[ROS Projects] – Use OpenAI_ROS with Turtlebot2 Step by Step #Part 1
Use-OpenAI_ROS-with-Turtlebot2-Step-by-Step-#Part-1
Written by Miguel Angel
19/07/2018
In this new video series, we are going to learn how to use the openai_ros package created by TheConstruct. You will learn to use it with all the robots that we give suport to. You will learn in this video divided into two parts, how to use openai_ros with Turtlebot2. You will learn how to setup everything to use our package and make it learn how to move around a maze with very little coding.
Here is the git of OpenAi_ros:
https://bitbucket.org/theconstructcore/openai_ros/src/master/
Here is the git to the code generated in this video and the next to come:
https://bitbucket.org/theconstructcore/openai_examples_projects/src/master/
Here a link to the OpenAI 101 course in RobotIgniteAcademy
ROSDS helps you follow our tutorial in a fast pace without dealing without setting up an environment locally. If you haven’t had an account yet, you can create a free account here.
Step 2. Clone the repository and create a package for the project
At first, we have to clone the repositories that we need for this project
cd ~/simulation_ws/src
git clone https://bitbucket.org/theconstructcore/open_ai_gym_construct.git
git clone https://bitbucket.org/theconstructcore/openai_ros.git
You can launch the simulation environment from simulations->Select launch file->gym_construct-main.launch
Inside the open_ai ROS package, we need to specify turtlebot2_maze.py as our task.
We’ll start by creating the folders for the project
mkdir openai_examples_projects/turtle2_open_ai_ros_example
Then create three folder config, launch, and scripts under the directory. Inside the launch folder, let’s create a script called start_training.launch with the following content
    <!-- This version uses the openai_ros environments -->
    <rosparam command="load" file="$(find turtle2_openai_ros_example)/config/turtlebot2_openai_qlearn_params.yaml" />
    <node pkg="turtle2_openai_ros_example" name="turtlebot2_maze" type="start_qlearning.py" output="screen"/>
This launch file will load the parameters first for the algorithm, you can define the parameter in a file called turtlebot2_openai_qlearn_params.yaml in the config folder with the following content
turtlebot2: #namespace
    pos_step: 0.016     # increment in position for each command
    #qlearn parameters
    alpha: 0.1
    gamma: 0.7
    epsilon: 0.9
    epsilon_discount: 0.999
    nepisodes: 500
    nsteps: 10000
    number_splits: 10 #set to change the number of state splits for the continuous problem and also the number of env_variable splits
    running_step: 0.06 # Time for each step
    n_actions: 4 # We have 3 actions, Forwards,TurnLeft,TurnRight,Backwards
    n_observations: 6 # We have 6 different observations
    speed_step: 1.0 # Time to wait in the reset phases
    linear_forward_speed: 0.5 # Spwwed for ging fowards
    linear_turn_speed: 0.05 # Lienare speed when turning
    angular_speed: 0.3 # Angular speed when turning Left or Right
    init_linear_forward_speed: 0.0 # Initial linear speed in which we start each episode
    init_linear_turn_speed: 0.0 # Initial angular speed in shich we start each episode
    new_ranges: 5 # How many laser readings we jump in each observation reading, the bigger the less laser resolution
    min_range: 0.5 # Minimum meters below wich we consider we have crashed
    max_laser_value: 6 # Value considered Ok, no wall
    min_laser_value: 0 # Value considered there is an obstacle or crashed
    desired_pose:
      x: 5.0
      y: 0.0
      z: 0.0
    forwards_reward: 5 # Points Given to go forwards
    turn_reward: 1 # Points Given to turn as action
    end_episode_points: 200 # Points given when ending an episode
Then it will launch the node for qlearning, let’s create two files under the scripts folder. The first one called qlearn.py with the following content which is implemented by Victor Mayoral Vilches. We won’t go into detail here.
Q-learning approach for different RL problems
as part of the basic series on reinforcement learning @
Inspired by https://gym.openai.com/evaluations/eval_kWknKOkPQ7izrixdhriurA
        @author: Victor Mayoral Vilches <victor@erlerobotics.com>
import random
class QLearn:
    def __init__(self, actions, epsilon, alpha, gamma):
        self.q = {}
        self.epsilon = epsilon  # exploration constant
        self.alpha = alpha      # discount constant
        self.gamma = gamma      # discount factor
        self.actions = actions
    def getQ(self, state, action):
        return self.q.get((state, action), 0.0)
    def learnQ(self, state, action, reward, value):
        Q-learning:
            Q(s, a) += alpha * (reward(s,a) + max(Q(s') - Q(s,a))
        oldv = self.q.get((state, action), None)
        if oldv is None:
            self.q[(state, action)] = reward
            self.q[(state, action)] = oldv + self.alpha * (value - oldv)
    def chooseAction(self, state, return_q=False):
        q = [self.getQ(state, a) for a in self.actions]
        maxQ = max(q)
        if random.random() < self.epsilon:
            minQ = min(q); mag = max(abs(minQ), abs(maxQ))
            # add random values to all the actions, recalculate maxQ
            q = [q[i] + random.random() * mag - .5 * mag for i in range(len(self.actions))]
            maxQ = max(q)
        count = q.count(maxQ)
        # In case there're several state-action max values
        # we select a random one among them
        if count > 1:
            best = [i for i in range(len(self.actions)) if q[i] == maxQ]
            i = random.choice(best)
            i = q.index(maxQ)
        action = self.actions[i]
        if return_q: # if they want it, give it!
