In this short post, we will show how to avoid a very common mistake most ROS beginners make: missing execute permission on the Python file.
Step 1: Create a Project (ROSject) on ROSDS
Head to http://rosds.online and create a project with a similar configuration as the one shown below. You can change the details as you like, but please make sure you select “Ubuntu 16.04 + ROS Kinetic + Gazebo 7” under “Configuration”.
Step 2: Create a ROS package with a Python program
Pick a Shell from the Tools menu and create a Python package.
user:~$ cd catkin_ws/ user:~/catkin_ws$ cd src user:~/catkin_ws/src$ catkin_create_pkg missing_permission Created file missing_permission/package.xml Created file missing_permission/CMakeLists.txt Successfully created files in /home/user/catkin_ws/src/missing_permission. Please adjust the values in package.xml. user:~/catkin_ws/src$ cd missing_permission/ user:~/catkin_ws/src/missing_permission$ mkdir -p src/ user:~/catkin_ws/src/missing_permission$ cd src user:~/catkin_ws/src/missing_permission/src$ touch missing_perm.py user:~/catkin_ws/src/missing_permission/src$
Fire up the IDE from the Tools menu, find the missing_perm.py
file in the missing_permission
package, open the file and paste the following code into it.
#! /usr/bin/env python import rospy rospy.init_node("Obiwan") rate = rospy.Rate(2) while not rospy.is_shutdown(): print "Help me Obi-Wan Kenobi, you're my only hope" rate.sleep()
Save().
Step 3: Compile and source the workspace.
Step 4: Run the package with rosrun
and roslaunch
First, we check that the package has been recognized, with rospack list
. Then we run it with rosrun
user:~/catkin_ws$ rospack list | grep missing missing_permission /home/user/catkin_ws/src/missing_permission user:~/catkin_ws$ rosrun missing_permission missing_perm.py [rosrun] Couldn't find executable named missing_perm.py below /home/user/catkin_ws/src/missing_permission [rosrun] Found the following, but they're either not files, [rosrun] or not executable: [rosrun] /home/user/catkin_ws/src/missing_permission/src/missing_perm.py user:~/catkin_ws$
The program did not run! What’s that error? Surely that not what we expected. Maybe rosrun
does not like us – let’s try roslaunch
Create a launch file and use it to launch the python program:
user:~/catkin_ws$ cd src/missing_permission/ user:~/catkin_ws/src/missing_permission$ mkdir -p launch user:~/catkin_ws/src/missing_permission$ cd launch user:~/catkin_ws/src/missing_permission/launch$ touch missing_perm.launch user:~/catkin_ws/src/missing_permission$
Open the launch file in the IDE and paste in the following code:
<launch> <node name="missing_permission_ex" pkg="missing_permission" type="missing_perm.py" output="screen" /> </launch>
Launch!
user:~/catkin_ws/src/missing_permission$ cd ~/catkin_ws user:~/catkin_ws$ source devel/setup.bash user:~/catkin_ws$ roslaunch missing_permission missing_perm.launch ... logging to /home/user/.ros/log/e3188a2e-e921-11e9-8ac1-025ee6e69cec/roslaunch-rosdscomputer-11105.log ... NODES / missing_permission_ex (missing_permission/missing_perm.py) auto-starting new master process[master]: started with pid [11147] ROS_MASTER_URI=http://master:11311 setting /run_id to e3188a2e-e921-11e9-8ac1-025ee6e69cec process[rosout-1]: started with pid [11170] started core service [/rosout] ERROR: cannot launch node of type [missing_permission/missing_perm.py]: can't locate node [missing_perm.py] in package [missing_permission]
Oops! It didn’t run again. Now we have another error screaming:
What do we do now?
Step 5: Fix the missing execute permission on the Python file and be happy!
user:~/catkin_ws$ cd src/missing_permission/src/ user:~/catkin_ws/src/missing_permission/src$ chmod +x missing_perm.py user:~/catkin_ws/src/missing_permission/src$
Now let’s try again with both roslaunch
and rosrun
user:~/catkin_ws/src/missing_permission/src$ roslaunch missing_permission missing_perm.launch ... NODES / missing_permission_ex (missing_permission/missing_perm.py) auto-starting new master process[master]: started with pid [13206] ROS_MASTER_URI=http://master:11311 setting /run_id to eec6e306-e922-11e9-b72a-025ee6e69cec process[rosout-1]: started with pid [13229] started core service [/rosout] process[missing_permission_ex-2]: started with pid [13242] Help me Obi-Wan Kenobi, you're my only hope Help me Obi-Wan Kenobi, you're my only hope Help me Obi-Wan Kenobi, you're my only hope ...
Running fine with roslaunch
. Press Ctrl + C
on the roslaunch program and try rosrun
user:~/catkin_ws/src/missing_permission/src$ rosrun missing_permission missing_perm.py Unable to register with master node [http://master:11311]: master may not be running yet. Will keep trying.
If you get the error above, please spin another Shell from the Tools menu, and run the following to start the ROS master:
user:~$ roscore
After this, the roscore
command should resume and you’ll get:
user:~/catkin_ws/src/missing_permission/src$ rosrun missing_permission missing_perm.py Unable to register with master node [http://master:11311]: master may not be running yet. Will keep trying. Help me Obi-Wan Kenobi, you're my only hope Help me Obi-Wan Kenobi, you're my only hope Help me Obi-Wan Kenobi, you're my only hope ...
And that was it. As it turned out, roscore
had no ill-feeling towards us!
- Complete ROSject for this post
- ROS Development Studio (ROSDS)
- Robot Ignite Academy
- ROS for Beginners Course (Python)
Did you like this post? Do you have questions about what was explained? Whatever the case, please leave a comment on the comments section below, so we can interact and learn from each other.
