[ROS in 5 mins] 025 – What is Rviz?
What is rviz?
Written by Bayode Aderinola
25/09/2019
In this post, we will see what Rviz is all about and how to use it.
We are going to use a ROS1 installation for this, but you don’t need to install ROS, as we will use the ROS Development Studio (ROSDS), an online platform that provides access to ROS1 or ROS2 computers and other powerful ROS tools within a browser!
Action first before the theory! Grab a copy of the project used for this post here. If you don’t have an account on the ROSDS, you will be asked to create one.
Once you have cloned the project, open it up and give it a moment to finish loading.
Step 2: Bring up a TurtleBot2 simulation
Head to the Simulations menu and launch one of the pre-configured simulations:
  1. Select “Simulations from the main menu”.
  2. Under “World”, select “Empty to World”.
  3. Under “Robot”, select TurtleBot2.
  4. Click “Start Simulation”.
ROSDS - Launch a simulation
You should now have something like this:
TutleBot2 with wall in front
That’s a TutleBot2 facing a wall.
Step 3: Launch the rviz program and use it to “spy” on the TurtleBot
We need two more tools here.
  • Minimize the Gazebo window.
  • From the Tools menu, pick “Shell” and “Graphical Tools”. Arrange them side-by-side for better visibility.
On the Shell tool, run the following command:
rosrun rviz rviz
Rviz - launch visualization
Maximize the Rviz window and:
  1. Double-click the Title bar to bring the window into full focus. Ensure you can clearly see the “Add” button lablled below.
  2. Change the “Fixed frame” to “base_link”.
  3. Click “Add” to add a visualization.
  4. Select “Camera”
  5. Click okay.
Semi-finally, select a topic for the Camera visualization. You should see the brick wall in full color now!
Finally, pick another Shell from the Tools menu and run the following command to cause the robot to rotate. You should see the wall in the Camera disappear and appear again as the front camera position changes.
# Just type rostopic pub /cmd_vel and then press TAB-TAB to complete message structure.
# Then change angular.z to 1.0
user:~$ rostopic pub /cmd_vel geometry_msgs/Twist "linear:
  x: 0.0
  y: 0.0
  z: 0.0
angular:
  x: 0.0
  y: 0.0
  z: 1.0"
Interesting, isn’t it? You can try and play with other visualization tools and see how they work.
Now’s let review the theory briefly.
Step 4: So, what’s Rviz?
We have just seen Rviz in action. So what exactly is this amazing tool?
  • Short for ROS Visualization. It’s a 3-dimensional visualization tool for ROS.
  • It helps to visualize what the robot seeing and doing.
And that’s it. It’s more practical than theory 🙂 .
Related Resources and Further Learning
If you want to learn about other ROS topics, please let us know in the comments area and we will do a video or post about it
Alternatives to ROS
Alternatives to ROS
