Learn how to create a ROS Action message and compile it for C++, to control a drone.
- The ROSject of the project with the simulation and the ROS Packages: www.rosject.io/l/e80ec70/
- Robot Ignite Academy courses, if you want to learn more about ROS Actions: www.robotigniteacademy.com/en/
- Post in ROS Discourse where the challenge was posted: discourse.ros.org/t/rosject-of-the-week-challenge-4/11706
Opening the ROSject
Once you clicked in the link to get a copy of the ROSject,
When you click in the ROSject Link (www.rosject.io/l/e80ec70/), you will get a copy of it. You can then download it if you want to use it on our local computer, or you can just click Open to have it opened in ROSDS.
Once it’s open, you can find all the code associated with this challenge in the ~/catkin_ws folder. To see the full code, open the IDE by going to the top menu and select Tools->IDE.
Launching the simulation
Finally, click on the Launch button to start the simulation. In the end, you should get something like this:
The problem to solve
As you can see, this ROSject contains 1 package inside its catkin_ws workspace: rotw4_code. The purpose of this packages is to allow you to control the Drone (Take Off or Land) using an Action Server.
So, the main purpose of this ROSject is to be able to send a Goal to this Action Server, specifying a keyword in the goal (either “UP” or “DOWN”), and the Drone receives and executes this goal. The steps in order to achieve this are the following:
First, you will need to compile the Action Server and the Action message used. For this, execute the following command:
cd ~/catkin_ws/ catkin_make source ~/catkin_ws/devel/setup.bash
Once, the compilation has finished successfully, you will start the Action Server by executing the following command:
rosrun rotw4_code rotw4_action_node
Once the Action Server is up and running, you can send goals to the Action with the following commands.
In order to make the Drone TAKE OFF:
rostopic pub /rotw4_action/goal rotw4_code/ActionMsgActionGoal "header: seq: 0 stamp: secs: 0 nsecs: 0 frame_id: '' goal_id: stamp: secs: 0 nsecs: 0 id: '' goal: goal: 'UP'"
You should see the Drone taking off, like in the following image:
And in order to make the Drone LAND, you could use the following command:
rostopic pub /rotw4_action/goal rotw4_code/ActionMsgActionGoal "header: seq: 0 stamp: secs: 0 nsecs: 0 frame_id: '' goal_id: stamp: secs: 0 nsecs: 0 id: '' goal: goal: 'DOWN'"
You should see the Drone landing:
Also, you will see in the Action Server a message indicating that the action was successfully executed.
Ok, so… where’s the problem? If you have tried to reproduce the steps described above you have already seen that it DOES NOT WORK. When you follow the pipeline you can see that even the 1st step, which is to compile the package, it does not work (though it is not the only error here). But Why? Let’s find it in the section below.
Solving the ROS Mini Challenge
According to the instructions, we need to have a look at the rotw4_code package and try to find there the errors.
If you looked carefully, after running the first commands, you had an error:
The error was:
Building CXX object rotw4_code/CMakeFiles/rotw4_action_node.dir/src/rotw4_action.cpp.o /home/user/catkin_ws/src/rotw4_code/src/rotw4_action.cpp:3:34: fatal error: rotw4_code/ActionMsg.h: No such file or directory compilation terminated. rotw4_code/CMakeFiles/rotw4_action_node.dir/build.make:62: recipe for target 'rotw4_code/CMakeFiles/rotw4_action_node.dir/src/rotw4_action.cpp.o' failed make[2]: *** [rotw4_code/CMakeFiles/rotw4_action_node.dir/src/rotw4_action.cpp.o] Error 1 CMakeFiles/Makefile2:1909: recipe for target 'rotw4_code/CMakeFiles/rotw4_action_node.dir/all' failed make[1]: *** [rotw4_code/CMakeFiles/rotw4_action_node.dir/all] Error 2 Makefile:138: recipe for target 'all' failed make: *** [all] Error 2 Invoking "make -j2 -l2" failed
The problem is that it can’t find the ActionMsg.h, so, which tell us that our ~/catkin_ws/src/rotw4_code/action/ActionMsg.action is not being compiled. Let’s then open the CMakeLists.txt file located in the rotw4_code package, to see where is the error.
