In this post, you will learn how to write a ROS publisher and subscriber with a custom message, by following the Writing a Publisher and Subscriber with a Custom Message (Python) tutorial. This post is a response to this question posted on Gazebo Answers.
PS:
- We are using ROS Kinetic here because that’s what the user on ROS Answers used.
- We could put the publisher and the subscriber in a single package, but we’ll create two packages as the user did.
- We could put the custom message in any of the two packages, but we’ll put it in the subscriber, just like the user.
Step 2: Create the first package that contains the subscriber and the custom message
Create the package and custom message
Open a web shell and run the following commands to create the package. When creating a custom message, you need extra dependencies message_generation
and message_runtime
, in addition to the main ROS API, rospy
(for Python) in this case, and the types needed for the message, in this case std_msgs
cd catkin_ws/src source /opt/ros/kinetic/setup.bash catkin_create_pkg quadrotor_receive rospy std_msgs message_generation message_runtime
Next, we create the message file, Person.msg
. Run the following command in the same terminal you just used.
cd quadrotor_receive mkdir msg cd msg touch Person.msg
Nice done! Now head over to the Code Editor to make changes to the Person.msg
file. Check the image below for how to open the Code Editor.
Locate the file in the code editor: catkin_ws > src > quadrotor_receive > msg > Person.msg
and paste in the following code.
string name int32 age
Edit package files
Replace CMakeLists.txt
with the one below (where the following changes have been made).
- Removed
message_runtime
from thefind_package
function. - Uncommented the
add_message_files
function, and addedPerson.msg
belowFILES
. - Uncommented the
generate_messages
function, and left it intact. - Uncommented the line
CATKIN_DEPENDS
in thecatkin_package
function. - Removed all commented lines to keep the file short and sweet.
cmake_minimum_required(VERSION 3.0.2) project(quadrotor_receive) ## Find catkin macros and libraries ## if COMPONENTS list like find_package(catkin REQUIRED COMPONENTS xyz) ## is used, also find other catkin packages find_package(catkin REQUIRED COMPONENTS message_runtime rospy std_msgs ) ## Generate messages in the 'msg' folder add_message_files( FILES Person.msg # Message2.msg ) ## Generate added messages and services with any dependencies listed here generate_messages( DEPENDENCIES std_msgs ) ################################### ## catkin specific configuration ## ################################### ## The catkin_package macro generates cmake config files for your package ## Declare things to be passed to dependent projects ## INCLUDE_DIRS: uncomment this if your package contains header files ## LIBRARIES: libraries you create in this project that dependent projects also need ## CATKIN_DEPENDS: catkin_packages dependent projects also need ## DEPENDS: system dependencies of this project that dependent projects also need catkin_package( # INCLUDE_DIRS include # LIBRARIES quadrotor_receive CATKIN_DEPENDS message_generation message_runtime rospy std_msgs # DEPENDS system_lib ) ########### ## Build ## ########### ## Specify additional locations of header files ## Your package locations should be listed before other locations include_directories( # include ${catkin_INCLUDE_DIRS} )
Next, add a single line to package.xml
so that it looks like the one below. Can you identify the line that was added?
<?xml version="1.0"?> <package format="2"> <name>quadrotor_receive</name> <version>0.0.0</version> <description>The quadrotor_receive package</description> <!-- One maintainer tag required, multiple allowed, one person per tag --> <!-- Example: --> <!-- <maintainer email="jane.doe@example.com">Jane Doe</maintainer> --> <maintainer email="user@todo.todo">user</maintainer> <!-- One license tag required, multiple allowed, one license per tag --> <!-- Commonly used license strings: --> <!-- BSD, MIT, Boost Software License, GPLv2, GPLv3, LGPLv2.1, LGPLv3 --> <license>TODO</license> <!-- <doc_depend>doxygen</doc_depend> --> <buildtool_depend>catkin</buildtool_depend> <build_depend>message_generation</build_depend> <build_depend>rospy</build_depend> <build_depend>std_msgs</build_depend> <build_export_depend>rospy</build_export_depend> <build_export_depend>std_msgs</build_export_depend> <build_export_depend>message_generation</build_export_depend> <exec_depend>message_runtime</exec_depend> <exec_depend>rospy</exec_depend> <exec_depend>std_msgs</exec_depend> <!-- The export tag contains other, unspecified, tags --> <export> <!-- Other tools can request additional information be placed here --> </export> </package>
Finally, let’s create the receiver Python node, just as the ROS Answers user created it. Run the following in the same terminal as before. Notice that we’re making the Python script executable.
cd ~/catkin_ws/src/quadrotor_receive/src touch custom_listener.py chmod +x custom_listener.py
Open custom_listener.py
in the IDE and paste in the following code.
#!/usr/bin/env python import rospy from quadrotor_receive.msg import Person def callback(data): rospy.loginfo("%s is age: %d" % (data.name, data.age)) def listener(): rospy.init_node('custom_listener', anonymous=True) rospy.Subscriber("custom_chatter", Person , callback) # spin() simply keeps python from exiting until this node is stopped rospy.spin() if __name__=='__main__': listener()
So much for all the hard work – let’s see if it works. Time to compile the code. In the same web shell, run the following commands:
Compile and test
Success! We have successfully created a package with a custom message. Let’s see if we can find the message. You should get an output similar to the one below.
user:~/catkin_ws$ rosmsg show quadrotor_receive/Person string name int32 age
Let’s also test receiver node at this point. Though there’s nothing to receive yet, it should not throw any error. First, we need to start roscore
roscore
Then try to run your subscriber in another terminal. Leave it running!
rosrun quadrotor_receive custom_listener.py
Step 3: Create the second package that contains the publisher
Create a new folder package. This should be easy-peasy, as most of the work has been done in the previous step. Do the following in a new terminal.
cd ~/catkin_ws/src/ catkin_create_pkg transmit_thrust rospy
Next, create the custom_talker.py
node.
cd transmit_thrust/src touch custom_talker.py chmod +x custom_talker.py
Open up custom_talker.py
in the IDE and paste in the following.
#!/usr/bin/env python import rospy from quadrotor_receive.msg import Person def talker(): pub = rospy.Publisher('custom_chatter', Person) rospy.init_node('custom_talker', anonymous=True) r = rospy.Rate(10) #10hz msg = Person() msg.name = "ROS User" msg.age = 4 while not rospy.is_shutdown(): rospy.loginfo(msg) pub.publish(msg) r.sleep() if __name__ == '__main__': try: talker() except rospy.ROSInterruptException: pass
Please note that:
- We are importing the custom message from the
quadrotor_receive
package. - We are creating a publisher for the same topic we created a subscriber for in the
quadrotor_receive
package.
Nothing more is needed. Let’s compile our new package.
That done, let’s start the custom talker node.
rosrun transmit_thrust custom_talker.py
You should see some output similar to these on the terminal.
[INFO] [1680728823.955004]: name: "ROS User" age: 4 [INFO] [1680728824.055152]: name: "ROS User"
And…on the terminal where you have the listener tunning, you should see something similar to:
[INFO] [1680728823.956347]: ROS User is age: 4 [INFO] [1680728824.056833]: ROS User is age: 4
And we are done here!
Step 4: Check your learning
Do you understand how to write a ROS publisher and subscriber with a custom message? If you don’t know it yet, please go over the post again, more carefully this time.
(Extra) Step 5: Watch the video to understand how to write a ROS publisher and subscriber with a custom message
Did you like this post? Do you have any questions about how to write a ROS publisher and subscriber with a custom message? Please leave a comment in the comments section below, so we can interact and learn from each other.
