[ROS Projects] OpenAI with Moving Cube Robot in Gazebo Step-by-Step #Part5
Written by Miguel Angel
16/07/2018
In this new ROS Project you are going to learn Step-by-Step how to create a robot cube that moves and that it learns to move using OpenAI environment.
In this fifth and last video of the cube series, we create the Robot environment for OpenAI Gym for the moving cube. You will learn all the details on why we do it like this and we finally execute the script to make the robot cube learn how to walk in one direction.
For any suggestion on the next AI project that we could do, please leave us a comment, we will be happy to hear your ideas :).
OpenAi Course
Moving Cube Git:
https://bitbucket.org/theconstructcore/moving_cube/src/master/
Moving Cube Training AI Git:
https://bitbucket.org/theconstructcore/moving_cube_ai/src/master/
Step 0. If you didn’t follow up
This is a series posts using ROS Development Studio(ROSDS). In case you haven’t had an account yet, you can create one for free here.
You can find the last post down below:
https://www.theconstruct.ai/ros-projects-openai-moving-cube-robot-gazebo-step-step-part4/
Step 1. Create gym environment file
We’ll start by creating a file called old_way_moving_cube_env.py under the my_moving_cube_training_pkg/script directory with the following content
import gym
import time
import numpy as np
import copy
from gym import utils, spaces
import numpy
from rosgraph_msgs.msg import Clock
from gazebo_connection import GazeboConnection
from controllers_connection import ControllersConnection
from gym.utils import seeding
from tf.transformations import euler_from_quaternion
reg = register(
    id='MyOldMovingCube-v0',
    entry_point='old_way_moving_cube_env:MyOldMovingCubeEnv',
    timestep_limit=1000,
class MyOldMovingCubeEnv(gym.Env):
        number_actions = rospy.get_param('/moving_cube/n_actions')
        self.action_space = spaces.Discrete(number_actions)
        self._seed()
        #get configuration parameters
        self.init_roll_vel = rospy.get_param('/moving_cube/init_roll_vel')
        # Actions
        self.roll_speed_fixed_value = rospy.get_param('/moving_cube/roll_speed_fixed_value')
        self.roll_speed_increment_value = rospy.get_param('/moving_cube/roll_speed_increment_value')
        self.start_point = Point()
        self.start_point.x = rospy.get_param("/moving_cube/init_cube_pose/x")
        self.start_point.y = rospy.get_param("/moving_cube/init_cube_pose/y")
        self.start_point.z = rospy.get_param("/moving_cube/init_cube_pose/z")
        # Done
        self.max_pitch_angle = rospy.get_param('/moving_cube/max_pitch_angle')
        # Rewards
        self.move_distance_reward_weight = rospy.get_param("/moving_cube/move_distance_reward_weight")
        self.y_linear_speed_reward_weight = rospy.get_param("/moving_cube/y_linear_speed_reward_weight")
        self.y_axis_angle_reward_weight = rospy.get_param("/moving_cube/y_axis_angle_reward_weight")
        self.end_episode_points = rospy.get_param("/moving_cube/end_episode_points")
        # stablishes connection with simulator
        self.gazebo = GazeboConnection()
        self.controllers_list = ['joint_state_controller',
                         'inertia_wheel_roll_joint_velocity_controller'
        self.controllers_object = ControllersConnection(namespace="moving_cube",
                                                        controllers_list=self.controllers_list)
        self.gazebo.unpauseSim()
        self.controllers_object.reset_controllers()
        self.check_all_sensors_ready()
        rospy.Subscriber("/moving_cube/joint_states", JointState, self.joints_callback)
        rospy.Subscriber("/moving_cube/odom", Odometry, self.odom_callback)
        self._roll_vel_pub = rospy.Publisher('/moving_cube/inertia_wheel_roll_joint_velocity_controller/command', Float64, queue_size=1)
        self.gazebo.pauseSim()
    def _seed(self, seed=None): #overriden function
        self.np_random, seed = seeding.np_random(seed)
        return [seed]
    def _step(self, action):#overriden function
        self.set_action(action)
        obs = self._get_obs()
        done = self._is_done(obs)
        info = {}
        reward = self.compute_reward(obs, done)
        simplified_obs = self.convert_obs_to_state(obs)
        return simplified_obs, reward, done, info
    def _reset(self):
        self.set_init_pose()
        self.gazebo.resetSim()
        self.init_env_variables()
    def init_env_variables(self):
        Inits variables needed to be initialised each time we reset at the start
        of an episode.