If we look at the line 153 of the CMakeLists.txt file, we find the following:
add_executable(rotw4_action_node src/rotw4_action.cpp) target_link_libraries(rotw4_action_node ${catkin_LIBRARIES} )
we didn’t add the dependencies. To solve this compilation part, let’s add the line below right after line 153:
add_dependencies(rotw4_action_node ${rotw4_action_node_EXPORTED_TARGETS}
add_executable(rotw4_action_node src/rotw4_action.cpp) add_dependencies(rotw4_action_node ${rotw4_action_node_EXPORTED_TARGETS} ${catkin_EXPORTED_TARGETS}) target_link_libraries(rotw4_action_node ${catkin_LIBRARIES} )
Let’s now try to compile our package again:
Now we have another error. Although it looks similar, at least now the messages were compiled:
[ 97%] Building CXX object rotw4_code/CMakeFiles/rotw4_action_node.dir/src/rotw4_action.cpp.o /home/user/catkin_ws/src/rotw4_code/src/rotw4_action.cpp:3:34: fatal error: rotw4_code/ActionMsg.h: No such file or directory compilation terminated.
We can confirm the message was generated with find ~/catkin_ws/devel/ -name ActionMsg*.h:
$ find ~/catkin_ws/devel/ -name ActionMsg*.h /home/user/catkin_ws/devel/include/rotw4_code/ActionMsgActionResult.h /home/user/catkin_ws/devel/include/rotw4_code/ActionMsgActionFeedback.h /home/user/catkin_ws/devel/include/rotw4_code/ActionMsgAction.h /home/user/catkin_ws/devel/include/rotw4_code/ActionMsgFeedback.h /home/user/catkin_ws/devel/include/rotw4_code/ActionMsgGoal.h /home/user/catkin_ws/devel/include/rotw4_code/ActionMsgActionGoal.h /home/user/catkin_ws/devel/include/rotw4_code/ActionMsgResult.h
As we can see, we have no file named ActionMsg.h, which is imported by rotw4_code/src/rotw4_action.cpp. Let’s then fix rotw4_action.cpp on line 3 and import ActionMsgAction.h. Now let’s try to compile again:
Now we have different errors:
Scanning dependencies of target rotw4_action_node [ 97%] Building CXX object rotw4_code/CMakeFiles/rotw4_action_node.dir/src/rotw4_action.cpp.o /home/user/catkin_ws/src/rotw4_code/src/rotw4_action.cpp:11:33: error: 'ActionMsg' is not a member of 'rotw4_code' actionlib::SimpleActionServer<rotw4_code::ActionMsg> as_; ^ /home/user/catkin_ws/src/rotw4_code/src/rotw4_action.cpp:11:33: error: 'ActionMsg' is not a member of 'rotw4_code' /home/user/catkin_ws/src/rotw4_code/src/rotw4_action.cpp:11:54: error: template argument 1 is invalid actionlib::SimpleActionServer<rotw4_code::ActionMsg> as_; ^ /home/user/catkin_ws/src/rotw4_code/src/rotw4_action.cpp: In constructor 'ActionClass::ActionClass(std::__cxx11::string)': /home/user/catkin_ws/src/rotw4_code/src/rotw4_action.cpp:29:26: error: expression list treated as compound expression in mem-initializer [-fpermissive] action_name_(name) { ^ /home/user/catkin_ws/src/rotw4_code/src/rotw4_action.cpp:30:9: error: request for member 'start' in '((ActionClass*)this)->ActionClass::as_', which is of non-class type 'int' as_.start(); ^ /home/user/catkin_ws/src/rotw4_code/src/rotw4_action.cpp: In member function 'void ActionClass::executeCB(const ActionMsgGoalConstPtr&)': /home/user/catkin_ws/src/rotw4_code/src/rotw4_action.cpp:43:13: error: request for member 'isPreemptRequested' in '((ActionClass*)this)->ActionClass::as_', which is of non-class type 'int' if (as_.isPreemptRequested() || !ros::ok()) { ^ /home/user/catkin_ws/src/rotw4_code/src/rotw4_action.cpp:46:11: error: request for member 'setPreempted' in '((ActionClass*)this)->ActionClass::as_', which is of non-class type 'int' as_.setPreempted(); ^ /home/user/catkin_ws/src/rotw4_code/src/rotw4_action.cpp:62:9: error: request for member 'publishFeedback' in '((ActionClass*)this)->ActionClass::as_', which is of non-class type 'int' as_.publishFeedback(feedback_); ^ /home/user/catkin_ws/src/rotw4_code/src/rotw4_action.cpp:68:11: error: request for member 'setSucceeded' in '((ActionClass*)this)->ActionClass::as_', which is of non-class type 'int' as_.setSucceeded(result_);