            return action, q
        return action
    def learn(self, state1, action1, reward, state2):
        maxqnew = max([self.getQ(state2, a) for a in self.actions])
        self.learnQ(state1, action1, reward, reward + self.gamma*maxqnew)
The next one is the training script called start_qlearning.py with the following content
import gym
import numpy
import time
import qlearn
from gym import wrappers
# ROS packages required
import rospkg
from openai_ros.turtlebot2 import turtlebot2_maze
    rospy.init_node('turtlebot2_maze_qlearn', anonymous=True, log_level=rospy.WARN)
    # Create the Gym environment
    env = gym.make('TurtleBot2Maze-v0')
    rospy.loginfo("Gym environment done")
    # Set the logging system
    rospack = rospkg.RosPack()
    pkg_path = rospack.get_path('my_turtlebot2_maze')
    outdir = pkg_path + '/training_results'
    env = wrappers.Monitor(env, outdir, force=True)
    rospy.loginfo("Monitor Wrapper started")
    last_time_steps = numpy.ndarray(0)
    # Loads parameters from the ROS param server
    # Parameters are stored in a yaml file inside the config directory
    # They are loaded at runtime by the launch file
    Alpha = rospy.get_param("/turtlebot2/alpha")
    Epsilon = rospy.get_param("/turtlebot2/epsilon")
    Gamma = rospy.get_param("/turtlebot2/gamma")
    epsilon_discount = rospy.get_param("/turtlebot2/epsilon_discount")
    nepisodes = rospy.get_param("/turtlebot2/nepisodes")
    nsteps = rospy.get_param("/turtlebot2/nsteps")
    running_step = rospy.get_param("/turtlebot2/running_step")
    # Initialises the algorithm that we are going to use for learning
    qlearn = qlearn.QLearn(actions=range(env.action_space.n),
                           alpha=Alpha, gamma=Gamma, epsilon=Epsilon)
    initial_epsilon = qlearn.epsilon
    start_time = time.time()
    highest_reward = 0
    # Starts the main training loop: the one about the episodes to do
    for x in range(nepisodes):
        rospy.logdebug("############### START EPISODE=>" + str(x))
        cumulated_reward = 0
        done = False
        if qlearn.epsilon > 0.05:
            qlearn.epsilon *= epsilon_discount
        # Initialize the environment and get first state of the robot
        observation = env.reset()
        state = ''.join(map(str, observation))
        # Show on screen the actual situation of the robot
        # env.render()
        # for each episode, we test the robot for nsteps
        for i in range(nsteps):
            rospy.logwarn("############### Start Step=>" + str(i))
            # Pick an action based on the current state
            rospy.logwarn("Next action is:%d", action)
            # Execute the action in the environment and get feedback
            rospy.logwarn(str(observation) + " " + str(reward))
            cumulated_reward += reward
            if highest_reward < cumulated_reward:
                highest_reward = cumulated_reward
            # Make the algorithm learn based on the results
            rospy.logwarn("# state we were=>" + str(state))
            rospy.logwarn("# action that we took=>" + str(action))
            rospy.logwarn("# reward that action gave=>" + str(reward))
            rospy.logwarn("# episode cumulated_reward=>" + str(cumulated_reward))
            rospy.logwarn("# State in which we will start next step=>" + str(nextState))
            if not (done):
                rospy.logwarn("NOT DONE")
                state = nextState
                rospy.logwarn("DONE")
                last_time_steps = numpy.append(last_time_steps, [int(i + 1)])
                break
            rospy.logwarn("############### END Step=>" + str(i))
            #raw_input("Next Step...PRESS KEY")
            # rospy.sleep(2.0)
        m, s = divmod(int(time.time() - start_time), 60)
        h, m = divmod(m, 60)
        rospy.logerr(("EP: " + str(x + 1) + " - [alpha: " + str(round(qlearn.alpha, 2)) + " - gamma: " + str(
            round(qlearn.gamma, 2)) + " - epsilon: " + str(round(qlearn.epsilon, 2)) + "] - Reward: " + str(
            cumulated_reward) + "     Time: %d:%02d:%02d" % (h, m, s)))
    rospy.loginfo(("\n|" + str(nepisodes) + "|" + str(qlearn.alpha) + "|" + str(qlearn.gamma) + "|" + str(
        initial_epsilon) + "*" + str(epsilon_discount) + "|" + str(highest_reward) + "| PICTURE |"))
    l = last_time_steps.tolist()
    l.sort()
    # print("Parameters: a="+str)
    rospy.loginfo("Overall score: {:0.2f}".format(last_time_steps.mean()))
    rospy.loginfo("Best 100 score: {:0.2f}".format(reduce(lambda x, y: x + y, l[-100:]) / len(l[-100:])))
    env.close()
Line 20 is the most important part of this script. It will register the training environment.
