In this post, you will learn how to create Gazebo plugins by making the Gazebo plugin tutorial, Hello World, compile and work in a ROS package. This is a response to the question posted on Gazebo Answers.
You might also want to try this on a local PC if you have ROS installed. However, please note that we cannot support local PCs and you will have to fix any errors you run into on your own. The rest of the instruction assumes that you are working on The Construct; please adapt them to your local PC and ROS installation.
PS: We are using ROS Kinetic here, but you should be able to use any ROS 1 distro.
Step 2: Create a new package that we’ll use to demonstrate creating Gazebo plugins
Open a web shell and run the following commands to create the package. When creating Gazebo plugins, you need, at a minimum, the roscpp
and gazebo_ros
dependencies.
cd catkin_ws/src source /opt/ros/kinetic/setup.bash catkin_create_pkg example_plugins_gazebo roscpp gazebo_ros
Create a new C++ file in the package you just created:
cd example_plugins_gazebo/src touch simple_world_plugin.cpp
Now head over to the Code Editor to make changes to the C++ file. Check the image below for how to open the Code Editor.
Locate the C++ file in the code editor: catkin_ws > src > example_plugins_gazebo > src > simple_world_plugin.cpp
and paste in the following code.
#include <gazebo/common/Plugin.hh> #include <ros/ros.h> namespace gazebo { class WorldPluginTutorial : public WorldPlugin { public: WorldPluginTutorial() : WorldPlugin() { } void Load(physics::WorldPtr _world, sdf::ElementPtr _sdf) { // Make sure the ROS node for Gazebo has already been initialized if (!ros::isInitialized()) { ROS_FATAL_STREAM("A ROS node for Gazebo has not been initialized, unable to load plugin. " << "Load the Gazebo system plugin 'libgazebo_ros_api_plugin.so' in the gazebo_ros package)"); return; } ROS_WARN("Hello World!"); } }; GZ_REGISTER_WORLD_PLUGIN(WorldPluginTutorial) }
Next, replace the package’s CMakeLists.txt
with the following:
cmake_minimum_required(VERSION 2.8.3) project(example_plugins_gazebo) ## Add support for C++11, supported in ROS Kinetic and newer add_definitions(-std=c++11) # Load catkin and all dependencies required for this package find_package(catkin REQUIRED COMPONENTS roscpp gazebo_ros ) # Depend on system install of Gazebo find_package(gazebo REQUIRED) link_directories(${GAZEBO_LIBRARY_DIRS}) include_directories(${Boost_INCLUDE_DIR} ${catkin_INCLUDE_DIRS} ${GAZEBO_INCLUDE_DIRS}) # For tc_simple_world_plugin plugin add_library(simple_world_plugin src/simple_world_plugin.cpp) target_link_libraries(simple_world_plugin ${catkin_LIBRARIES} ${GAZEBO_LIBRARIES}) catkin_package( DEPENDS roscpp gazebo_ros )
Also, replace the package.xml
file content with the following:
<?xml version="1.0"?> <package> <name>example_plugins_gazebo</name> <version>0.0.0</version> <description>The example_plugins_gazebo package</description> <maintainer email="name@email.com">user</maintainer> <license>TODO</license> <buildtool_depend>catkin</buildtool_depend> <build_depend>gazebo_ros</build_depend> <build_depend>roscpp</build_depend> <run_depend>gazebo_ros</run_depend> <run_depend>roscpp</run_depend> <!-- The export tag contains other, unspecified, tags --> <export> <gazebo_ros plugin_path="${prefix}/lib" gazebo_media_path="${prefix}" /> </export> </package>
Success! We have now created a new plugin. Next, we will use it!
Step 3: Use the new Gazebo plugin we just created
Create a new folder in the package. We’ll create Gazebo worlds in it, so it’s so named!
cd ~/catkin_ws/src/example_plugins_gazebo mkdir -p worlds cd worlds touch simple_world.world
Open the simple_world.world
file in the code editor and paste in the following:
<?xml version="1.0" ?> <sdf version="1.4"> <world name="default"> <include> <uri>model://ground_plane</uri> </include> <include> <uri>model://sun</uri> </include> <!-- reference to your plugin --> <plugin name="simple_world_plugin" filename="libsimple_world_plugin.so"/> </world> </sdf>
But, wait…how did we know the right filename to use in the line highlighted in the world file? It is by convention named lib{name_of_cpp_executable}.so
, and we should find it in ~/catkin_ws/src/devel/lib/
cd ~/catkin_ws/devel/lib/ ls
That covered, we move. Now we’ll create a launch file to launch our world with the Gazebo plugin.
cd ~/catkin_ws/src/example_plugins_gazebo mkdir -p launch cd launch touch simple_world.launch
Open the simple_world.launch
file in the code editor and paste in the following content.
<?xml version="1.0" encoding="UTF-8"?> <launch> <include file="$(find gazebo_ros)/launch/empty_world.launch"> <arg name="world_name" value="$(find example_plugins_gazebo)/worlds/simple_world.world"/> </include> </launch>
Perfect! Time to launch the package.
roslaunch example_plugins_gazebo simple_world.launch
Now you should see something like this: Hello World!
printed on the terminal and an empty Gazebo world. We are done here!
Step 4: Check your learning
Do you understand how to create Gazebo plugins? If you don’t know it yet, please go over the post again, more carefully this time.
Here are the links to the resources used in this tutorial:
- http://gazebosim.org/tutorials/?tut=plugins_hello_world
- http://gazebosim.org/tutorials?tut=ros_gzplugins
- http://gazebosim.org/tutorials?tut=guided_i5
- http://gazebosim.org/tutorials/?tut=ros_advanced
- http://gazebosim.org/tutorials?tut=plugins_model
(Extra) Step 5: Watch the video to understand how to create Gazebo plugins
Did you like this post? Do you have any questions about how to create Gazebo plugins? Please leave a comment in the comments section below, so we can interact and learn from each other.