        :return:
        self.total_distance_moved = 0.0
        self.current_y_distance = self.get_y_dir_distance_from_start_point(self.start_point)
        self.roll_turn_speed = rospy.get_param('/moving_cube/init_roll_vel')
    def _is_done(self, observations):
        pitch_angle = observations[3]
        if abs(pitch_angle) > self.max_pitch_angle:
            rospy.logerr("WRONG Cube Pitch Orientation==>" + str(pitch_angle))
            done = True
            rospy.logdebug("Cube Pitch Orientation Ok==>" + str(pitch_angle))
            done = False
        return done
    def set_action(self, action):
        # We convert the actions to speed movements to send to the parent class CubeSingleDiskEnv
        if action == 0:# Move Speed Wheel Forwards
            self.roll_turn_speed = self.roll_speed_fixed_value
        elif action == 1:# Move Speed Wheel Backwards
        elif action == 2:# Stop Speed Wheel
            self.roll_turn_speed = 0.0
        elif action == 3:# Increment Speed
            self.roll_turn_speed += self.roll_speed_increment_value
        elif action == 4:# Decrement Speed
            self.roll_turn_speed -= self.roll_speed_increment_value
        # We clamp Values to maximum
        rospy.logdebug("roll_turn_speed before clamp=="+str(self.roll_turn_speed))
        self.roll_turn_speed = numpy.clip(self.roll_turn_speed,
                                          -1*self.roll_speed_fixed_value,
                                          self.roll_speed_fixed_value)
        rospy.logdebug("roll_turn_speed after clamp==" + str(self.roll_turn_speed))
        # We tell the OneDiskCube to spin the RollDisk at the selected speed
        self.move_joints(self.roll_turn_speed)
    def _get_obs(self):
        Here we define what sensor data defines our robots observations
        To know which Variables we have acces to, we need to read the
        MyCubeSingleDiskEnv API DOCS
        :return:
        # We get the orientation of the cube in RPY
        roll, pitch, yaw = self.get_orientation_euler()
        # We get the distance from the origin
        # We get the current speed of the Roll Disk
        current_disk_roll_vel = self.get_roll_velocity()
        # We get the linear speed in the y axis
        y_linear_speed = self.get_y_linear_speed()
        cube_observations = [
            round(current_disk_roll_vel, 0),
            round(y_distance, 1),
            round(roll, 1),
            round(pitch, 1),
            round(y_linear_speed,1),
            round(yaw, 1),
        return cube_observations
    def get_orientation_euler(self):
        # We convert from quaternions to euler
        orientation_list = [self.odom.pose.pose.orientation.x,
                            self.odom.pose.pose.orientation.y,
                            self.odom.pose.pose.orientation.z,
                            self.odom.pose.pose.orientation.w]
        roll, pitch, yaw = euler_from_quaternion(orientation_list)
        return roll, pitch, yaw
    def get_roll_velocity(self):
        # We get the current joint roll velocity
        roll_vel = self.joints.velocity[0]
        return roll_vel
    def get_y_linear_speed(self):
        y_linear_speed = self.odom.twist.twist.linear.y
        return y_linear_speed
    def get_y_dir_distance_from_start_point(self, start_point):
        Calculates the distance from the given point and the current position
        given by odometry. In this case the increase or decrease in y.
