Step 0 – Introduction
In this post, we implement Bug 1 algorithm to our existing robot! Let’s use some algorithms we have already done in order to have it all working!
At the end of this post, you must have the robot+algorithm working like shown at the image below:
Step 1 – Importing libraries and defining states
We start creating a script file, it goes like that: ~/catkin_ws/src/motion_plan/scripts/bug1.py
(Don’t forget to assign the necessary permissions to the file)
chmod +x ~/catkin_ws/src/motion_plan/scripts/bug1.py
Open the file in the editor and start coding. We start from the necessary libraries:
#! /usr/bin/env python # import ros stuff import rospy # import ros message from geometry_msgs.msg import Point from sensor_msgs.msg import LaserScan from nav_msgs.msg import Odometry from tf import transformations # import ros service from std_srvs.srv import * import math
Now.. we define some global variables to store the goal and the current status of the robot and algorithm:
yaw_ = 0
position_ = Point()
desired_position_ = Point()
desired_position_.z = 0
regions_ = None
state_desc_ = ['Go to point', 'circumnavigate obstacle', 'go to closest point']
state_ = 0
circumnavigate_starting_point_ = Point()
circumnavigate_closest_point_ = Point()
count_state_time_ = 0 # seconds the robot is in a state
count_loop_ = 0
# 0 - go to point
# 1 - circumnavigate
# 2 - go to closest point
Take a closer look.. You’ll notice there are some new variables (in comparison to Bug 0 alg.) to store, not only the state, but also some necessary points (starting point of circumnavigation state and closest point to the goal).
Step 2 – Defining callbacks
Second step, we define the callbacks, afterall we need to read the position (given by odometry) and the obstacles (laser reading). They go like:
# callbacks
def clbk_odom(msg):
    global position_, yaw_
    # position
    # yaw
    quaternion = (
        msg.pose.pose.orientation.x,
        msg.pose.pose.orientation.y,
        msg.pose.pose.orientation.z,
        msg.pose.pose.orientation.w)
    yaw_ = euler[2]
def clbk_laser(msg):
    global regions_
    regions_ = {
There is nothing new here, if you compare to the Bug 0 we have implemented before!
Step 3 – Helper functions
This part doesn’t contain rules of the robot behavior, but it’s important to help other functions to work properly (and clearer), since we are helping them to get values and assigning states in a simpler way.
The first function is change_state, we had something like this one to other algorithms:
def change_state(state):
    global state_, state_desc_
    global count_state_time_
    state_ = state
    rospy.loginfo(log)
    if state_ == 0:
    if state_ == 1:
    if state_ == 2:
Then, we create the function calc_dist_points. It’s used to know the distance from the current position of the robot to interesting points (e.g: entry point of circumnavigation state, goal, etc.). It is quite simple, but we don’t want to have mathematical functions in our logics:
def calc_dist_points(point1, point2):
    dist = math.sqrt((point1.y - point2.y)**2 + (point1.x - point2.x)**2)
    return dist
Finally, a function to normalize angles. Very common for mobile robots algorithms:
def normalize_angle(angle):
    return angle
Step 4 – The core of it all!
Let’s go to the main function, where we have it all working together.
Part 1 – Defining ROS node, callbacks, services and the initial state
def main():
    global circumnavigate_closest_point_, circumnavigate_starting_point_
    global count_loop_, count_state_time_
    rospy.init_node('bug1')
    rospy.wait_for_service('/go_to_point_switch')
    rospy.wait_for_service('/wall_follower_switch')
    change_state(0)
    rate_hz = 20
    rate = rospy.Rate(rate_hz)
And finally, our loop control:
        if regions_ == None:
            continue
        if state_ == 0:
                circumnavigate_closest_point_ = position_
                circumnavigate_starting_point_ = position_
                change_state(1)
        elif state_ == 1:
            # if current position is closer to the goal than the previous closest_position, assign current position to closest_point
            if calc_dist_points(position_, desired_position_) < calc_dist_points(circumnavigate_closest_point_, desired_position_):
            # compare only after 5 seconds - need some time to get out of starting_point
            # if robot reaches (is close to) starting point
            if count_state_time_ > 5 and \
               calc_dist_points(position_, circumnavigate_starting_point_) < 0.2:
                change_state(2)
        elif state_ == 2:
            # if robot reaches (is close to) closest point
            if calc_dist_points(position_, circumnavigate_closest_point_) < 0.2:
                change_state(0)
        count_loop_ = count_loop_ + 1
        if count_loop_ == 20:
            count_state_time_ = count_state_time_ + 1
            count_loop_ = 0
Depending on the state, we use one rule or another to do a transition.
For example, from state 0 – go to point, if there’s an obstacle ahead, we change to state 1 – circumnavigate obstacle
Step 5 – Launch it!
Let’s create a launch file and see it working!
Create a new file at ~/catkin_ws/src/motion_plan/launch/bug1.launch. The content is:
    <arg name="des_x" default="0" />
    <arg name="des_y" default="-3" />
    <node pkg="motion_plan" type="follow_wall.py" name="wall_follower" />
    <node pkg="motion_plan" type="go_to_point.py" name="go_to_point" />
    <node pkg="motion_plan" type="bug1.py" name="bug1" output="screen" />
1 – You must launch the simulation like we did in previous chapters. Go to the simulation launcher and choose the world configured in our package:
2 – Spawn the robot
3 – Launch the algorithm
roslaunch motion_plan bug1.launch
Step 6 – Conclusion
Remember! If in any of the steps above you have missed something, you can always clone our ROSJect! Use this link to get your copy: http://www.rosject.io/l/b3a5b3c/
If you like it or have suggestion to improve it, leave a comment!
See you in the next post!
Thanks for this helpful tutorial. I have a question about velocities you used in go_to_point.py and follow_wall.py scripts. Why did you choose these velocities? Is there any computation behind it, or is just empirical?
Hello Z.HA,
They are just empirical, no maths so far!
