[ROS in 5 mins] 046 – What is ROS Namespace
[ROS in 5 mins] 046 - What is ROS Namespace
08/10/2018
Hello Everyone
In today’s video we’re going to see what is ROS Namespace and how it works.
Step 0. Create a project in Robot Ignite Academy(RIA)
We have the best online ROS course available in RIA. It helps you learn ROS in the easiest way without setting up ROS environment locally. The only thing you need is a browser! Create an account here and start to browse the trial course for free now! We’ll use the ROS Basics in 5 Days course unit0 as an example today.
Step 1. Create a package for the code
At first, let’s create a ROS package with dependencies for our code and a source file called robot.py under the src folder in the pakcage with the following command
catkin_create_pkg tutorial rospy geometry_msgs
cd tutorial/src
touch robot.py
In robot.py, please create the following content
rospy.init_node('robot', anonymous=True)
pub = rospy.Publisher('my_position', Pose, queue_size=1)
rate = rospy.Rate(1) # 1hz
pub.publish(Pose())
You can then give the permission and run the code with the following commands.
chmod +x robot.py
rosrun tutorial robot.py
It will publish the robot pose in my_position topic which you can check with
rostopic list | grep my_pos
Let’s imagine you have two different robot and you want to reuse the code. How can you distinguish between this two topics?
The answer is that you can use the namespace. To specify the different namespace, you can run the following command
rosrun tutorial robot.py __ns:=robot1
rosrun tutorial robot.py __ns:=robot2
Now if you see into the topic list, you should see two different topics called
/robot1/my_position
and
/robot2/my_position
If you are interested in this kind of tutorial, I highly recommend you to take any of the following courses on Robot Ignite Academy:
ROS Basics In 5 Days (Python)
ROS Basics In 5 Days (C++)
Thanks for watching.
Edited by: Tony Huang
129. ros2ai
129. ros2ai
