In this post, you will learn how to use the joint_state_publisher node. At the end of the post, you will be able to debug your robot model joints using a graphical interface. Let’s go!
Once logged in, click here to copy the ROS project (rosject) we’ll use for this post. Once copied, click the Run button to open the rosject.
PS: we are using ROS Kinetic. You should be able to replicate the same on any ROS 1 distro, with minor changes.
Step 2: Identify the joints in your robot
For this post, we are using the following robot model, which you’ll find by opening the IDE and locating the file as shown in the image below.
<?xml version="1.0" ?>
<robot name="my_robot" xmlns:xacro="http://www.ros.org/wiki/xacro">
<!-- 1st link -->
<link name="link_chassis">
<pose>0 0 0.1 0 0 0</pose>
<inertial>
<mass value="5"/>
<origin xyz="0 0 0.1" rpy="0 0 0"/>
<inertia ixx="0.0395416666667" ixy="0" ixz="0" iyy="0.106208333333" iyz="0" izz="0.106208333333"/>
</inertial>
<collision name="collision_chassis">
<box size="1 1 2"/>
</collision>
<visual>
<origin rpy="0 0 0" xyz="0 0 0"/>
<box size="1 1 2"/>
<joint name="joint1" type="continuous">
<origin xyz="0.6 0 1" rpy="0 0 0"/>
<parent link="link_chassis"/>
<child link="link_arm"/>
<!-- 2nd link -->
<link name="link_arm">
<pose>0 0 0 0 0 0</pose>
<inertial>
<mass value="0.5"/>
</inertial>
<origin xyz="0 0 0.5" rpy="0 0 0"/>
<box size="0.2 0.2 1"/>
</collision>
<visual>
</robot>
The joint in question here is highlighted in the code above.
Step 3: Use the joint_state_publisher node with the rviz node
The launch file is in simulation_ws/src/my_robot_description/launch/rviz.launch. The lines where the joint_state_publisher node is started is highlighted below.
<param name="robot_description" command="$(find xacro)/xacro --inorder '$(find my_robot_description)/urdf/robot.urdf'" />
<!-- send fake joint values -->
<!-- Combine joint values -->
<!-- Show in Rviz -->
<node name="rviz" pkg="rviz" type="rviz" args="-d $(find my_robot_description)/rviz/robotmodel.rviz" />
Step 4: Use the joint_state_publisher to move the joint
Open a web shell and launch rviz with the command shown below.
roslaunch my_robot_description rviz.launch
You should now see two displays: rviz and the joint_state_publisher gui. You should be able to move the joint as shown in the image below.
Step 5: Check your learning
Do you now understand how to use the joint_state_published node? If not, please go over the post again, more carefully this time.
Step 6 (Optional): watch the video to learn more
If you want to learn about other ROS topics, please let us know on the comments area, and we will do a video about it.
![[Gazebo in 5 mins] 011 – How to use joint_state_publisher [Gazebo in 5 mins] 011 - How to use joint_state_publisher](https://www.theconstruct.ai/wp-content/uploads/2018/12/Gazebo-in-5-mins-011-How-to-use-joint_state_publisher.png)
