In this video, we will see what the ROS_MASTER_URI is in just 5 minutes. We’ll see what it represents and how it’s used in the entire ROS system.
Links mentioned in the video:
– ROS Development Studio (RDS), used for the demonstration: ROS Development Stdio
– Robot Ignite Academy, the place to learn to program robots using only a web browser: Robot Ignite Academy
– The openni_launch example from ROS Wiki: http://wiki.ros.org/openni_launch
Below are the Steps to create the project as shown in the video
Step 1
- Head to ROS Development Studio and create a new project.
- Provide a suitable project name and some useful description. (We have named the project )
- Load/Open the project (this will take few seconds).
- Open Tools > Shell and run following commands
$ echo $ROS_MASTER_URI
Note the result of the above command, it should have the following format http://<ip>:<port>. The following image shows a representational value
The specific values shown in the image are \<ip>=10.8.0.1 and \<port>=11311.
Step 2
- The ip we just saw is also referred as hostname and it denotes the address of the computer running the
roscoreprogram. - To understand better, lets run a ros application
$ roslaunch openni_launch openni.launch
When the above command executes, it will launch the openni project. First of all ros master will be run (as shown) and once the ros master is ready other nodes are loaded. Note that there is only one ros master, however any number of nodes can exist.
Step 3
Next we can see how to change the ROS_MASTER_URI. The simplest way to change ROS_MASTER_URI is by editing the .bashrc file. This file is a system file and thus hidden by default, we will modify its content using the vi editor. Use the following command to start editing the .bashrc file (located in home directory)
$ vim ~/.bashrc
The following line is responsible for assigning the ros master ip
export ROS_MASTER_URI=http://10.8.0.1:11311
We can modify this line to use any other ip address. For reflecting the changed ip we will need to load this bash file. Use the following command to do so
$ source ~/.bashrc
Once we have sourced the bashrc file, we will see the changed ros master uri when launching ros project.
![[ROS-in-5-mins]-010—What-is-ROS_MASTER_URI- [ROS-in-5-mins]-010---What-is-ROS_MASTER_URI-](https://www.theconstruct.ai/wp-content/uploads/2018/06/ROS-in-5-mins-010-What-is-ROS_MASTER_URI-.jpg)
