ROS2 Tutorials #8: How to communicate between ROS1 & ROS2 with ros1_bridge
Written by Alberto Ezquerro
06/10/2019
In this post, you will learn how to communicate between ROS1 & ROS2 with ros1_bridge. You will see how to set up the ros1_bridge package in order to send ROS2 commands to control a TurtleBot2 simulation running in ROS1 Melodic.
Step 1: Grab a copy of the Project (ROSject) on ROSDS
Click here to get your copy of the project used in this post.
Step 2: Launch the TurtleBot2 simulation from the Simulations menu
Launch a TB2 Simulation
Now you should see a Simulation window pop up with the TurtleBot2 simulation.
TurtleBot2 Simulation
Step 2: Source the workspace for ROS1 Melodic
Pick a Shell (terminal tool) from the Tools menu and run the following command:
user:~$ source /opt/ros/melodic/setup.bash
user:~$
Step 3: Source the workspace for ROS2 Dashing
In the same Shell used in Step 2, run the following command:
user:~$ source /opt/ros/dashing/local_setup.bash
ROS_DISTRO was set to 'melodic' before. Please make sure that theenvironment does not mix paths from different distributions.
user:~$
Step 3: Ensure ROS_MASTER_URI is pointing in the right direction:
Still on the same shell, run the following:
user:~$ echo $ROS_MASTER_URI
http://master:11311
user:~$ export ROS_MASTER_URI=http://master:11311
user:~$
Step 4: Communicate between ROS1 & ROS2 with ros1_bridge: start the ros_bridge
Now, start the ros1_bridge and put this terminal on one side – we’re done with it for now.
user:~$ ros2 run ros1_bridge dynamic_bridge
Created 2 to 1 bridge for service /gazebo/clear_body_wrenches
Created 2 to 1 bridge for service /gazebo/clear_joint_forces
Created 2 to 1 bridge for service /gazebo/delete_light
Created 2 to 1 bridge for service /gazebo/delete_model
Created 2 to 1 bridge for service /gazebo/get_joint_properties
Created 2 to 1 bridge for service /gazebo/get_light_properties
Created 2 to 1 bridge for service /gazebo/get_link_properties
Step 5: Control the ROS1 TurtleBot2 Simulation from ROS2
Fire up another Shell from the Tools menu and publish to /cmd_vel.
ROS_DISTRO was set to 'melodic' before. Please make sure that the environment does not mix paths from different distributions.
user:~$ ros2 topic pub /cmd_vel geometry_msgs/Twist "linear:
  x: 0.5
  y: 0.0
  z: 0.0
angular:
  x: 0.0
  y: 0.0
  z: 0.0"
publisher: beginning loop
publishing #1: geometry_msgs.msg.Twist(linear=geometry_msgs.msg.Vector3(x=0.5, y=0.0, z=0.0), angular=geometry_msgs.msg.Vector3(x=0.0, y=0.0, z=0.0))
In the shell where you’re running the ros1_bridge, you should see messages similar to the following:
created 1to2 bridge for topic '/rosout' with ROS 1 type 'rosgraph_msgs/Log' and ROS 2 type 'rcl_interfaces/msg/Log'
created 2to1 bridge for topic '/cmd_vel' with ROS 2 type 'geometry_msgs/msg/Twist' and ROS 1 type ''
created 2to1 bridge for topic '/rosout' with ROS 2 type 'rcl_interfaces/msg/Log' and ROS 1 type 'rosgraph_msgs/Log'
[INFO] [ros_bridge]: Passing message from ROS 2 geometry_msgs/msg/Twist to ROS 1 geometry_msgs/Twist (showing msg only once per type)
And, of course, you should see that your robot started to move!
And that was it 😉 . We just controlled a simulation started in ROS1 with ROS2, using the ros1_bridge.
Prefer to watch a video demonstrating the steps above? We have one for you below! PS: the video uses another simulation, a Parrot Drone, but the concepts are the same.
Post edited by Bayode Aderinola
#ROS2 #ROS #ROS2tutorials #Robot
Topics: ros1_bridge | ros2
1 Comment
  1. Adi
    Could you also provide a tutorial on installation on our devices please. Installing and setting up for newbies like me is just as hard as actually using these tools
