Exploring ROS with a 2 wheeled robot #12 – Bug 2
Motion planning algorithms Bug2
Written by Marco Arruda
20/07/2019
Step 0 – Introduction
Yes! We have skipped part number #11. That’s because it was an adjustment from ROS Indigo to ROS Kinetic. It’s not something necessary now, because we have already started using Kinetic.
In this post, we implement Bug 2 algorithm in our existing robot! Let’s use some algorithms we have already done in order to have it all working!
At the end of this post, we’ll have the robot working as shown on the image below:
Step 1 – Importing libraries
We start creating a script file, it goes like that: ~/catkin_ws/src/motion_plan/scripts/bug2.py
(Don’t forget to assign the necessary permissions to the file)
chmod +x ~/catkin_ws/src/motion_plan/scripts/bug2.py
Open the file in the editor and start coding. We start from the necessary libraries:
# import ros stuff
# import ros message
from gazebo_msgs.msg import ModelState
from gazebo_msgs.srv import SetModelState
# import ros service
from std_srvs.srv import *
Now.. we define some global variables to store the goal and the current status of the robot and algorithm:
yaw_ = 0
position_ = Point()
initial_position_ = Point()
initial_position_.x = rospy.get_param('initial_x')
initial_position_.y = rospy.get_param('initial_y')
initial_position_.z = 0
desired_position_ = Point()
desired_position_.z = 0
regions_ = None
state_desc_ = ['Go to point', 'wall following']
state_ = 0
count_state_time_ = 0 # seconds the robot is in a state
count_loop_ = 0
# 0 - go to point
# 1 - wall following
Like in Bug 1 algorithm, we are storing the state of the robot. I put some description of the states in an Array called state_desc_. There are also 2 new arguments being received: initial_x and initial_y. They are used to restore the robot position in case you want to restart the algorithm. Very useful to test the algorithm many times in a row!
Step 2 – Defining callbacks
Here we define callbacks, the very same as before, no big deal here. But don’t miss this part of the code:
# callbacks
def clbk_odom(msg):
    global position_, yaw_
    # position
    # yaw
    quaternion = (
        msg.pose.pose.orientation.x,
        msg.pose.pose.orientation.y,
        msg.pose.pose.orientation.z,
        msg.pose.pose.orientation.w)
    yaw_ = euler[2]
def clbk_laser(msg):
    global regions_
    regions_ = {
Step 3 – Helper functions
The first helper function is change_state. We had one like this in Bug 1, but we have different rules and states now. Let’s check it:
def change_state(state):
    global state_, state_desc_
    global count_state_time_
    state_ = state
    rospy.loginfo(log)
    if state_ == 0:
    if state_ == 1:
We have only 2 states: wall_follower and go_to_point. The different is that we are not driving the robot in a straight line to the desired point, but following the original line. The one from the initial position to the desired one. This will be implemented on the main function.
The next one: distance_to_line:
def distance_to_line(p0):
    # p0 is the current position
    # p1 and p2 points define the line
    global initial_position_, desired_position_
    p1 = initial_position_
    p2 = desired_position_
    # here goes the equation
    up_eq = math.fabs((p2.y - p1.y) * p0.x - (p2.x - p1.x) * p0.y + (p2.x * p1.y) - (p2.y * p1.x))
    lo_eq = math.sqrt(pow(p2.y - p1.y, 2) + pow(p2.x - p1.x, 2))
    distance = up_eq / lo_eq
    return distance
This function is used to calculate the distance of the robot to the initial line. Super important for this algorithm and it’s used all the time during its execution.
Finally, we’ll use again the normalize_angle function:
def normalize_angle(angle):
    return angle
Step 4 – The core of it all!
Let’s check the main function
Part 1 – ROS node, callbacks, services and initial state
def main():
    global count_state_time_, count_loop_
    rospy.init_node('bug0')
    rospy.wait_for_service('/go_to_point_switch')
    rospy.wait_for_service('/wall_follower_switch')
    rospy.wait_for_service('/gazebo/set_model_state')
    srv_client_set_model_state = rospy.ServiceProxy('/gazebo/set_model_state', SetModelState)
    # set robot position
    model_state = ModelState()
    model_state.model_name = 'm2wr'
    model_state.pose.position.x = initial_position_.x
    model_state.pose.position.y = initial_position_.y
    resp = srv_client_set_model_state(model_state)
    change_state(0)
    rate = rospy.Rate(20)
This is something necessary, the same standard we have been doing so far.
