
* /joint_group_position_controller/type: position_controll...
* /joint_state_controller/publish_rate: 50
* /joint_state_controller/type: joint_state_contr...
* /robot_description: <?xml version="1....
* /robot_state_publisher/publish_frequency: 50.0
* /robot_state_publisher/tf_prefix:
* /rosdistro: noetic
* /rosversion: 1.15.11
* /scaled_pos_joint_traj_controller/action_monitor_rate: 10
* /scaled_pos_joint_traj_controller/constraints/elbow_joint/goal: 0.1
* /scaled_pos_joint_traj_controller/constraints/elbow_joint/trajectory: 0.1
* /scaled_pos_joint_traj_controller/constraints/goal_time: 0.6
* /scaled_pos_joint_traj_controller/constraints/shoulder_lift_joint/goal: 0.1
* /scaled_pos_joint_traj_controller/constraints/shoulder_lift_joint/trajectory: 0.1
* /scaled_pos_joint_traj_controller/constraints/shoulder_pan_joint/goal: 0.1
* /scaled_pos_joint_traj_controller/constraints/shoulder_pan_joint/trajectory: 0.1
* /scaled_pos_joint_traj_controller/constraints/stopped_velocity_tolerance: 0.05
* /scaled_pos_joint_traj_controller/constraints/wrist_1_joint/goal: 0.1
* /scaled_pos_joint_traj_controller/constraints/wrist_1_joint/trajectory: 0.1
* /scaled_pos_joint_traj_controller/constraints/wrist_2_joint/goal: 0.1
* /scaled_pos_joint_traj_controller/constraints/wrist_2_joint/trajectory: 0.1
* /scaled_pos_joint_traj_controller/constraints/wrist_3_joint/goal: 0.1
* /scaled_pos_joint_traj_controller/constraints/wrist_3_joint/trajectory: 0.1
* /scaled_pos_joint_traj_controller/joints: ['shoulder_pan_jo...
* /scaled_pos_joint_traj_controller/state_publish_rate: 25
* /scaled_pos_joint_traj_controller/stop_trajectory_duration: 0.5
* /scaled_pos_joint_traj_controller/type: position_controll...
* /use_sim_time: True
NODES
arm_controller_spawner (controller_manager/controller_manager)
controller_spawner_gripper (controller_manager/spawner)
fake_joint_calibration (rostopic/rostopic)
gazebo (gazebo_ros/gzserver)
gazebo_gui (gazebo_ros/gzclient)
joint_state_controller_spawner (controller_manager/controller_manager)
robot_state_publisher (robot_state_publisher/robot_state_publisher)
ros_control_controller_manager (controller_manager/controller_manager)
spawn_gazebo_model (gazebo_ros/spawn_model)
auto-starting new master
process[master]: started with pid [3700]
ROS_MASTER_URI=http://4_xterm:11311
setting /run_id to 0e52b568-6cd6-11ec-9dc4-0242ac1b0007
process[rosout-1]: started with pid [3719]
process[gazebo-2]: started with pid [3722]
process[gazebo_gui-3]: started with pid [3724]
process[spawn_gazebo_model-4]: started with pid [3729]
process[robot_state_publisher-5]: started with pid [3733]
process[fake_joint_calibration-6]: started with pid [3741]
process[joint_state_controller_spawner-7]: started with pid [3742]
process[arm_controller_spawner-8]: started with pid [3747]
process[controller_spawner_gripper-9]: started with pid [3748]
process[ros_control_controller_manager-10]: started with pid [3749]
++ ls /usr/bin/gzclient-11.5.1
+ gzclient_path=/usr/bin/gzclient-11.5.1
+ DISPLAY=:2
+ /usr/bin/gzclient-11.5.1 -g /opt/ros/noetic/lib/libgazebo_ros_paths_plugin.so -g /opt/ros/noetic/lib/libgazebo_ros_api_plugin.so __name:=gazebo_gui __log:=/home/user/.ros/log/0e52b568-6cd6-11ec-9dc4-0242ac1b0007/gazebo_gui-3.log
INFO: cannot create a symlink to latest log directory: [Errno 2] No such file or directory: '/home/user/.ros/log/latest'
[INFO] [1641242725.661746, 0.000000]: Controller Spawner: Waiting for service controller_manager/load_controller
[INFO] [1641242725.761337, 0.000000]: Loading model XML from ros parameter robot_description
[INFO] [1641242725.768781, 0.000000]: Waiting for service /gazebo/spawn_urdf_model
Gazebo multi-robot simulator, version 11.5.1
Copyright (C) 2012 Open Source Robotics Foundation.
Released under the Apache 2 License.
http://gazebosim.org
[ INFO] [1641242726.627685197]: Finished loading Gazebo ROS API Plugin.