        :param start_point:
        :return:
        y_dist_dir = self.odom.pose.pose.position.y - start_point.y
        return y_dist_dir
    def compute_reward(self, observations, done):
        if not done:
            y_distance_now = observations[1]
            delta_distance = y_distance_now - self.current_y_distance
            rospy.logdebug("y_distance_now=" + str(y_distance_now)+", current_y_distance=" + str(self.current_y_distance))
            rospy.logdebug("delta_distance=" + str(delta_distance))
            reward_distance = delta_distance * self.move_distance_reward_weight
            self.current_y_distance = y_distance_now
            y_linear_speed = observations[4]
            rospy.logdebug("y_linear_speed=" + str(y_linear_speed))
            reward_y_axis_speed = y_linear_speed * self.y_linear_speed_reward_weight
            # Negative Reward for yaw different from zero.
            yaw_angle = observations[5]
            rospy.logdebug("yaw_angle=" + str(yaw_angle))
            # Worst yaw is 90 and 270 degrees, best 0 and 180. We use sin function for giving reward.
            sin_yaw_angle = math.sin(yaw_angle)
            rospy.logdebug("sin_yaw_angle=" + str(sin_yaw_angle))
            reward_y_axis_angle = -1 * abs(sin_yaw_angle) * self.y_axis_angle_reward_weight
            # We are not intereseted in decimals of the reward, doesnt give any advatage.
            reward = round(reward_distance, 0) + round(reward_y_axis_speed, 0) + round(reward_y_axis_angle, 0)
            rospy.logdebug("reward_distance=" + str(reward_distance))
            rospy.logdebug("reward_y_axis_speed=" + str(reward_y_axis_speed))
            rospy.logdebug("reward_y_axis_angle=" + str(reward_y_axis_angle))
            rospy.logdebug("reward=" + str(reward))
            reward = -1*self.end_episode_points
        return reward
    def joints_callback(self, data):
        self.joints = data
    def odom_callback(self, data):
        self.odom = data
    def check_all_sensors_ready(self):
        self.check_joint_states_ready()
        self.check_odom_ready()
        rospy.logdebug("ALL SENSORS READY")
    def check_joint_states_ready(self):
        self.joints = None
        while self.joints is None and not rospy.is_shutdown():
                self.joints = rospy.wait_for_message("/moving_cube/joint_states", JointState, timeout=1.0)
                rospy.logdebug("Current moving_cube/joint_states READY=>" + str(self.joints))
            except:
                rospy.logerr("Current moving_cube/joint_states not ready yet, retrying for getting joint_states")
        return self.joints
    def check_odom_ready(self):
        self.odom = None
        while self.odom is None and not rospy.is_shutdown():
                self.odom = rospy.wait_for_message("/moving_cube/odom", Odometry, timeout=1.0)
                rospy.logdebug("Current /moving_cube/odom READY=>" + str(self.odom))
            except:
                rospy.logerr("Current /moving_cube/odom not ready yet, retrying for getting odom")
        return self.odom
        :return:
        rate = rospy.Rate(10)  # 10hz
        while (self._roll_vel_pub.get_num_connections() == 0 and not rospy.is_shutdown()):
            rospy.logdebug("No susbribers to _roll_vel_pub yet so we wait and try again")
                pass
        rospy.logdebug("_base_pub Publisher Connected")
        rospy.logdebug("All Publishers READY")
    def move_joints(self, roll_speed):
        joint_speed_value = Float64()
        joint_speed_value.data = roll_speed
        rospy.logdebug("Single Disk Roll Velocity>>" + str(joint_speed_value))
        self._roll_vel_pub.publish(joint_speed_value)
        self.wait_until_roll_is_in_vel(joint_speed_value.data)
    def wait_until_roll_is_in_vel(self, velocity):
        start_wait_time = rospy.get_rostime().to_sec()
        end_wait_time = 0.0
        epsilon = 0.1
        v_plus = velocity + epsilon
        v_minus = velocity - epsilon
            joint_data = self.check_joint_states_ready()
            roll_vel = joint_data.velocity[0]
            rospy.logdebug("VEL=" + str(roll_vel) + ", ?RANGE=[" + str(v_minus) + ","+str(v_plus)+"]")
            are_close = (roll_vel <= v_plus) and (roll_vel > v_minus)
            if are_close:
                rospy.logdebug("Reached Velocity!")
                end_wait_time = rospy.get_rostime().to_sec()
                break
            rospy.logdebug("Not there yet, keep waiting...")
        delta_time = end_wait_time- start_wait_time
        rospy.logdebug("[Wait Time=" + str(delta_time)+"]")
        return delta_time
    def set_init_pose(self):
        """Sets the Robot in its init pose
        self.move_joints(self.init_roll_vel)
        return True
    def convert_obs_to_state(self,observations):
        Converts the observations used for reward and so on to the essentials for the robot state
        In this case we only need the orientation of the cube and the speed of the disc.
