In this post, you will learn how to publish and subscribe to a topic from a launch file. This post is a response to this question posted on Gazebo Answers.
PS: we are using ROS Noetic. You should be able to replicate the same on any ROS 1 distro.
Step 2: Create a package to demonstrate how to publish and subscribe to a topic from a launch file
cd catkin_ws/src source /opt/ros/noetic/setup.bash catkin_create_pkg test_rostopic
Next, we create the launch directory and the launch files.
cd test_rostopic mkdir launch cd launch touch test_pub.launch touch test_echo.launch
Nice done! Now head over to the Code Editor to make changes to the launch files. Check the image below for how to open the Code Editor.
Locate the launch folder in the code editor: catkin_ws > src > test_rostopic > launch
and open the two launch files.
Paste the following lines into the test_pub.launch
file. This is equivalent to rostopic pub /test_topic std_msgs/String "data: 'Hello there!'"
<launch> <arg name="topic_name" default="/test_topic" /> <arg name="message" default="Hello there!" /> <node pkg="rostopic" type="rostopic" name="rostopic_pub_node" output="screen" args="pub $(arg topic_name) std_msgs/String 'data: $(arg message)'" /> </launch>
Next, your test_echo.launch
should be made up of the following lines. This is equivalent to rostopic echo /test_topic
<launch> <arg name="topic_name" default="/test_topic" /> <node pkg="rostopic" type="rostopic" name="rostopic_echo_node" output="screen" args="echo $(arg topic_name)" /> </launch>
Fantastic! Now, let’s compile the package.
Success! We’ll test it in the next step.
Step 3: Test the package to demonstrate how to publish and subscribe to a topic from a launch file
Start the test_pub.launch
file in the current terminal.
roslaunch test_rostopic test_pub.launch
When done, open another terminal and run the test_echo.launch
file.
roslaunch test_rostopic test_echo.launch
Now you should see something similar to the following on the terminal where test_echo.launch
is running:
process[rostopic_echo_node-1]: started with pid [xxxx] data: "Hello there!" ---
Sweet! So we are able to publish with one launch file and echo what we publish in another launch file. And…we are done here, congrats!
Take home: try combining both into a single launch file. After trying, check the solution in this gist.
Step 4: Check your learning
Do you understand how to publish and subscribe to a topic from a launch file? If you don’t know it yet, please go over the post again, more carefully this time.
(Extra) Step 5: Watch the video to understand how to publish and subscribe to a topic from a launch file
Did you like this post? Do you have any questions about how to publish and subscribe to a topic from a launch file? Please leave a comment in the comments section below, so we can interact and learn from each other.
