[ROS Q&A] 189 – How to create a custom action message
custom action message for ROS Actions
Written by Alberto Ezquerro
24/05/2019
About
Learn how to create and compile a custom action message for ROS Actions from zero.
You’ll learn
  • How to define the message
  • How to modify the CMakeLists.txt and package.xml files
  • How to compile and import the message for ROS Actions
Below are the Steps to create the project as shown in the video
Step 1
  • Head to ROS Development Studio and create a new project.
  • Provide a suitable project name and some useful description. (We have named the project how_to_make_custom_ros_action)
  • Load/Start the project (this will take a few seconds).
  • Let’s create a new catkin package in our catkin workspace. Open Tools > Shell and run the following commands
$ cd catkin_ws/src
$ catkin_create_pkg turtlebot3_console_controller actionlib_msgs std_msgs
  • We’ll create an action directory to put the action file. We will create an action file named Motor.action inside the action directory
$ cd turtlebot3_console_controller
$ mkdir action
$ touch Motor.action
  • Use Tools > IDE to browse the directory and file we just created. At this point we should have the following directory structure
    ├── ai_ws
    ├── catkin_ws
    │   ├── build
    │   ├── devel
    │   └── src
    │       ├── CMakeLists.txt
    │       └── turtlebot3_console_controller
    │           ├── action
    │           │   └── Motor.action
    │           └── package.xml
    ├── how_to_make_custom_ros_action.zip
    ├── notebook_ws
    │   ├── default.ipynb
    │   └── images
    └── simulation_ws
      ├── build
      ├── devel
      └── src
Step 2
  • Open the Motor.action file in IDE and write the following content to it.
# This is an action definition file, which has three parts: the goal
# the result, and the feedback.
# Part 1: the goal.
# The angle in degree the robot to turn, sent by client main
float64 angle
# Part 2: the result, sent by action server unpon completion
# How much time used
duration time_elapsed
# How many updates thrown in total
uint32 updates_n
# Part 3: the feedback,to be sent periodically by server
# The amount of time elapsed from the start
  • The contents of Motor.action defines variables of three categories. The categories are separated by — lines. The first category of variables are related to GOAL, second is related to RESULT and third are related to the FEEDBACK. Here we have the following variable in different categories: angle for GOAL, time_elapsed, updates_n for RESULT and time_elapsed for FEEDBACK.
  • Now we have to add the directive to compile action file in CMakeLists.txt file. This file is inside our package directory i.e. ~/catkin_ws/src/turtlebot3_console_controller. Open the CMakeLists.txt file in IDE
  • Add the following code block
    add_action_files(
    FILES
    Motor.action
  • Also, add this code block
    generate_messages(
    DEPENDENCIES
    actionlib_msgs
  • Let’s compile the project. Run following commands in the SHELL
    $ cd ~/catkin_ws
    $ catkin_make
  • To test if the action file works we will create a script name node.py inside a new directory within the package. Use the following commands in SHELL
    $ cd ~/catkin_ws/src/turtlebot3_console_controller
    $ mkdir src
    $ touch node.py
  • To create the directory and file we can use IDE tool as well. Let’s add the following code to the node.py file
from turtlebot3_console_controller.msg import MotorGoal, MotorResult, MotorFeedback
print("OK, it worked!!!")
Let’s run the above script. Enter the following commands in the SHELL
$ cd ~/catkin_ws/src/turtlebot3_console_controller/src
$ ./node.py
After running the above command you should see the reply OK, it worked!!! in the next line.
And that’s it. We have created a basic action message and verified it works.
Related courses
Topics: ROS Q&A
