[ROS Projects] OpenAI with Moving Cube Robot in Gazebo Step-by-Step Part2
OpenAI-with-Moving-Cube-Robot-in-Gazebo-Step-by-Step-Part2
Written by Miguel Angel
25/06/2018
In this new ROS Project you are going to learn Step-by-Step how to create a moving cube and that it learns to move using OpenAI environment.
This second video is for learning the creation the basics of Reinforcement learning and how to connect to the various systems of the robot to get the state, perform actions and calculate rewards.
ROS Development Studio
OpenAi Course
Moving Cube Git:https://bitbucket.org/theconstructcore/moving_cube/src/master/
Moving Cube Training AI Git: https://bitbucket.org/theconstructcore/moving_cube_training/src/master/
If you didn’t follow up, please check the link below for the last post.
[irp posts=”9744″ name=”[ROS Projects] OpenAI with Moving Cube Robot in Gazebo Step-by-Step Part1″]
Step 1. Clone the simulation
In order to make sure we have the same project. Please run the following command
cd ~/simulation_ws/src
git clone https://bitbucket.org/theconstructcore/moving_cube.git
NOTICE: please delete the previous code if you have problems to compile the code
In the /moving_cube/moving_cube_description/urdf/moving_cube.urdf file, please uncomment the following part. We’ll need this part to publish the odom topic.
    <gazebo>
        <plugin name="p3d_base_controller" filename="libgazebo_ros_p3d.so">
            <robotNamespace>/moving_cube</robotNamespace>
            <alwaysOn>true</alwaysOn>
            <updateRate>50.0</updateRate>
            <bodyName>cube_body</bodyName>
            <topicName>odom</topicName>
            <gaussianNoise>0.01</gaussianNoise>
            <frameName>world</frameName>
            <xyzOffsets>0 0 0</xyzOffsets>
            <rpyOffsets>0 0 0</rpyOffsets>
        </plugin>
    </gazebo>
Step 2. Create a training package
To train the robot, let’s create a package for training under the catkin_ws/src
catkin_create_pkg my_moving_cube_traning_pkg rospy
Then we’ll create a script folder inside the package and put a file called cube_rl_utils.py inside it with the following content
import time
import copy
import numpy
from tf.transformations import euler_from_quaternion
class CubeRLUtils(object):
        self.check_all_sensors_ready()
        rospy.Subscriber("/moving_cube/joint_states", JointState, self.joints_callback)
        rospy.Subscriber("/moving_cube/odom", Odometry, self.odom_callback)
        self._roll_vel_pub = rospy.Publisher('/moving_cube/inertia_wheel_roll_joint_velocity_controller/command', Float64, queue_size=1)
    def check_all_sensors_ready(self):
        self.disk_joints_data = None
        while self.disk_joints_data is None and not rospy.is_shutdown():
                self.disk_joints_data = rospy.wait_for_message("/moving_cube/joint_states", JointState, timeout=1.0)
                rospy.loginfo("Current moving_cube/joint_states READY=>"+str(self.disk_joints_data))
            except:
                rospy.logerr("Current moving_cube/joint_states not ready yet, retrying for getting joint_states")
        self.cube_odom_data = None
                self.cube_odom_data = rospy.wait_for_message("/moving_cube/odom", Odometry, timeout=1.0)
                rospy.loginfo("Current /moving_cube/odom READY=>" + str(self.cube_odom_data))
            except:
                rospy.logerr("Current /moving_cube/odom not ready yet, retrying for getting odom")
        rospy.loginfo("ALL SENSORS READY")
        :return:
        rate = rospy.Rate(10)  # 10hz
        while (self._roll_vel_pub.get_num_connections() == 0 and not rospy.is_shutdown()):
            rospy.loginfo("No susbribers to _roll_vel_pub yet so we wait and try again")
                pass
        rospy.loginfo("_base_pub Publisher Connected")
        rospy.loginfo("All Publishers READY")
    def joints_callback(self, data):
        self.joints = data
    def odom_callback(self, data):
        self.odom = data
    # Reinforcement Learning Utility Code
    def move_joints(self, roll_speed):
        joint_speed_value = Float64()
        joint_speed_value.data = roll_speed
        rospy.loginfo("Single Disk Roll Velocity>>"+str(joint_speed_value))
        self._roll_vel_pub.publish(joint_speed_value)