[ INFO] [1641242726.629782039]: waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting...
[Msg] Waiting for master.
[Msg] Connected to gazebo master @ http://172.27.0.7:11345
[Msg] Publicized address: 172.27.0.7
[ INFO] [1641242726.738771830]: Finished loading Gazebo ROS API Plugin.
[ INFO] [1641242726.742342582]: waitForService: Service [/gazebo_gui/set_physics_properties] has not been advertised, waiting...
[Msg] Loading world file [/usr/share/gazebo-11/worlds/empty.world]
[ INFO] [1641242727.138178149]: waitForService: Service [/gazebo/set_physics_properties] is now available.
[ INFO] [1641242727.244679729, 0.048000000]: Physics dynamic reconfigure ready.
[INFO] [1641242727.280947, 0.088000]: Calling service /gazebo/spawn_urdf_model
[INFO] [1641242727.537885, 0.104000]: Spawn status: SpawnModel: Successfully spawned entity
[spawn_gazebo_model-4] process has finished cleanly
log file: /home/user/.ros/log/0e52b568-6cd6-11ec-9dc4-0242ac1b0007/spawn_gazebo_model-4*.log
[ INFO] [1641242729.504743470, 0.104000000]: Camera Plugin: Using the 'robotNamespace' param: '/'
[ INFO] [1641242729.513059783, 0.104000000]: Camera Plugin (ns = /) <tf_prefix_>, set to ""
[ INFO] [1641242730.186888511, 0.104000000]: Loading gazebo_ros_control plugin
[ INFO] [1641242730.187188566, 0.104000000]: Starting gazebo_ros_control plugin in namespace: /
[ INFO] [1641242730.188738334, 0.104000000]: gazebo_ros_control plugin is waiting for model URDF in parameter [robot_description] on the ROS param server.
[ERROR] [1641242730.480595227, 0.104000000]: No p gain specified for pid. Namespace: /gazebo_ros_control/pid_gains/shoulder_pan_joint
[ERROR] [1641242730.482573352, 0.104000000]: No p gain specified for pid. Namespace: /gazebo_ros_control/pid_gains/shoulder_lift_joint
[ERROR] [1641242730.483960993, 0.104000000]: No p gain specified for pid. Namespace: /gazebo_ros_control/pid_gains/elbow_joint
[ERROR] [1641242730.485373065, 0.104000000]: No p gain specified for pid. Namespace: /gazebo_ros_control/pid_gains/wrist_1_joint
[ERROR] [1641242730.486771098, 0.104000000]: No p gain specified for pid. Namespace: /gazebo_ros_control/pid_gains/wrist_2_joint
[ERROR] [1641242730.488209294, 0.104000000]: No p gain specified for pid. Namespace: /gazebo_ros_control/pid_gains/wrist_3_joint
[ERROR] [1641242730.489539274, 0.104000000]: No p gain specified for pid. Namespace: /gazebo_ros_control/pid_gains/egh_gripper_finger_left_joint
[ INFO] [1641242730.503064828, 0.104000000]: Loaded gazebo_ros_control.
[ INFO] [1641242730.514695030, 0.104000000]: MimicJointPlugin loaded! Joint: "egh_gripper_finger_left_joint", Mimic joint: "egh_gripper_finger_right_joint", Multiplier: 1, Offset: 0, MaxEffort: 200, Sensitiveness: 0
[Msg] Loading grasp-fix plugin
[Msg] GazeboGraspFix: Using disable_collisions_on_attach 0
[Msg] GazeboGraspFix: Using update rate 10
[Msg] GazeboGraspFix: Using max_grip_count 10
[Msg] GazeboGraspFix: Using grip_count_threshold 3
[Msg] GazeboGraspFix: Using release_tolerance 0.001
[Msg] GazeboGraspFix: Adding collision scoped name robot::egh_gripper_left_finger::egh_gripper_left_finger_collision
[Msg] GazeboGraspFix: Adding collision scoped name robot::egh_gripper_right_finger::egh_gripper_right_finger_collision
[Msg] Subscribing contact manager to topic ~/robot/contacts
[Msg] Advertising grasping events on topic grasp_events
[Wrn] [Publisher.cc:136] Queue limit reached for topic /gazebo/default/pose/local/info, deleting message. This warning is printed only once.
[INFO] [1641242730.834305, 0.401000]: Controller Spawner: Waiting for service controller_manager/switch_controller
[INFO] [1641242730.842565, 0.415000]: Controller Spawner: Waiting for service controller_manager/unload_controller
[INFO] [1641242730.846773, 0.422000]: Loading controller: gripper_controller
Loaded 'joint_state_controller'
[ERROR] [1641242731.068522252, 0.634000000]: Could not load controller 'arm_controller' because the type was not specified. Did you load the controller configuration on the parameter server (namespace: '/arm_controller')?