        The distance doesnt condition at all the actions
        disk_roll_vel = observations[0]
        state_converted = [disk_roll_vel, y_linear_speed, yaw_angle]
        return state_converted
From line 22 to line 26 is the most important part of the file. You have to register your environment to OpenAI gym.
In the _get_obs() function in line 169 to line 198, the observation is measured from the simulation and will be used to generate a state.
The set_action() function in line 144 to line 166 executes the action decided by the q learning algorithm.
From line 88 to 188, the code defines what should the environment do when the algorithm runs into step or reset state.
The reward and checking if the training session is done or not is done in the __step() function.
In _reset() function, the environment will at first pause the gazebo simulation and reset the controller. In order to connect to gazebo and controller, we create a file called gazebo_connection.py under the same folder with the following content
from std_srvs.srv import Empty
from gazebo_msgs.msg import ODEPhysics
from gazebo_msgs.srv import SetPhysicsProperties, SetPhysicsPropertiesRequest
from geometry_msgs.msg import Vector3
class GazeboConnection():
        self.unpause = rospy.ServiceProxy('/gazebo/unpause_physics', Empty)
        self.pause = rospy.ServiceProxy('/gazebo/pause_physics', Empty)
        self.reset_proxy = rospy.ServiceProxy('/gazebo/reset_simulation', Empty)
        # Setup the Gravity Controle system
        service_name = '/gazebo/set_physics_properties'
        rospy.logdebug("Waiting for service " + str(service_name))
        rospy.wait_for_service(service_name)
        rospy.logdebug("Service Found " + str(service_name))
        self.set_physics = rospy.ServiceProxy(service_name, SetPhysicsProperties)
        self.init_values()
        # We always pause the simulation, important for legged robots learning
        self.pauseSim()
    def pauseSim(self):
        rospy.wait_for_service('/gazebo/pause_physics')
            self.pause()
        except rospy.ServiceException as e:
            print ("/gazebo/pause_physics service call failed")
    def unpauseSim(self):
        rospy.wait_for_service('/gazebo/unpause_physics')
            self.unpause()
            print ("/gazebo/unpause_physics service call failed")
    def resetSim(self):
        rospy.wait_for_service('/gazebo/reset_simulation')
            self.reset_proxy()
            print ("/gazebo/reset_simulation service call failed")
    def resetWorld(self):
        rospy.wait_for_service('/gazebo/reset_world')
            self.reset_proxy()
            print ("/gazebo/reset_world service call failed")
    def init_values(self):
            # reset_proxy.call()
            self.reset_proxy()
        self._time_step = Float64(0.001)
        self._max_update_rate = Float64(1000.0)
        self._gravity = Vector3()
        self._gravity.x = 0.0
        self._gravity.y = 0.0
        self._gravity.z = -9.81
        self._ode_config = ODEPhysics()
        self._ode_config.auto_disable_bodies = False
        self._ode_config.sor_pgs_precon_iters = 0
        self._ode_config.sor_pgs_iters = 50
        self._ode_config.sor_pgs_w = 1.3
        self._ode_config.sor_pgs_rms_error_tol = 0.0
        self._ode_config.contact_surface_layer = 0.001
        self._ode_config.contact_max_correcting_vel = 0.0
        self._ode_config.cfm = 0.0
        self._ode_config.erp = 0.2
        self._ode_config.max_contacts = 20
        self.update_gravity_call()
    def update_gravity_call(self):
        self.pauseSim()
        set_physics_request = SetPhysicsPropertiesRequest()
        set_physics_request.time_step = self._time_step.data
        set_physics_request.max_update_rate = self._max_update_rate.data
        set_physics_request.gravity = self._gravity
        set_physics_request.ode_config = self._ode_config
        rospy.logdebug(str(set_physics_request.gravity))
        result = self.set_physics(set_physics_request)
        rospy.logdebug("Gravity Update Result==" + str(result.success) + ",message==" + str(result.status_message))
        self.unpauseSim()
    def change_gravity(self, x, y, z):
        self._gravity.x = x
        self._gravity.y = y
        self._gravity.z = z
Then we create another file called controllers_connection.py with the following content
import time
from controller_manager_msgs.srv import SwitchController, SwitchControllerRequest, SwitchControllerResponse
class ControllersConnection():
    def __init__(self, namespace, controllers_list):
        self.controllers_list = controllers_list
        self.switch_service_name = '/'+namespace+'/controller_manager/switch_controller'
        self.switch_service = rospy.ServiceProxy(self.switch_service_name, SwitchController)
    def switch_controllers(self, controllers_on, controllers_off, strictness=1):
        Give the controllers you want to switch on or off.