    def get_cube_state(self):
        # We convert from quaternions to euler
        orientation_list = [self.odom.pose.pose.orientation.x,
                            self.odom.pose.pose.orientation.y,
                            self.odom.pose.pose.orientation.z,
                            self.odom.pose.pose.orientation.w]
        roll, pitch, yaw = euler_from_quaternion(orientation_list)
        # We get the distance from the origin
        start_position = Point()
        start_position.x = 0.0
        start_position.y = 0.0
        start_position.z = 0.0
        distance = self.get_distance_from_point(start_position,
                                                self.odom.pose.pose.position)
        cube_state = [
                        round(self.joints.velocity[0],1),
                        round(distance,1),
                        round(roll,1),
                        round(pitch,1),
                        round(yaw,1)
        return cube_state
    def observation_checks(self, cube_state):
        # MAximum distance to travel permited in meters from origin
        max_distance=2.0
        if (cube_state[1] > max_distance):
            rospy.logerr("Cube Too Far==>"+str(cube_state[1]))
            done = True
            rospy.loginfo("Cube NOT Too Far==>"+str(cube_state[1]))
            done = False
        return done
    def get_distance_from_point(self, pstart, p_end):
        Given a Vector3 Object, get distance from current position
        :param p_end:
        :return:
        a = numpy.array((pstart.x, pstart.y, pstart.z))
        b = numpy.array((p_end.x, p_end.y, p_end.z))
        distance = numpy.linalg.norm(a - b)
        return distance
    def get_reward_for_observations(self, state):
        # We reward it for lower speeds and distance traveled
        speed = state[0]
        distance = state[1]
        # Positive Reinforcement
        reward_distance = distance * 10.0
        # Negative Reinforcement for magnitude of speed
        reward_for_efective_movement = -1 * abs(speed)
        reward = reward_distance + reward_for_efective_movement
        rospy.loginfo("Reward_distance="+str(reward_distance))
        rospy.loginfo("Reward_for_efective_movement= "+str(reward_for_efective_movement))
        return reward
def cube_rl_systems_test():
    rospy.init_node('cube_rl_systems_test_node', anonymous=True, log_level=rospy.INFO)
    cube_rl_utils_object = CubeRLUtils()
    rospy.loginfo("Moving to Speed==>80")
    cube_rl_utils_object.move_joints(roll_speed=80.0)
    time.sleep(2)
    rospy.loginfo("Moving to Speed==>-80")
    cube_rl_utils_object.move_joints(roll_speed=-80.0)
    time.sleep(2)
    rospy.loginfo("Moving to Speed==>0.0")
    cube_rl_utils_object.move_joints(roll_speed=0.0)
    time.sleep(2)
    cube_state = cube_rl_utils_object.get_cube_state()
    done = cube_rl_utils_object.observation_checks(cube_state)
    reward = cube_rl_utils_object.get_reward_for_observations(cube_state)
    rospy.loginfo("Done==>"+str(done))
    rospy.loginfo("Reward==>"+str(reward))
if __name__ == "__main__":
In this post, we’ll focus on the cube_rl_systems_test() function. The function uses the class to move the cube, get the observation, calculate reward and check if it’s done. To run it, you have to run the simulation first. Please go to Simulations->Select launch file-> main.launch
NOTICE: You have to unpause the simulation by clicking the arrow key in the simulation window
Then you can run the following command to run the script
cd ~/catkin_ws/src/my_moving_cube_training_pkg/script
chmod +x cube_rl_utils.py
source devel_setup.bash
rosrun my_moving_cube_training_pkg cube_rl_utils.py
You should see the cube moving around and the reward and the done state is calculated.
[irp posts=”9976″ name=”ROS Projects OpenAI with Moving Cube Robot in Gazebo Step-by-Step Part3″]
Trackbacks/Pingbacks
  1. [ROS Projects] OpenAI with Moving Cube Robot in Gazebo Step-by-Step Part3 | The Construct - […] https://www.theconstruct.ai/ros-projects-openai-moving-cube-robot-gazebo-step-step-part2/ […]
  2. [ROS Projects] OpenAI with Moving Cube Robot in Gazebo Step-by-Step #Part1 - […] Part 2: Basics of Reinforcement learning and Connect to the various systems of the robot […]
The Construct
131. The Truth About ROS Jobs
