[ROS in 5 mins] 009 – How to Launch a ROS node
[ROS-in-5-mins]-009-How-to-Launch-a-ROS-node-
Written by The Construct
11/06/2018
In this video, we will see how to launch a ROS node in just 5 minutes. We’ll see four different way nodes can be launched in ROS, and how to check that a node has been launched:
* rosnode list
Links mentioned in the video:
– ROS Development Studio (RDS), used for the demonstration: http://ROS Development Studio
– Robot Ignite Academy, the place to learn to program robots using only a web browser: https://goo.gl/PoGfxC
– More about ‘rosrun’: https://www.theconstruct.ai/ros-5-mins-007-rosrun-works/
– Difference between ‘roslaunch’ and ‘rosrun’: https://www.theconstruct.ai/ros-5-mins-008-difference-rosrun-roslaunch/
– The turtlesim node examplefrom ROS Wiki: http://wiki.ros.org/ROS/Tutorials/UnderstandingNodes
– The openni_launch example from ROS Wiki: http://wiki.ros.org/openni_launch
The following steps take through the development as shown in the video
  • Open Robot Development Studio and create a new project (use a suitable name for project).
  • Open the project.
  • Start a Tools > Shell and start the roscore with following command
    $ roscore
This command starts the roscore. If the roscore is already running then it shows a warning message with roscore ip address information (as shown in green box in image)
The roscore starts as a node called /rosout. We can check the node with rostopic list command in another Shell
One way to launch a rosnode is using the rosrun command. For example
$ rosrun turtlesim turtlesim_node
This command will start the following nodes
  • /turtle1/cmd_vel
  • /turtle1/color_sensor
  • /turtle1/pose
We can verify these nodes with rostopic list command in a new window
Next we will see about running a custom node. We will create a project using catkin_create_pkg command. Then we will create a python script with following contents
rospy.init_node('Obiwan')
rate = rospy.Rate(2)
    print("Help me Obi-wan Kenobi, you're my only hope")
## This program creates an endless loop that repeats itself 2 times per second
Next we will launch the script with the following command
$ rosrun node_demo simple.py
We can check if the node is running or not with rostopic list command in a new shell
Now we will see how to run several nodes at the same time. This is done with the help of launch files and roslaunch command. For example:
$ roslaunch openni_launch openni.launch
This command will launch various nodes that can be listed with the rostopic list command.
129. ros2ai
129. ros2ai
