How to create custom interfaces using a field type that is a msg from a package | English ROS2 Tutorial
Written by Ernest Cheong
08/03/2024
What you will learn:
How to create custom interfaces using a field type that is a msg from a package, and not just a primitive built-in-type.
Prerequisite:
Basic understanding of the basics of creating custom interfaces with the built-in field types (including best practices such as creating a package dedicated to your interface definitions).
If you want to learn ROS 2 Python in a practical, hands-on way, check out the course ROS 2 Basics in 5 Days: https://app.theconstruct.ai/courses/132
In order to follow this tutorial, we need to have ROS2 installed in our system, and ideally a ros2_ws (ROS2 Workspace). To make your life easier, we have already prepared a rosject for that: /https://app.theconstruct.ai/l/5f773d8c/
After the rosject has been successfully copied to your own area, you should see a Run button. Just click that button to launch the rosject ( see this example).
After pressing the Run button, you should have the rosject loaded. Now, let’s head to the next section to get some real practice.
Let’s open a terminal by clicking the Open a new terminal button.
Recreating the error: Creating the custom srv
Create a new package named custom_interfaces. This package, however, has to be a CMake package (default when using ros2 pkg create). Currently, there is no way to generate custom interfaces in a pure Python package. However, you can create a custom interface in a CMake package and then use it in a Python node.
cd ~/ros2_ws/src/
ros2 pkg create custom_interfaces
Next, remove the include and src directories and create a directory named srv inside your package. Inside this directory, create the srv file TurnCamera.srv:
cd ~/ros2_ws/src/custom_interfaces
rm -rf include
rm -rf src
mkdir srv
touch srv/TurnCamera.srv
Paste this inside TurnCamera.srv:
float32 deg_turn
sensor_msgs/Image camera_image
Then add the following lines to the CMakeLists.txt file:
find_package(sensor_msgs REQUIRED)
rosidl_generate_interfaces(${PROJECT_NAME}
  "srv/TurnCamera.srv"
And also the following lines to the package.xml file within the <package> element:
<buildtool_depend>rosidl_default_generators</buildtool_depend>
<exec_depend>rosidl_default_runtime</exec_depend>
<member_of_group>rosidl_interface_packages</member_of_group>
Finally compile the package by running this in the terminal:
colcon build --packages-select custom_interfaces
You should get this error:
Starting >>> custom_interfaces
--- stderr: custom_interfaces
In file included from /home/user/ros2_ws/build/custom_interfaces/rosidl_typesupport_cpp/custom_interfaces/srv/turn_camera__type_support.cpp:7:
/home/user/ros2_ws/build/custom_interfaces/rosidl_generator_cpp/custom_interfaces/srv/detail/turn_camera__struct.hpp:134:10: fatal error: sensor_msgs/msg/detail/image__struct.hpp: No suchfile or directory
  134 | #include "sensor_msgs/msg/detail/image__struct.hpp"
compilation terminated.
gmake[2]: *** [CMakeFiles/custom_interfaces__rosidl_typesupport_cpp.dir/build.make:86: CMakeFiles/custom_interfaces__rosidl_typesupport_cpp.dir/rosidl_typesupport_cpp/custom_interfaces/srv/turn_camera__type_support.cpp.o] Error 1
gmake[1]: *** [CMakeFiles/Makefile2:414: CMakeFiles/custom_interfaces__rosidl_typesupport_cpp.dir/all] Error 2
gmake: *** [Makefile:146: all] Error 2
Failed   <<< custom_interfaces [20.3s, exited with code 2]
Summary: 0 packages finished [20.8s]
  1 package failed: custom_interfaces
  1 package had stderr output: custom_interfaces
Fixing the error: Adding a dependency
So what was the issue?
Well the OP did not pass the dependencies to rosidl_generate_interfaces by specifying other packages that their custom interface used. In this case, they did not specify the dependency on sensor_msgs which their custom srv TurnCamera.srv used.
They added the find_package line (in green) but did not add the DEPENDENCIES line (in red) in the CMakeLists.txt file. Both lines are necessary when using a msg from another package as a field type:
find_package(sensor_msgs REQUIRED) # Add packages that the custom interfaces depend on
  DEPENDENCIES sensor_msgs # Add packages that the custom interfaces depend on
After adding this line, recompile and source the workspace:
It should work now!
Finished <<< custom_interfaces [21.1s]
Summary: 1 package finished [21.5s]
You can verify that your custom srv has been created successfully by running these two commands:
ros2 interface list | grep custom
ros2 interface show custom_interfaces/srv/TurnCamera
You should get these results respectively:
float32 deg_turn
        std_msgs/Header header #
                builtin_interfaces/Time stamp
                        int32 sec
                        uint32 nanosec
                string frame_id
                                     # Header frame_id should be optical frame of camera
                                     # origin of frame should be optical center of cameara
                                     # +x should point to the right in the image
                                     # +y should point down in the image
                                     # +z should point into to plane of the image
                                     # If the frame_id here and the frame_id of the CameraInfo
                                     # message associated with the image conflict
                                     # the behavior is undefined
        uint32 height                #
        uint32 width                 #
        string encoding       #
                              # taken from the list of strings in include/sensor_msgs/image_encodings.hpp
        uint8 is_bigendian    #
        uint32 step           #
        uint8[] data          #
The same principles should apply for custom msgs and actions with field types that are msgs from packages rather than simply the primitive built-in-types.
Congratulations. You now know how to create ROS 2 Custom Interface.
To learn more advanced topics about ROS 2, have a look at the course below:
We hope this post was really helpful to you.
This tutorial is created by Robotics Ambassador Ernest.
Topics: ros2