We have a bunch of errors, so, let’s look at the first one first, which says:
The problem is almost the same as before. Instead of using ActionMsgAction, we used ActionMsg. Let’s fix that on line 11, and try to compile again:
Congratulations, now everything compiled as expected:
Scanning dependencies of target rotw4_action_node [ 97%] Building CXX object rotw4_code/CMakeFiles/rotw4_action_node.dir/src/rotw4_action.cpp.o [100%] Linking CXX executable /home/user/catkin_ws/devel/lib/rotw4_code/rotw4_action_node [100%] Built target rotw4_action_node Scanning dependencies of target rotw4_code_generate_messages [100%] Built target rotw4_code_generate_messages
Now, let’s run our action server:
Now we could try to make the robot take off by running the following command in a different web shell:
The only problem is that the robot doesn’t move as expected yet, although the action server says succeeded.
rotw4_action: Succeeded
If we look the file rotw4_action.cpp, in the executeCB method, everything seems to be correct.
void executeCB(const rotw4_code::ActionMsgGoalConstPtr &goal) { std::string upDown = goal->goal; takeoff_pub_ = nh_.advertise<std_msgs::Empty>("/drone/takeoff", 1000); land_pub_ = nh_.advertise<std_msgs::Empty>("/drone/land", 1000); // check that preempt has not been requested by the client if (as_.isPreemptRequested() || !ros::ok()) { ROS_INFO("%s: Preempted", action_name_.c_str()); // set the action state to preempted as_.setPreempted(); success_ = false; } if (upDown == "UP") { takeoff_pub_.publish(takeoff_msg_); feedback_.feedback = "Taking Off Drone..."; } if (upDown == "DOWN") { land_pub_.publish(land_msg_); feedback_.feedback = "Landing Drone..."; } // feedback_.feedback = i; // publish the feedback as_.publishFeedback(feedback_); if (success_) { ROS_INFO("%s: Succeeded", action_name_.c_str()); // set the action state to succeeded as_.setSucceeded(result_); } }
The problem is that we are instantiating the topic publishers and publishing on them straight away, and the topics need some time after being defined to start being used. To solve this, let’s add a while loop to publish at least 4 times, once a second:
void executeCB(const rotw4_code::ActionMsgGoalConstPtr &goal) { std::string upDown = goal->goal; takeoff_pub_ = nh_.advertise<std_msgs::Empty>("/drone/takeoff", 1000); land_pub_ = nh_.advertise<std_msgs::Empty>("/drone/land", 1000); ros::Rate rate(1); // check that preempt has not been requested by the client if (as_.isPreemptRequested() || !ros::ok()) { ROS_INFO("%s: Preempted", action_name_.c_str()); // set the action state to preempted as_.setPreempted(); success_ = false; } if (upDown == "UP") { int i = 0; while (i < 4) { takeoff_pub_.publish(takeoff_msg_); feedback_.feedback = "Taking Off Drone..."; i++; rate.sleep(); } } if (upDown == "DOWN") { land_pub_.publish(land_msg_); feedback_.feedback = "Landing Drone..."; } // feedback_.feedback = i; // publish the feedback as_.publishFeedback(feedback_); if (success_) { ROS_INFO("%s: Succeeded", action_name_.c_str()); // set the action state to succeeded as_.setSucceeded(result_); } }
If we now compile the code again
run the node:
and publish the message to take off again:
now the robot should work as expected.