Error when loading 'arm_controller'
Loaded 'joint_group_position_controller'
[INFO] [1641242731.563780, 1.066000]: Controller Spawner: Loaded controllers: gripper_controller
[ERROR] [1641242731.564298128, 1.067000000]: Could not start controller with name 'arm_controller' because no controller with this name exists
Started ['joint_state_controller'] successfully
Error when starting ['arm_controller'] and stopping []
[INFO] [1641242731.573472, 1.076000]: Started controllers: gripper_controller
You can now click Open Gazebo to see the simulation:
Click Open Gazebo to see the ur3 simulation with depth camera
We are most interested in the depth camera that we can see inside a red box in the image above.
That camera has a normal rgb camera and a depth camera that can be used to detect distance.
Launching ros1_bridge
Now that we have the simulation running in ros1, let’s start ros1_bridge so that we can interact with the topics using ros2.
For that, let’s run the following command (in this order, first ros1, then ros2) in the second terminal to source ros:
The output should be similar to:
created 1to2 bridge for topic '/calibrated' with ROS 1 type 'std_msgs/Bool' and ROS 2type 'std_msgs/msg/Bool'
created 1to2 bridge for topic '/gripper_controller/gripper_cmd/status' with ROS 1 type 'actionlib_msgs/GoalStatusArray' and ROS 2 type 'actionlib_msgs/msg/GoalStatusArray'
created 1to2 bridge for topic '/rosout' with ROS 1 type 'rosgraph_msgs/Log' and ROS 2type 'rcl_interfaces/msg/Log'
created 1to2 bridge for topic '/tf_static' with ROS 1 type 'tf2_msgs/TFMessage' and ROS 2 type 'tf2_msgs/msg/TFMessage'
created 1to2 bridge for topic '/wrist_rgbd/depth/camera_info' with ROS 1 type 'sensor_msgs/CameraInfo' and ROS 2 type 'sensor_msgs/msg/CameraInfo'
created 1to2 bridge for topic '/wrist_rgbd/depth/image_raw' with ROS 1 type 'sensor_msgs/Image' and ROS 2 type 'sensor_msgs/msg/Image'
created 1to2 bridge for topic '/wrist_rgbd/depth/points' with ROS 1 type 'sensor_msgs/PointCloud2' and ROS 2 type 'sensor_msgs/msg/PointCloud2'
created 1to2 bridge for topic '/wrist_rgbd/rgb/camera_info' with ROS 1 type 'sensor_msgs/CameraInfo' and ROS 2 type 'sensor_msgs/msg/CameraInfo'
created 1to2 bridge for topic '/wrist_rgbd/rgb/image_raw' with ROS 1 type 'sensor_msgs/Image' and ROS 2 type 'sensor_msgs/msg/Image'
created 1to2 bridge for topic '/wrist_rgbd/rgb/image_raw/compressed' with ROS 1 type 'sensor_msgs/CompressedImage' and ROS 2 type 'sensor_msgs/msg/CompressedImage'
created 1to2 bridge for topic '/wrist_rgbd/rgb/image_raw/compressedDepth' with ROS 1 type 'sensor_msgs/CompressedImage' and ROS 2 type 'sensor_msgs/msg/CompressedImage'
Created 2 to 1 bridge for service /gazebo/clear_body_wrenches
Created 2 to 1 bridge for service /gazebo/clear_joint_forces
Created 2 to 1 bridge for service /gazebo/delete_light
Created 2 to 1 bridge for service /gazebo/delete_model
Created 2 to 1 bridge for service /gazebo/get_joint_properties
Created 2 to 1 bridge for service /gazebo/get_light_properties
Created 2 to 1 bridge for service /gazebo/get_link_properties
Created 2 to 1 bridge for service /gazebo/get_link_state
Created 2 to 1 bridge for service /gazebo/get_model_properties
Created 2 to 1 bridge for service /gazebo/get_model_state
Created 2 to 1 bridge for service /gazebo/get_physics_properties
Created 2 to 1 bridge for service /gazebo/get_world_properties
Created 2 to 1 bridge for service /gazebo/pause_physics
Created 2 to 1 bridge for service /gazebo/reset_simulation
Created 2 to 1 bridge for service /gazebo/reset_world
Created 2 to 1 bridge for service /gazebo/set_joint_properties
Created 2 to 1 bridge for service /gazebo/set_link_properties
Created 2 to 1 bridge for service /gazebo/set_link_state
Created 2 to 1 bridge for service /gazebo/set_model_configuration
Created 2 to 1 bridge for service /gazebo/set_model_state
Created 2 to 1 bridge for service /gazebo/set_physics_properties
