Hello ROS Developers,
This is the 3rd of 4 posts of the series Developing web interfaces for ROS Robots.
In this post, we are going to create a “joystick” to send velocity commands to a robot from the webpage.
1 – Creating the HTML
First we are going to create the buttons that the user will click on to move the robot.
Just after the logs section, let’s add the following:
<h3>Log messages</h3>
<div>
<p v-for="log of logs">{{ log }}</p>
</div>
</div>
</div>
<hr>
<div class="row">
<div class="col-md-12 text-center">
<h5>Commands</h5>
</div>
<!-- 1st row -->
<button class="btn btn-primary">Go forward</button>
<br><br>
</div>
<!-- 2nd row -->
<div class="col-md-4 text-center">
<button class="btn btn-primary">Turn left</button>
</div>
<button class="btn btn-danger">Stop</button>
<br><br>
</div>
<button class="btn btn-primary">Turn right</button>
</div>
<!-- 3rd row -->
<button class="btn btn-primary">Go backward</button>
</div>
</div>
This must provide an interface like below:
2 – Code to send the commands
Now, in our main.js file, let’s create some new methods to perform the actions we have just idealized. Inside the methods attribute we already have 2 functions. Let’s create the ones below:
setTopic: function() {
this.topic = new ROSLIB.Topic({
ros: this.ros,
messageType: 'geometry_msgs/Twist'
forward: function() {
this.message = new ROSLIB.Message({
linear: { x: 1, y: 0, z: 0, },
angular: { x: 0, y: 0, z: 0, },
this.setTopic()
this.topic.publish(this.message)
stop: function() {
linear: { x: 0, y: 0, z: 0, },
this.setTopic()
backward: function() {
linear: { x: -1, y: 0, z: 0, },
this.setTopic()
turnLeft: function() {
linear: { x: 0.5, y: 0, z: 0, },
angular: { x: 0, y: 0, z: 0.5, },
this.setTopic()
turnRight: function() {
angular: { x: 0, y: 0, z: -0.5, },
this.setTopic()
We have defined a common method setTopic that is used by the others: forward, backward, stop, turnLeft and turnRight.
The task inside of each one is always the same. Define a message to send, set the topic and publish the message.
The only thing that changes from one to another are the values of the Twist message.
3 – Integrating HTML and JavaScript
Now that we have the elements in our page and the methods that perform the actions, let’s make them work together.
In order to do so, we need to assign the methods to the “click” events of each button. It goes like this:
<!-- 1st row -->
<button @click="forward" :disabled="loading || !connected" class="btn btn-primary">Go forward</button>
<br><br>
</div>
<!-- 2nd row -->
<button @click="turnLeft" :disabled="loading || !connected" class="btn btn-primary">Turn left</button>
</div>
<button @click="stop" :disabled="loading || !connected" class="btn btn-danger">Stop</button>
<br><br>
</div>
<button @click="turnRight" :disabled="loading || !connected" class="btn btn-primary">Turn right</button>
</div>
<!-- 3rd row -->
<button @click="backward" :disabled="loading || !connected" class="btn btn-primary">Go backward</button>
</div>
Notice that we are not only defining the @click attribute, but also the “:disabled”. It means that the button will be disabled if one of the conditions are true: Loading or not connected.
4 – Final result
At this point, you must have the following result with your webpage:
ROSJect created along with the post:
