This is an extra short video updating what it has been done new on OpenAI_ROS package. You can find the link to the package wiki down below.
This is important for the people that saw the other two videos, because the structure of the package has changed and it might lead to some confusion and errors.
[irp posts=”10259″ name=”ROS Projects – Use OpenAI_ROS with Turtlebot2 Step by Step #Part 1″]
[irp posts=”10441″ name=”ROS Projects – Use OpenAI_ROS with TurtleBot2 Step-by-Step #Part 2″]
ROSDS helps you follow our tutorial in a fast pace without dealing without setting up an environment locally. If you haven’t had an account yet, you can create a free account here. Let’s create a new project and call it rrbot_control. You can easily clone the project with this link.
Step 1. Train Turtlebot 2 with OpenAI ROS
In the ROSject, we already clone the openai ros package for you. You can run the turtlebot 2 simulation from Simulations->Select launch file->main.launch. You should see the simulation is up and running.
Then you can run the training script with
cd catkin_ws source devel/setup.bash roslaunch turtle2_openai_ros_example start_training.launch
The robot starts moving and learning how to move in a maze.
If you are interested in using the openAI gym in ROS, please check our OpenAI Gym for Robotics 101 course.
- We have also created a ROS Wiki fo the package with tutorials:
[https://goo.gl/Hu2FhY] - A page with all the robots supported by OpenAi_ROS package:
[https://goo.gl/xro8Z9] - Here you have the ROSJect with the updated code from the git and simulation, just click and run: [https://rds.theconstructsim.com/tc_projects/use_project_share_link/2f58476a-40e9-46e9-a25c-9588b5a78441]
![[ROS Projects] – Use OpenAI_ROS with Turtlebot2 Step by Step – PE [ROS Projects] - Use OpenAI_ROS with Turtlebot2 Step by Step - PE](https://www.theconstruct.ai/wp-content/uploads/2018/08/ROS-Projects-Use-OpenAI_ROS-with-Turtlebot2-Step-by-Step-PE.jpg)
