Gazebo Joints Control in ROS2
Written by Bayode Aderinola
18/11/2021
In this post, we will see how to implement Gazebo joints control in ROS2. The way this is done has changed a bit from ROS1.
Step 1: Grab a copy of the ROS Project containing the code
Run ROS project
That done, open the project using the Run button. This might take a few moments, please be patient.
You should now see a notebook with detailed instructions. This post includes a summary of these instructions and some other tips.
Step 2: Start the Simulation and get the robot moving
Start a web shell
Start a web shell from the bottom bar of the screen as shown above and run the following command:
ros2 launch box_car_gazebo box_bot_launch.py
Create new web shell
Start another tab in the web shell, run the following command:
ros2 run teleop_twist_keyboard teleop_twist_keyboard --ros-args --remap cmd_vel:=/box_bot/cmd_vel
See the robot by clicking on the Gazebo icon on the bottom bar:
Open Gazebo
You should now see something like this (if you cannot see it, please ensure the ros2 launch command is still running and restart it if necessary):
Gazebo window with box car
Put the Gazebo window and the shell window with the teleop command side by side, focus on the shell and move the robot with the keyboard. You should see the robot run off. PS: use the z key to reduce the speed before moving the robot forward or backward, otherwise it runs off too quickly!
Step 3: Explore the source code using the IDE
Open the IDE
ROS2 workspace
All the files used in the simulation are in the ros2_ws/src directory. Explore the files. Double-click to open a file in the editor. You will refer back to some of the files later on.
Step 4: Watch the video to understand how we implemented gazebo joints control in ROS2
Step 5: Consolidate your learning
  • Do you understand how to implement gazebo joints control in ROS2 after watching the video? If not, have you gone over the video again?
  • If you are familiar with ROS1 control, can you see how it’s different from ROS control?
The Construct
Run ROS project
Start a web shell
Open Gazebo
Open the IDE
ROS2 workspace
How to set/get parameters from another node | ROS 2 Humble Python Tutorial
