The Awards For The Best in ROS
2nd
April 22 – May 31, 2021
2nd ROS Awards Winners
ROS Awards 2021
Best ROS Software
Nav 2
ROS Awards 2021
Best ROS Robot
TurtleBot
by Melonee Wise and Tully Foote at Willow Garage
ROS Awards 2021
Best ROS Developer
Steven Macenski
About & Mission
You Nominate the Best in ROS.
Help Them Expand Their Impact!
The ROS Awards are international recognition of excellence in robot development achievements in the ROS world, voted annually by ROS developers for ROS developers.
Nominate the best
2nd ROS Awards Nominees
Best ROS Software
Nav 2
The Nav2 project is the spiritual successor of the ROS Navigation Stack. This project seeks to find a safe way to have a mobile robot move from point A to point B. It can also be applied in other applications that involve robot navigation, like following dynamic points. This will complete dynamic path planning, compute velocities for motors, avoid obstacles, and structure recovery behaviors. To learn more about this project, such as related projects, robots using, ROS1 comparison, and maintainers, see About and Contact.
(source: https://navigation.ros.org/)
Movelt
MoveIt is the most widely used software for manipulation and has been used on over 150 robots. It is released under the terms of the BSD license, and thus free for industrial, commercial, and research use.
By incorporating the latest advances in motion planning, manipulation, 3D perception, kinematics, control and navigation, MoveIt is state of the art software for mobile manipulation.
(source: https://moveit.ros.org/)
Plotjuggler
PlotJuggler is a tool to visualize time series that is fast, powerful and intuitive.
Noteworthy features:
  • Simple Drag & Drop user interface.
  • Load data from file.
  • Connect to live streaming of data.
  • Save the visualization layout and configurations to re-use them later.
  • Fast OpenGL visualization.
  • Can handle thousands of timeseries and millions of data points.
  • Transform your data using a simple editor: derivative, moving average, integral, etc…
  • PlotJuggler can be easily extended using plugins.
(source:
https://github.com/facontidavide/PlotJuggler)
Best ROS Robot
Stretch
A Robot for Researchers by Researchers
  • Interact with people using a low mass, contact-sensitive body.
  • Work in clutter with a compact footprint and a slender manipulator.
  • Go outside the lab, it only weighs 51 lb.
  • Everything included: a gripper, a computer, sensors, and software
  • Ready for autonomy
    • Calibrated
    • Python interfaces and ROS integration
    • Autonomy demos in Python
    • Open source code
(source: Hello Robot)
TurtleBot
TurtleBot is a low-cost, personal robot kit with open-source software. TurtleBot was created at Willow Garage by Melonee Wise and Tully Foote in November 2010. With TurtleBot, you’ll be able to build a robot that can drive around your house, see in 3D, and have enough horsepower to create exciting applications.
(source: https://www.turtlebot.com/)
TurtleBot3
TurtleBot3 is a small, affordable, programmable, ROS-based mobile robot for use in education, research, hobby, and product prototyping. The goal of TurtleBot3 is to dramatically reduce the size of the platform and lower the price without having to sacrifice its functionality and quality, while at the same time offering expandability. The TurtleBot3 can be customized into various ways depending on how you reconstruct the mechanical parts and use optional parts such as the computer and sensor. In addition, TurtleBot3 is evolved with cost-effective and small-sized SBC that is suitable for robust embedded system, 360 degree distance sensor and 3D printing technology.
(source: ROBOTIS)
Best ROS Developer
Davide Faconti
Twitter
Linkedin
Github
David Lu!!
Github
Steve Macenski
Winners Announcement Time
June 19, 2021 at ROSDevDay
The results will be announced on ROS Developers Day 2021 and published on this website on June 22, 2021.
Past Winners
ROS Awards 2020
Best ROS Software
Movelt
by Picknik
ROS Awards 2020
Best ROS-Based Product
Toru
by Magazino
ROS Awards 2020
Best ROS Robot
TurtleBot
by Willow Garage
ROS Awards 2020
Best ROS Developer
Steven Macenski
Nominate
The Best in ROS
Voting has been closed.
The winners will be announced at ROS Developers Day 2021
