In today’s Q&A, the question is How to use a c++ vector container in my code and to publish and subscribe it in ROS.
Let’s see how to do it.
ROSDS helps you follow our tutorial in a fast pace without dealing without setting up an environment locally. If you haven’t had an account yet, you can create a free account here. Let’s create a new project and call it ros_q_a_messages.
Step 1. Create a package
Let’s create a new package and a msg folder for our code.
cd ~/catkin_make/src catkin_create_pkg my_pkg roscpp std_msgs geometry_msgs cd my_pkg mkdir msg
In the msg folder, we’ll define the message in the my_msg.msg file
geometry_msgs/Point[] points uint8 another_field
In order to compile the message, we have to change two files. The first one is the pckage.xml, add the following two line.
... <build_depend>message_generation</build_depend> ... <run_depend>message_runtime</run_depend> ...
The second is the CMakeList.txt file. Change the following part
... find_package(catkin REQUIRED COMPONENTS geometry_msgs roscpp std_msgs message_generation ) .. add_message_files( FILES my_msg.msg ) ... generate_messages( DEPENDENCIES geometry_msgs ) ... catkin_package( CATKIN_DEPENDS geometry_msgs roscpp std_msgs message_runtime ) ...
Then we can finally compile the message
In the my_pkg/src folder, create a my_publisher.cpp file with the following content
#include "ros/ros.h" #include "geometry_msgs/Point.h" #include "my_pkg/my_msg.h" #include <vector> struct Point { float x; float y; }; int main(int argc, char **argv) { // ROS objects ros::init(argc, argv, "my_publisher"); ros::NodeHandle n; ros::Publisher pub = n.advertise<my_pkg::my_msg>("my_topic", 1); ros::Rate loop_rate(0.5); // the message to be published my_pkg::my_msg msg; msg.another_field = 0; // creating the vector Point my_array[11]; Point point; for (int i=0; i < 11; i++) { point.x = i; point.y = i; my_array[i] = point; } std::vector<Point> my_vector (my_array, my_array + sizeof(my_array) / sizeof(Point)); // loop control int count = 0; while (ros::ok()) { msg.points.clear(); msg.another_field = count; int i = 0; for (std::vector<Point>::iterator it = my_vector.begin(); it != my_vector.end(); ++it) { geometry_msgs::Point point; point.x = (*it).x; point.y = (*it).y; point.z = 0; msg.points.push_back(point); i++; } ROS_INFO("%d", msg.another_field); pub.publish(msg); ros::spinOnce(); loop_rate.sleep(); ++count; } return 0; }
To compile the code, we have to change the CMakeLists.txt again in the following part.
... add_executable(my_publisher src/my_publisher.cpp) ... target_link_libraries(my_publisher $(catkin_LIBRARIES) )
Then we compile it again with
Now you can run the executable rosrun my_pkg my_publisher with the node is publishing something.
You also have to run a simulation or run roscore to start the rosmaster
The next step is to create a subscriber to subscribe to the topic. Let’s create a my_subscriber.cpp file under the src folder with the following content.
#include "ros/ros.h" #include "my_pkg/my_msg.h" void clbk(const my_pkg::my_msg::ConstPtr& msg) { ROS_INFO("%d", msg->another_field); ROS_INFO("first point: x=%.2f, y=%.2f", msg->points[0].x, msg->points[0].y); } int main(int argc, char **argv) { // ROS objects ros::init(argc, argv, "my_subscriber"); ros::NodeHandle n; ros::Subscriber sub = n.subscribe("my_topic", 1, clbk); ros::spin(); }
You also have to change the following part in CMakeLists.txt to compile the code
... add_executable(my_subscriber src/my_subscriber.cpp) ... target_link_libraries(my_subscriber $(catkin_LIBRARIES))
Then compile again and run with
cd catkin_ws catlin_make source devel/setup.bash rosrun my_pkg my_subscriber
You should see the number from the my_topic is printing on the screen.
