RDP 004: Using Docker to Cross-Compile ROS With Francisco Martin
cross-compile ROS with Francisco Martin
12/02/2018
In this episode, I interview Francisco Martin, associated professor at the University Juan Carlos I in Madrid, where he teaches robotics by using ROS. He is also a participant of the Robocup and the ROCKin competitions. He will explain how have they hacked Pepper the robot by means of using docker machines to cross-compile ROS code for Pepper. Francisco will also tell us about with research work on applying cognitive architectures to the control of robots, using ROS Plan inside Pepper to figure out the situation of the robot.
Selected quote to from the interview
For the next Robocup we are going to use ROS2 because it has realtime communication between components. Actually, for the next ROSCON we are planning to have everything in Pepper running with ROS2
Related links
1 Comment
  1. tomoyafujita
    i really interested in cross compile part, this could be integration improvement.
    could you enlighten me more about that specific part?
The Construct
131. The Truth About ROS Jobs
