[ROS Projects] – My Robotic Manipulator #6 – STL Mesh file for URDF Link
[ROS-Projects]---My-Robotic-Manipulator-#6---STL-Mesh-file-for-URDF-Link
Written by Marco Arruda
06/07/2018
In this video we are going to set a .STL mesh file to one of the links of our robot using its URDF code. From the URDF model used in the previous videos, we are going to define a new XML MACRO to use mesh files for a given link. Up to the end of the video, we will be able to see the mesh in RViz and Gazebo simulator.
Repositories:
Robot description: https://bitbucket.org/theconstructcore/my-robotic-manipulator/src
URDF Course: https://goo.gl/PNEgCX
Robot Ignite Academy: https://goo.gl/1bg1UV
ROS Development Studio: https://goo.gl/wL5Mxz
Step 1. Meshes
Create e folder called meshes under the mrm_description directory and drag the .stl file you want into it.
Step 2. Modify the .xarco file
For easier test and debug, let’s comment out the other links in the mrm.xarco file.
           axis_xyz="0 1 0"
           parent="link_01" child="link_02"
           limit_e="1000" limit_l="0" limit_u="0.5" limit_v="0.5" />
              mass="57.906"
              ixx="12.679" ixy="0" ixz="0"
              iyy="12.679" iyz="0"
              izz="0.651"
              radius="0.15" length="0.8" />
           axis_xyz="0 1 0"
           parent="link_02" child="link_03"
           limit_e="1000" limit_l="0" limit_u="0.75" limit_v="0.5" />
              mass="57.906"
              izz="0.651"
           axis_xyz="0 1 0"
           parent="link_03" child="link_04"
              mass="57.906"
              izz="0.651"
           axis_xyz="0 0 1"
           parent="link_04" child="link_05"
           limit_e="1000" limit_l="-3.14" limit_u="3.14" limit_v="0.5" />
              mass="18.056"
              ixx="0.479" ixy="0" ixz="0"
              iyy="0.479" iyz="0"
              izz="0.204"
Then we define a new mesh called m_link_mesh in the links_joints.xarco with the following content
  <xacro:macro name="m_link_mesh" params="name origin_xyz origin_rpy meshfile meshscale mass ixx ixy ixz iyy iyz izz">
    <link name="${name}">
      <inertial>
        <mass value="${mass}" />
        <inertia ixx="${ixx}" ixy="${ixy}" ixz="${ixz}" iyy="${iyy}" iyz="${iyz}" izz="${izz}" />
      </inertial>
      <collision>
          <mesh filename="${meshfile}" scale="${meshscale}"/>
      </collision>
      <visual>
        <material name="light_black"/>
  </xacro:macro>
Please notice that in the params, we added two new property called meshfile and meshscale.
Since we are now using the mesh instead of a cylinder, let’s go back to the mrm.xarco and change it.
  <m_link_mesh name="${link_01_name}"
              mass="157.633"
              ixx="13.235" ixy="0" ixz="0"
              iyy="13.235" iyz="0"
              izz="9.655"
              meshfile="package://mrm_description/meshes/Link1-v2.stl"
              meshscale="0.001 0.001 0.001" />
Please make sure the meshscale is correct for your .stl file. In the simulation, the scale is in m. We change the meshscale to 0.001 because the stl file is done on the scale of mm.
Step 2. Modify the launch file
Since we only use one joint, we’ll only need the controller for one joint. Let’s change this part in the /launch/spawn.launch
        <!-- Controllers -->
            args="--namespace=/mrm
            joint_state_controller
            joint1_position_controller
            --timeout 60">
Step 3. Launch the description in RViz and Gazebo
You can launch the RViz with the following command. After launching, please go to tools->graphical tool. You will see the RViz is open.
roslaunch mrm_description rviz.launch
After launching, we noticed that the link is not in the correct position, let’s go back to the mrm.xarco file and give it a proper offset.
              origin_rpy="0 0 0" origin_xyz="0 0 -0.1"
              mass="157.633"
              izz="9.655"
You can also spawn the robot in gazebo, please go to Simulations->Empty to open a simulation the run the following command to spawn the robot
