Hello ROS Developers
Welcome to this new post about ROS. In today’s post, we are going to learn what is the ROS_PACKAGE_PATH variable and how it is used by the ROS ecosystem.
The commands used here can be executed in your own computer if you have ROS installed, but for simplicity, we are going to use Robot Ignite Academy.
Before we start, if you are new to ROS, I highly recommend you taking the following course:
Ok, let’s get started, shall we?
In a computer with ROS installed, we have many variables with the ROS_ prefix. If we run env | grep ROS , for example, we may have something like the output below:
ROS_ROOT=/opt/ros/kinetic/share/ros ROS_PACKAGE_PATH=/home/user/catkin_ws/src:/home/simulations/public_sim_ws/src:/opt/ros/kinetic/share ROS_MASTER_URI=http://localhost:11311 ROS_VERSION=1 ROSLISP_PACKAGE_DIRECTORIES=/home/user/catkin_ws/devel/share/common-lisp:/home/simulations/public_sim_ws/devel/share/common-lisp ROS_DISTRO=kinetic ROS_ETC_DIR=/opt/ros/kinetic/etc/ros
Among these variables we can find the one we are looking for: ROS_PACKAGE_PATH
This variable is used by ROS in order to find ROS Packages. To better understand this, let’s consider the command below, used to control robots using the keyboard:
roslaunch turtlebot_teleop keyboard_teleop.launch
The first parameter of the roslaunch command is the package name, which in this case is turtlebot_teleop .
When we run the command exemplified above, in order to find the turtlebot_teleop package, ROS will look for the ROS_PACKAGE_PATH variable.
If we run roscd turtlebot_teleop to enter on the that package, for instance, on Robot Ignite Academy the package is located at /home/simulations/public_sim_ws/src/all/turtlebot/turtlebot_teleop as can be seen below:
user:~$ roscd turtlebot_teleop user:/home/simulations/public_sim_ws/src/all/turtlebot/turtlebot_teleop$ pwd /home/simulations/public_sim_ws/src/all/turtlebot/turtlebot_teleop
If you look carefully, you can notice that the turtlebot_telop package is on the “Public Simulations Workspace”, which is /home/simulations/public_sim_ws/src. Now, with a closer look at the ROS_PACKAGE_PATH variable, we can find that path on it:
So, the turtlebot_teleop package only was found because its workspace path is set on ROS_PACKAGE_PATH.
If we unset that variable and try to roscd on that package again, it is not going to work, as can be seen with the commands unset ROS_PACKAGE_PATH and roscd turtlebot_teleop.
user:~$ cd user:~$ unset ROS_PACKAGE_PATH user:~$ roscd turtlebot_teleop roscd: No such package/stack 'turtlebot_teleop'
Here we can see that ROS wasn’t able to find the package. If we look at the ROS_ prefixed environment variables again, we won’t find ROS_PACKAGE_PATH:
user:~$ env | grep ROS ROS_ROOT=/opt/ros/kinetic/share/ros ROS_MASTER_URI=http://localhost:11311 ROS_VERSION=1 ROSLISP_PACKAGE_DIRECTORIES=/home/user/catkin_ws/devel/share/common-lisp:/home/simulations/public_sim_ws/devel/share/common-lisp ROS_DISTRO=kinetic ROS_ETC_DIR=/opt/ros/kinetic/etc/ros
If we source our catkin_ws again with source ~/catkin_ws/devel/setup.bash, the variable will be exported and ROS will be able to find the package again:
user:~$ source ~/catkin_ws/devel/setup.bash user:~$ roscd turtlebot_teleop user:/home/simulations/public_sim_ws/src/all/turtlebot/turtlebot_teleop$
Creating a package in an unexpected location
Now let’s go a bit further and create a package in a place that nobody would do it. We are going to create it in the /tmp folder, just to let you better understand the importance of ROS_PACKAGE_PATH.
We can use the cd /tmp/ and catkin_create_pkg tutorial_package commands to achieve that:
user:~$ cd /tmp/ user:/tmp$ catkin_create_pkg tutorial_package Created file tutorial_package/package.xml Created file tutorial_package/CMakeLists.txt Successfully created files in /tmp/tutorial_package. Please adjust the values in package.xml.
We can clearly see that the package was created in /tmp/tutorial_package, but if we try to navigate to it using roscd tutorial_package, ROS won’t be able to find it:
user:/tmp$ roscd tutorial_package roscd: No such package/stack 'tutorial_package'
That happens because the /tmp folder is not on the ROS_PACKAGE_PATH variable. We can easily add it using the next command:
export ROS_PACKAGE_PATH=/tmp:$ROS_PACKAGE_PATH
Now if we check the value of the variable with env | grep ROS_P , we can find /tmp there:
user:/tmp$ export ROS_PACKAGE_PATH=/tmp:$ROS_PACKAGE_PATH user:/tmp$ env | grep ROS_P ROS_PACKAGE_PATH=/tmp:/home/user/catkin_ws/src:/home/simulations/public_sim_ws/src:/opt/ros/kinetic/share
If we try to enter our package with roscd tutorial_package again, ROS will find it:
user:/tmp$ roscd tutorial_package user:/tmp/tutorial_package$ pwd /tmp/tutorial_package
So easy to understand the ROS_PACKAGE_PATH variable, isn’t it?
Remember that we also have a video version of this post on YouTube:
I hope you liked the post (and the video), if that is the case, please consider subscribing to our channel on YouTube. Additionally, should you have any questions or suggestions, please leave your comment on the comments section of the video.
![[ROS in 5 mins] 037 – What is ROS PACKAGE PATH? [ROS in 5 mins] 037 - What is ROS PACKAGE PATH?](https://www.theconstruct.ai/wp-content/uploads/2018/09/ROS-in-5-mins-037-What-is-ROS-PACKAGE-PATH.png)