From line 52 to line 102 is the training process of the algorithm. For each timestep, the algorithm will decide the action to take based on the current state. After an action is taken. The observation is measured and the reward is calculated. The algorithm will keep learning to get the highest possible reward.
After that, you can compile the package and launch the training with the following command.
roslaunch turtle2_openai_ros_example start_training.launch
You should see the turtlebot start to moving and reset if it touches the wall.
In this example, we use the environment defined by openai_ros package, but what if I want to do some different tasks? e.g. change the actions the robot can take?
Let’s create our own environment called my_turtlebot2_maze.py under the script folder with the following content
import numpy
from gym import spaces
from openai_ros import turtlebot2_env
timestep_limit_per_episode = 10000 # Can be any Value
register(
        id='MyTurtleBot2Maze-v0',
        entry_point='my_turtlebot2_maze:MyTurtleBot2MazeEnv',
        timestep_limit=timestep_limit_per_episode,
class MyTurtleBot2MazeEnv(turtlebot2_env.TurtleBot2Env):
        This Task Env is designed for having the TurtleBot2 in some kind of maze.
        It will learn how to move around the maze without crashing.
        # Only variable needed to be set here
        number_actions = rospy.get_param('/turtlebot2/n_actions')
        self.action_space = spaces.Discrete(number_actions)
        # We set the reward range, which is not compulsory but here we do it.
        self.reward_range = (-numpy.inf, numpy.inf)
        #number_observations = rospy.get_param('/turtlebot2/n_observations')
        We set the Observation space for the 6 observations
        cube_observations = [
            round(current_disk_roll_vel, 0),
            round(y_distance, 1),
            round(roll, 1),
            round(pitch, 1),
            round(y_linear_speed,1),
            round(yaw, 1),
        # Actions and Observations
        self.linear_forward_speed = rospy.get_param('/turtlebot2/linear_forward_speed')
        self.linear_turn_speed = rospy.get_param('/turtlebot2/linear_turn_speed')
        self.angular_speed = rospy.get_param('/turtlebot2/angular_speed')
        self.init_linear_forward_speed = rospy.get_param('/turtlebot2/init_linear_forward_speed')
        self.init_linear_turn_speed = rospy.get_param('/turtlebot2/init_linear_turn_speed')
        self.new_ranges = rospy.get_param('/turtlebot2/new_ranges')
        self.min_range = rospy.get_param('/turtlebot2/min_range')
        self.max_laser_value = rospy.get_param('/turtlebot2/max_laser_value')
        self.min_laser_value = rospy.get_param('/turtlebot2/min_laser_value')
        # We create two arrays based on the binary values that will be assigned
        # In the discretization method.
        laser_scan = self._check_laser_scan_ready()
        num_laser_readings = len(laser_scan.ranges)/self.new_ranges
        high = numpy.full((num_laser_readings), self.max_laser_value)
        low = numpy.full((num_laser_readings), self.min_laser_value)
        # We only use two integers
        self.observation_space = spaces.Box(low, high)
        rospy.logdebug("ACTION SPACES TYPE===>"+str(self.action_space))
        rospy.logdebug("OBSERVATION SPACES TYPE===>"+str(self.observation_space))
        # Rewards
        self.forwards_reward = rospy.get_param("/turtlebot2/forwards_reward")
        self.turn_reward = rospy.get_param("/turtlebot2/turn_reward")
        self.end_episode_points = rospy.get_param("/turtlebot2/end_episode_points")
        self.cumulated_steps = 0.0
        # Here we will add any init functions prior to starting the MyRobotEnv
        super(MyTurtleBot2MazeEnv, self).__init__()
    def _set_init_pose(self):
        """Sets the Robot in its init pose
        self.move_base( self.init_linear_forward_speed,
                        self.init_linear_turn_speed,
                        epsilon=0.05,
                        update_rate=10)
        return True
    def _init_env_variables(self):
        Inits variables needed to be initialised each time we reset at the start
        of an episode.
        :return:
        # For Info Purposes
        self.cumulated_reward = 0.0
        # Set to false Done, because its calculated asyncronously
        self._episode_done = False
    def _set_action(self, action):
        This set action will Set the linear and angular speed of the turtlebot2
        based on the action number given.