Created 2 to 1 bridge for service /gazebo/spawn_sdf_model
Created 2 to 1 bridge for service /gazebo/spawn_urdf_model
Created 2 to 1 bridge for service /gazebo/unpause_physics
Created 2 to 1 bridge for service /wrist_rgbd/set_camera_info
[INFO] [1641243318.565086017] [ros_bridge]: Passing message from ROS 1 std_msgs/Bool to ROS 2 std_msgs/msg/Bool (showing msg only once per type)
[INFO] [1641243318.565407501] [ros_bridge]: Passing message from ROS 1 rosgraph_msgs/Clock to ROS 2 rosgraph_msgs/msg/Clock (showing msg only once per type)
[INFO] [1641243318.634712568] [ros_bridge]: Passing message from ROS 1 gazebo_msgs/LinkStates to ROS 2 gazebo_msgs/msg/LinkStates (showing msg only once per type)
[INFO] [1641243318.636128359] [ros_bridge]: Passing message from ROS 1 gazebo_msgs/ModelStates to ROS 2 gazebo_msgs/msg/ModelStates (showing msg only once per type)
[INFO] [1641243318.636843101] [ros_bridge]: Passing message from ROS 1 actionlib_msgs/GoalStatusArray to ROS 2 actionlib_msgs/msg/GoalStatusArray (showing msg only once per type)
[INFO] [1641243318.637282514] [ros_bridge]: Passing message from ROS 1 sensor_msgs/JointState to ROS 2 sensor_msgs/msg/JointState (showing msg only once per type)
[INFO] [1641243318.637751048] [ros_bridge]: Passing message from ROS 1 rosgraph_msgs/Log to ROS 2 rcl_interfaces/msg/Log (showing msg only once per type)
[INFO] [1641243318.638771467] [ros_bridge]: Passing message from ROS 1 tf2_msgs/TFMessage to ROS 2 tf2_msgs/msg/TFMessage (showing msg only once per type)
created 2to1 bridge for topic '/calibrated' with ROS 2 type 'std_msgs/msg/Bool' and ROS 1 type 'std_msgs/Bool'
created 2to1 bridge for topic '/rosout' with ROS 2 type 'rcl_interfaces/msg/Log' and ROS 1 type 'rosgraph_msgs/Log'
removed 2to1 bridge for topic '/calibrated'
[INFO] [1641243320.970126882] [ros_bridge]: Passing message from ROS 1 sensor_msgs/Image to ROS 2 sensor_msgs/msg/Image (showing msg only once per type)
[INFO] [1641243320.971249839] [ros_bridge]: Passing message from ROS 1 sensor_msgs/CameraInfo to ROS 2 sensor_msgs/msg/CameraInfo (showing msg only once per type)
[INFO] [1641243321.032322768] [ros_bridge]: Passing message from ROS 2 rcl_interfaces/msg/Log to ROS 1 rosgraph_msgs/Log (showing msg only once per type)
[INFO] [1641243321.057171155] [ros_bridge]: Passing message from ROS 1 sensor_msgs/PointCloud2 to ROS 2 sensor_msgs/msg/PointCloud2 (showing msg only once per type)
[INFO] [1641243321.136791384] [ros_bridge]: Passing message from ROS 1 sensor_msgs/CompressedImage to ROS 2 sensor_msgs/msg/CompressedImage (showing msg only once per type)
If we now go to the third terminal, we can list the topics in ros2 with:
The /wrist_rgbd/depth/camera_info topic does not show any distance of any object. Is just shows the configurations of the camera.
The /wrist_rgbd/rgb/image_raw just shows an array of pixels that just represent the colors that we can see in an image. It does not contain any distance information either.
The topic we are really interested in this one: /wrist_rgbd/depth/points
Let’s open rviz2 in a fourth terminal so that we can understand things better by visualizing data like the depth information of the camera:
rviz2
Rviz is a graphical tool, so, in order to see it, you have to click the Graphical tools button.
Now that rviz is open, let’s change the Fixed Frame to wrist_rgbd_camera_link
After that, let’s click the Add button that appears on the bottom left, and click the By Topic tab, and select /wrist_rgbd/depth/points
Add – By Topic – wrist_rgbd/depth/points
You should now be able to see the depth info visually:
Add – By Topic – wrist_rgbd depth points visually
The points you see in the last image above actually tell you the distance of the arm.
By checking the values that are sent in the /wrist_rgbd/depth/points topic you can easily determine how far an object is.
That is pretty much how you would use a depth camera to determine the distance of an object.