Part 2 – The loop logic
        if regions_ == None:
            continue
        distance_position_to_line = distance_to_line(position_)
        if state_ == 0:
                change_state(1)
        elif state_ == 1:
            if count_state_time_ > 5 and \
               distance_position_to_line < 0.1:
                change_state(0)
        count_loop_ = count_loop_ + 1
        if count_loop_ == 20:
            count_state_time_ = count_state_time_ + 1
            count_loop_ = 0
        rospy.loginfo("distance to line: [%.2f], position: [%.2f, %.2f]", distance_to_line(position_), position_.x, position_.y)
We are all the time calculating the distance to the original line. Depending on the presence of obstacles, we switch between wall_follower and go_to_point.
The point to be used as goal is always the nearest in the line.
Step 5 – Launch it!
Let’s create a launch file and see it working!
Create a new file at ~/catkin_ws/src/motion_plan/launch/bug2.launch. The content is:
    <arg name="initial_x" default="0" />
    <arg name="initial_y" default="8" />
    <arg name="des_x" default="0" />
    <arg name="des_y" default="-4" />
    <param name="initial_x" value="$(arg initial_x)" />
    <param name="initial_y" value="$(arg initial_y)" />
    <node pkg="motion_plan" type="follow_wall.py" name="wall_follower" />
    <node pkg="motion_plan" type="go_to_point.py" name="go_to_point" />
    <node pkg="motion_plan" type="bug2.py" name="bug2" output="screen" />
We improved it a little bit. We are restarting our robot position every time we launch it. That’s why we have to new arguments.
1 – You must launch the simulation like we did in previous chapters. Go to the simulation launcher and choose the world configured in our package:
But.. just before, change the world to the previous one we worked before (~/simulation_ws/src/my_worlds/launch/world.launch):
  <arg name="pause" default="false"/>
  <arg name="world" default="world02" />
    <arg name="world_name" value="$(find my_worlds)/worlds/$(arg world).world"/>
    <env name="GAZEBO_MODEL_PATH" value="$(find simulation_gazebo)/models:$(optenv GAZEBO_MODEL_PATH)"/>
2 – Spawn the robot
3 – Launch the algorithm
roslaunch motion_plan bug2.launch
Step 6 – Conclusion
Remember! If in any of the steps above you have missed something, you can always clone our ROSJect! Use this link to get your copy: http://www.rosject.io/l/b550d08/
If you like it or have a suggestion to improve it, leave a comment!
See you in the next post!
5 Comments
  1. Gideon
    in Step 1 of the second code chunk line 3, Yaw_=
    Yaw_ is not set to anything, this is a syntax error. what is Yaw_ supposed to be = to?
    thanks
    • Marco Prod.
      Hi @Gideon,
      The value that must be there is just number “0” (as integer). Consider this for all the lines like this.
      Thanks for reporting. It’s an issue in my code format for this blog post. I’m working to format it in a better way.
      Hope it helped you! Cheers
  2. robotik
    hi
    up_eq = math.fabs((p2.y – p1.y) * p0.x – (p2.x – p1.x) * p0.y + (p2.x * p1.y) – (p2.y * p1.x))
    lo_eq = math.sqrt(pow(p2.y – p1.y, 2) + pow(p2.x – p1.x, 2))
    what exactly is the process here. especially did not understand up_eq.
    I would appreciate if you help.
    thanks.
  3. Fernando
    Hello
    Can you help me?
    File “/home/fernando/catkin_ws/src/path_controller/scripts/path_controller.py”, line 28, in
    initial_position_.x = rospy.get_param(‘initial_x’)
    File “/opt/ros/melodic/lib/python2.7/dist-packages/rospy/client.py”, line 467, in get_param
    return _param_server[param_name] #MasterProxy does all the magic for us
    File “/opt/ros/melodic/lib/python2.7/dist-packages/rospy/msproxy.py”, line 123, in __getitem__
    raise KeyError(key)
    KeyError: ‘initial_x’
    Thanks
  4. Sagit
    Thank You so much. Great video. It’s very helpful to me.
    Do you have a tutorial also for tangent bug algorithm?