        :param controllers_on: ["name_controler_1", "name_controller2",...,"name_controller_n"]
        :param controllers_off: ["name_controler_1", "name_controller2",...,"name_controller_n"]
        :return:
        rospy.wait_for_service(self.switch_service_name)
            switch_request_object = SwitchControllerRequest()
            switch_request_object.start_controllers = controllers_on
            switch_request_object.start_controllers = controllers_off
            switch_request_object.strictness = strictness
            switch_result = self.switch_service(switch_request_object)
            [controller_manager_msgs/SwitchController]
            int32 BEST_EFFORT=1
            int32 STRICT=2
            string[] start_controllers
            string[] stop_controllers
            int32 strictness
            bool ok
            rospy.logdebug("Switch Result==>"+str(switch_result.ok))
            return switch_result.ok
            print (self.switch_service_name+" service call failed")
            return None
    def reset_controllers(self):
        We turn on and off the given controllers
        :param controllers_reset: ["name_controler_1", "name_controller2",...,"name_controller_n"]
        :return:
        reset_result = False
        result_off_ok = self.switch_controllers(controllers_on = [],
                                controllers_off = self.controllers_list)
        rospy.logdebug("Deactivated Controlers")
        if result_off_ok:
            rospy.logdebug("Activating Controlers")
            result_on_ok = self.switch_controllers(controllers_on=self.controllers_list,
                                                    controllers_off=[])
            if result_on_ok:
                rospy.logdebug("Controllers Reseted==>"+str(self.controllers_list))
                reset_result = True
                rospy.logdebug("result_on_ok==>" + str(result_on_ok))
            rospy.logdebug("result_off_ok==>" + str(result_off_ok))
        return reset_result
    def update_controllers_list(self, new_controllers_list):
        self.controllers_list = new_controllers_list
Step 2. Start training
Now you have all the script you need for training, let’s create a launch file to launch the training under my_moving_cube_training_pkg/launch with the name start_training.launch
    <rosparam command="load" file="$(find my_moving_cube_training_pkg)/config/one_disk_walk_openai_params.yaml" />
    <node pkg="my_moving_cube_training_pkg" name="movingcube_gym" type="oldway_start_training.py" output="screen"/>
If you already closed the simulation, please start it again from Simulations->select launch file->main.launch
Then run the following command to launch the training.
roslaunch my_moving_cube_training_pkg start_training.launch
You should see the cube robot now moving around to find the best way to move, you can play with different parameters to optimize the training.
If you are interested in this topic, please do not forget to check our OpenAI course at Robot Ignite Academy where you can learn how to create the gym environment for different robots!
Trackbacks/Pingbacks
  1. [ROS Projects] OpenAI with Moving Cube Robot in Gazebo Step-by-Step #Part1 - […] Part 5: Create the Robot environment for OpenAI Gym for the moving cube […]
