Hello ROS Developers!
In today’s video we are going to learn how to compile a ROS Message.
For that we are going to use Robot Ignite Academy, which is the best tool if you want Learn ROS Fast.
We have the best online ROS course available in RIA. It helps you learn ROS in the easiest way without setting up ROS environment locally. The only thing you need is a browser! Create an account here and start to browse the trial course for free now! We’ll use the ROS Basic in 5 days course unit 4 as an example today.
Step2. Create a package
We’ll create a package for our code with the following command.
cd ~/catkin_ws/src catkin_create_pkg financial_market rospy
We also need one folder for our message definition
cd financial_market mkdir msg
Let’s call our message SharePrice.msg with the following definition
string name float32 price
In the package.xml file, please uncomment the following part.
... <build_depend>message_generation</build_depend> ... <run_depend>message_runtime</run_depend> ...
In the CMakeLists.txt, change the following part to compile the message.
... find_package(catkin REQUIRED COMPONENTS rospy std_msgs message_generation ) ... add_message_files( FILES SharePrice.msg # Message2.msg ) ... generate_messages( DEPENDENCIES std_msgs # Or other packages containing msgs ) ... catkin_package( # INCLUDE_DIRS include # LIBRARIES my_sense_package CATKIN_DEPENDS rospy message_runtime # DEPENDS system_lib ) ...
Then we compile the message with the following command
cd ~/catkin_ws catkin_make
Please source the file after compile.
You can then check the message with
rosmsg info financial_market/SharePrice
In your python code, you can then add from financial_market.msg import SharePrice to use the message.
If you are interested in this topic, please check our ROS Basics In 5 Days (Python) course. You’ll learn how to create service and action message in ROS as well.
