ROS Mini Challenge #9 – Fusing data to improve robot localization with ROS
07/03/2020
Learn how to improve robot localization with data from different sensors
Where to find the code
Once you open the ROSject (buff.ly/2RifSjn), you will get a copy of it. You just have to click Open. Once open, inside the catkin_ws folder, you will find all the ROS packages associated with this challenge. You can have a look at it using the IDE, for instance.
To see the full code, open the IDE by going to the top menu and select Tools->IDE.
Code Editor (IDE) - ROSDS
Code Editor (IDE) – ROSDS
Launching the simulation
Go to the top menu and select Simulations. On the menu that appears, click on the Choose launch file… button.
Choose lunch file to open simulation in ROSDS
Now, from the launch files list, select the launch file named rotw9.launch from the sumit_xl_course_basics package.
ROS Mini Challenge #9 - Select launch file
ROS Mini Challenge #9 – Select launch file
Finally, click on the Launch button to start the simulation. In the end, you should get something like this:
Summit XL gazebo simulation in ROSDS, ROSject of the week
The problem to be solved
As you can see, this ROSject contains 1 package inside its catkin_ws workspace: rotw9_pkg. This package contains a launch file and a configuration file, which are used to start an ekf localization node. This node is provided by the robot_localization package, and its main purpose is to fuse different sensor data inputs in order to improve the localization of a robot.
In our case, we are going to fuse Odometry data (which has been tweaked) with Imu data (which is correct). So, the main purpose of this challenge is to improve the Summit XL odometry data, since the initial one is a little bit distorted.
In order to test that it works as expected, first of all, we need to know the odometry topics. For this, we can use the following command:
rostopic list | grep odom
This command will give us the following topics:
/noisy_odom
/robotnik_base_control/odom
For this challenge, we are going to use the /noisy_odom topic, which basically is the original odometry data with some extra noise added to it.
You can have a look at the current odometry using RViz (rosrun rviz rviz ) and adding an Odometry display. You should get something similar to this:
Noisy Odometry example in ROSDS
As you can see, the Odometry readings are not very stable.
So now let’s start our node in order to correct the odometry readings with the following command:
roslaunch rotw9_pkg start_ekf_localization.launch
This command will generate a new Odometry topic, named /odometry/filtered, which will contain the resulting Odometry data (fusing the /noisy_odom data with the Imu data).
If you visualize this new Odometry, you will get something like this. As you can see, the new Odometry is much more stable than the original one. Great!
Correct (expected) Odometry data in ROSDS
NOTE: In order to properly visualize the differences between the 2 Odometry readings, you should modify the arrow size and color on the different displays.
Solving the ROS Mini Challenge
Ok, so… where’s the problem? If you have tried to reproduce the steps described above you have already seen that it DOES NOT WORK. When you run the programs introduced above, they just don’t work. The /odometry/filtered is not shown as expected in RViz (the red arrow that appears in RViz).
Let’s start by having a look at the files inside the rotw9_pkg package, to figure out where the error (or errors) are.
If we look at the start_ekf_localization.launch  file, everything seems fine:
<!-- Run the EKF Localization node -->
<node pkg="robot_localization" type="ekf_localization_node" name="ekf_localization">
<rosparam command="load" file="$(find rotw9_pkg)/config/ekf_localization.yaml"/>
Since the launch file loads the rotw9_pkg/config/ekf_localization.yaml file, let’s have a look at it:
#Configuation for robot odometry EKF
frequency: 50
two_d_mode: true
publish_tf: false
odom_frame: odom
base_link_frame: base_link
world_frame: odom
odom0: /noisy_odom
odom0_config: [true, true, false,
               false, false, true,
               true, true, false,
               false, false, true,
               false, false, false]
odom0_differential: false
imu0: /imu/data
imu0_config: [false, false, false,
              false, false, true,
              false, false, true,
              true, false, false]
imu0_differential: false
process_noise_covariance": [0.05, 0,    0,    0,    0,    0,    0,     0,     0,    0,    0,    0,    0,    0,    0,
                                              0,    0.05, 0,    0,    0,    0,    0,     0,     0,    0,    0,    0,    0,    0,    0,
                                              0,    0,    0.06, 0,    0,    0,    0,     0,     0,    0,    0,    0,    0,    0,    0,
                                              0,    0,    0,    0.03, 0,    0,    0,     0,     0,    0,    0,    0,    0,    0,    0,
                                              0,    0,    0,    0,    0.03, 0,    0,     0,     0,    0,    0,    0,    0,    0,    0,
                                              0,    0,    0,    0,    0,    0.06, 0,     0,     0,    0,    0,    0,    0,    0,    0,
                                              0,    0,    0,    0,    0,    0,    0.025, 0,     0,    0,    0,    0,    0,    0,    0,
                                              0,    0,    0,    0,    0,    0,    0,     0.025, 0,    0,    0,    0,    0,    0,    0,