        :param action: The action integer that set s what movement to do next.
        rospy.logdebug("Start Set Action ==>"+str(action))
        # We convert the actions to speed movements to send to the parent class CubeSingleDiskEnv
        if action == 0: #FORWARD
            linear_speed = self.linear_forward_speed
            angular_speed = 0.0
            self.last_action = "FORWARDS"
        elif action == 1: #LEFT
            linear_speed = self.linear_turn_speed
            angular_speed = self.angular_speed
            self.last_action = "TURN_LEFT"
        elif action == 2: #RIGHT
            angular_speed = -1*self.angular_speed
            self.last_action = "TURN_RIGHT"
        elif action == 3: #RIGHT
            linear_speed = -self.linear_turn_speed
            angular_speed = 0.0
            self.last_action = "BACKWARDS"
        # We tell TurtleBot2 the linear and angular speed to set to execute
        self.move_base(linear_speed, angular_speed, epsilon=0.05, update_rate=10)
        rospy.logdebug("END Set Action ==>"+str(action))
    def _get_obs(self):
        Here we define what sensor data defines our robots observations
        To know which Variables we have acces to, we need to read the
        TurtleBot2Env API DOCS
        :return:
        rospy.logdebug("Start Get Observation ==>")
        # We get the laser scan data
        laser_scan = self.get_laser_scan()
        discretized_observations = self.discretize_observation( laser_scan,
        self.new_ranges
        rospy.logdebug("Observations==>"+str(discretized_observations))
        rospy.logdebug("END Get Observation ==>")
        return discretized_observations
    def _is_done(self, observations):
        if self._episode_done:
            rospy.logerr("TurtleBot2 is Too Close to wall==>")
            rospy.logerr("TurtleBot2 is Ok ==>")
        return self._episode_done
    def _compute_reward(self, observations, done):
        if not done:
            if self.last_action == "FORWARDS":
                reward = self.forwards_reward
            elif self.last_action == "BACKWARDS":
                reward = -1*self.forwards_reward
                reward = self.turn_reward
            reward = -1*self.end_episode_points
        rospy.logdebug("reward=" + str(reward))
        self.cumulated_reward += reward
        rospy.logdebug("Cumulated_reward=" + str(self.cumulated_reward))
        self.cumulated_steps += 1
        rospy.logdebug("Cumulated_steps=" + str(self.cumulated_steps))
        return reward
    # Internal TaskEnv Methods
    def discretize_observation(self,data,new_ranges):
        Discards all the laser readings that are not multiple in index of new_ranges
        value.
        discretized_ranges = []
        mod = len(data.ranges)/new_ranges
        rospy.logdebug("data=" + str(data))
        rospy.logwarn("new_ranges=" + str(new_ranges))
        rospy.logwarn("mod=" + str(mod))
        for i, item in enumerate(data.ranges):
            if (i%mod==0):
                if item == float ('Inf') or numpy.isinf(item):
                    discretized_ranges.append(self.max_laser_value)
                elif numpy.isnan(item):
                    discretized_ranges.append(self.min_laser_value)
                    discretized_ranges.append(int(item))
                if (self.min_range > item > 0):
                    rospy.logerr("done Validation >>> item=" + str(item)+"< "+str(self.min_range))
                    self._episode_done = True
                    rospy.logwarn("NOT done Validation >>> item=" + str(item)+"< "+str(self.min_range))
        return discretized_ranges
Please notice the ID defined in line 10 is the one we are going to use
In line 15, you can see that the environment is inherited from the turtlebot2_env from the openai_ros package. By doing that, you don’t need to define how to move the robot or get the sensor data since the openai_ros package already defined it for you.
Then let’s set up a new training script and launch file. We’ll call the new training script my_start_qlearning_maze.py with same same content as start_qlearning.py but with the following changes
import rospkg
import my_turtlebot2_maze
    rospy.init_node('example_turtlebot2_maze_qlearn', anonymous=True, log_level=rospy.WARN)
    # Create our own Gym environment
    env = gym.make('MyTurtleBot2Maze-v0')
Here we directly import the environment from the previous script and use the ID it defined. The last step is to create the start_training_maze.launch file under the launch folder with the following content.
    <node pkg="turtle2_openai_ros_example" name="example_turtlebot2_maze_qlearn" type="my_start_qlearning_maze.py" output="screen"/>
This launch file will launch the node which uses the last script for training.
You can define different action or reward as you want, but remember to also change the n_actions parameter in the turtlebot2_openai_qlearn_params.yaml because it is used by the openai gym.
Have fun!
If you want to learn more about OpenAI gym, please check our OpenAI Gym for Robotics 101 course. You’ll learn how to create environments and train robot for different task in detail.
