[ROS Projects] – Use OpenAI_ROS with TurtleBot2 Step-by-Step #Part 2
[ROS-Projects]---Use-OpenAI_ROS-with-TurtleBot2-Step-by-Step-#Part-2
Written by Miguel Angel
30/07/2018
In this second part, you will continue by creating your own TaskEnvironment for a different TurtleBot simulation environment with a wall.
You will create this Task Env that allows the robot to learn how to reach a certain position in the map without running into the wall.
Related links and resources:
[irp posts=”10259″ name=”[ROS Projects] – Use OpenAI_ROS with Turtlebot2 Step by Step #Part 1″]