                                              0,    0,    0,    0,    0,    0,    0,     0,     0.04, 0,    0,    0,    0,    0,    0,
                                              0,    0,    0,    0,    0,    0,    0,     0,     0,    0.01, 0,    0,    0,    0,    0,
                                              0,    0,    0,    0,    0,    0,    0,     0,     0,    0,    0.01, 0,    0,    0,    0,
                                              0,    0,    0,    0,    0,    0,    0,     0,     0,    0,    0,    0.02, 0,    0,    0,
                                              0,    0,    0,    0,    0,    0,    0,     0,     0,    0,    0,    0,    0.01, 0,    0,
                                              0,    0,    0,    0,    0,    0,    0,     0,     0,    0,    0,    0,    0,    0.01, 0,
                                              0,    0,    0,    0,    0,    0,    0,     0,     0,    0,    0,    0,    0,    0,    0.015]
initial_estimate_covariance: [1e-9, 0,    0,    0,    0,    0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                                                      0,    1e-9, 0,    0,    0,    0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                                                      0,    0,    1e-9, 0,    0,    0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                                                      0,    0,    0,    1e-9, 0,    0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                                                      0,    0,    0,    0,    1e-9, 0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                                                      0,    0,    0,    0,    0,    1e-9, 0,    0,    0,    0,     0,     0,     0,    0,    0,
                                                      0,    0,    0,    0,    0,    0,    1e-9, 0,    0,    0,     0,     0,     0,    0,    0,
                                                      0,    0,    0,    0,    0,    0,    0,    1e-9, 0,    0,     0,     0,     0,    0,    0,
                                                      0,    0,    0,    0,    0,    0,    0,    0,    1e-9, 0,     0,     0,     0,    0,    0,
                                                      0,    0,    0,    0,    0,    0,    0,    0,    0,    1e-9,  0,     0,     0,    0,    0,
                                                      0,    0,    0,    0,    0,    0,    0,    0,    0,    0,     1e-9,  0,     0,    0,    0,
                                                      0,    0,    0,    0,    0,    0,    0,    0,    0,    0,     0,     1e-9,  0,    0,    0,
                                                      0,    0,    0,    0,    0,    0,    0,    0,    0,    0,     0,     0,     1e-9, 0,    0,
                                                      0,    0,    0,    0,    0,    0,    0,    0,    0,    0,     0,     0,     0,    1e-9, 0,
                                                      0,    0,    0,    0,    0,    0,    0,    0,    0,    0,     0,     0,     0,    0,    1e-9]
We are going to explain in deeper the configurations in the YAML file, otherwise, the post would be really big. So, in case you want to understand it better, we highly recommend the Fuse Sensor Data to Improve Localization course in Robot Ignite Academy (www.robotigniteacademy.com/en/).
Ok, let’s go straight to the point.
In the YAML file above, the parameters we are going to focus on are:
odom_frame: odom
world_frame: odom
We see that the are links named odom and base_link. We have to make sure these links exist in the simulation. Let’s do that by generating a TF Tree with the commands below:
rosrun tf view_frames
The commands above generate a file named frames.pdf that contains the full TF Tree of the simulation, with all the connections, the frame names, etc.
You can easily download the frames.pdf using the IDE (Code Editor) by selecting it and clicking Download.
After opening that file, we can see the names of the links:
TF Tree for Summit XL Simulation
As we can see, the Odom link is actually named summit_xl_a_odom, and the base_link is named summit_xl_a_base_link. Let’s then fix the Yaml file with the correct values and save the file:
odom_frame:summit_xl_a_odom
base_link_frame:summit_xl_a_base_link
world_frame:summit_xl_a_odom
Now we can try to launch our localization node again:
Unfortunately, the red arrow in RViz (topic /odometry/filtered) is still not as we expect.
Let’s now check the odom0_config settings in the YAML file:
odom0: /noisy_odom
               false, false, true,
               true, true, false,
               false, false, true,
The error is actually in that matrix.
The first row goes for X, Y and X positions. The second for ROW, PITCH and YAW. The third is for the linear values, the fourth the angular velocities and the final row is for the linear acceleration.
The problem is basically because we are inputting some noise in the X and Y positions. More details on this can be found in the documentation of the robot_localization package. If we just set those values to false, we have the following:
odom0: /noisy_odom
odom0_config: [false, false, false,
               false, false, true,
               true, true, false,
               false, false, true,
If we now try to launch our localization node again, we should see the correct values in RViz:
Remember that if you need a deeper understanding on fusing sensor data, the Fuse Sensor Data to Improve Localization course in Robot Ignite Academy (www.robotigniteacademy.com/en/) can help you.
129. ros2ai
129. ros2ai
