Hello ROS Developers! In this video post, we’ll see what rosbag is, what it does, and how to use it to record and playback ROS topics.
Key commands that you will learn: rosbag...
record
play
info
Step 1: Create a project in Robot Ignite Academy (RIA)
We have the best online ROS courses available in RIA. It helps you learn ROS in the easiest way without setting up a ROS environment locally. The only thing you need is a browser! Create an account here and start to browse the trial course for free now! We’ll use the ROS Basics in 5 Days course as an example today.
Step 2: Record Bag file with rosbag
The ROS Bag is a powerful tool for you to record and playback your simulation. To start the recording all topic available, simply type the following command in the terminal.
rosbag record -a
As an example, we’ll move the turtlebot in the simulation with
roslaunch turtlebot_teleop keyboard_teleop.launch
You can now move around to generate the data. To finish recording, simply press CTRL+C to terminate the rosbag.
Step 3: Play the rosbag
bag file
In the video, the recorded bag file is saved as 2018-10-06-05-04-57.bag
(be sure to use your own name 🙂 ). To playback, type the following command in a terminal
rosbag play 2018-10-06-05-04-57.bag
You should see the robot moving around as how you did.
If you want to see more information about the .bag file. The following command will print all the topic available in the .bag file.
rosbag info 2018-10-06-05-04-57.bag
Video
See it happening live in this video, in case you are stuck or just want to sit back and watch a “movie” instead!
Further resources
– ROS Development Studio (ROSDS), another powerful online tool for pushing your ROS learning in a practical way
We love feedback!
