[ROS Projects] Use OpenAI_ROS with WAM-V Step-by-Step
wam_v_sim
Written by Miguel Angel
06/08/2018
What you will learn?
In this video you will learn how to use openai_ros package to make learn the WAM-V sea robot of the RobotX Challenge to pass the first Navigation Control.  The only thing you need to code is the AI algorithm if you want to use a different one to the one provided Q-Learn.
You can run the ROSject containing all the ROS code and simulation of the robot and sea by clicking on the next button:
Run on ROSDS your ROS project
And here the different gits used:
And a course on OpenAI in RobotIgniteAcademy: OpenAI Gym for ROS Based Robots 101
Link to RobotX PDF instructions for the challenge:
[https://robotx.org/images/files/RobotX_2018_Task_Summary.pdf]
[https://www.robotx.org/]
