[ROS in 5 mins] 022 – What is a ROS publisher?
what is a publisher
Written by Bayode Aderinola
13/08/2018
In this post, we will see what a ROS publisher is all about in just about five minutes! We’ll also see how it relates to ROS nodes and topics.
Step 1: Grab a copy of the Project (ROSject) on ROSDS
Get it here: http://www.rosject.io/l/18f83296-0e7e-4c5c-95a7-2d3e3d6430d4/.
Once you have copied the project, open it up.
Step 2: Run the obiwan_pub.py program
Pick a Shell from the Tools menu and run the following commands.
First, start the ROS master – we need this to run any ROS commands. We’re starting this program in the background:
user:~$ nohup roscore &
[1] 1501
user:~$ nohup: ignoring input and appending output to 'nohup.out'
user:~$
Before we proceed, let’s check the ROS topics currently available:
user:~$ rostopic list
/rosout_agg
Now start the obiwan_pub.py program:
user:~$ cd catkin_ws/src
user:~/catkin_ws/src$ ./obiwan_pub.py
Again, check the list of available ROS topics. Pick another Shell from the Tools menu and run:
/help_msg
/rosout_agg
Now we have a new topic /help_msg, obviously created by the obiwan_pub.py program. Running it is the only thing we have done since the last time we checked the list of messages, right?
Okay, do not take my word for it; let’s spy on the /help_msg topic to confirm:
user:~$ rostopic info /help_msg
Type: std_msgs/String
Publishers:
 * /sos_2 (http://rosdscomputer:38619/)
Subscribers: None
Now we know that that topic uses a message of type std_msgs/String and has a Publisher named /sos_2.
But what has this got to with the obiwan_pub node? Everything – let’s see that in the next step.
Step 3: Unravel the mysterious “Publisher” /sos_2
In the previous step, we saw that /sos_2 was listed as a Publisher on the topic /help_msg, and we suspected that this has to do with the obiwan_pub.py program. Now, let’s examine the obiwan_pub.py code to see if we have some clues.
obiwan_pub.py
rospy.init_node("sos_2")
rate = rospy.Rate(2)
help_msg = String()
help_msg.data = "help me Obi-Wan Kenobi, you're my only hope"
pub = rospy.Publisher('/help_msg', String, queue_size = 1)
    pub.publish(help_msg)
On line 6, we have the statement rospy.init_node("sos_2"), so we now know that:
  • /sos_2 was created by this program!
  • /sos_2 is a ROS node, because it says rospy.init_node...
Also on line 10, we have this statement: pub = rospy.Publisher('/help_msg', String, queue_size = 1), confirming that:
  • The code actually creates a Publisher on the /help_msg topic. Bingo!
Step 4: Master the Concept – What is a ROS Publisher?
Combining all the points in the previous steps, we can see that a ROS Publisher…
  • is a ROS node (program).
  • creates a particular type of ROS message. In this case, it’s std_msgs/String, as can be seen on lines 4,7-8 of the code.
  • sends (publishes) a message over a channel called “topic”, as can be seen on lines 10 then 12 of the code.
In short, a ROS publisher is a ROS node that publishes a specific type of ROS message over a given ROS topic. “Interested” nodes (Subscribers) can access messages so published.
And that was it!
  • A previous video about ROS nodes: [irp posts=”10305″ name=”ROS in 5 mins – 005 – What is a ROS Node?”]
The Construct
what is a publisher
131. The Truth About ROS Jobs
