In this video, we are going to show how to create a launch file to spawn a URDF robot model in a given gazebo world.
Up to the end of the video, you will be able to spawn any robot model you may have described in URDF in Gazebo.
ROSDS helps you follow our tutorial in a fast pace without dealing without setting up an environment locally. If you haven’t had an account yet, you can create a free account here. Let’s create a new project and call it launch_urdf_model_in_gazebo.
Step 2. Create a package
Let’s create a ROS package for our code by using the following command.
cd ~/catkin_ws/src catkin_create_pkg my_robot_urdf rospy
Then we create a m2wr.urdf file under the my_robot_urdf/urdf folder.
<?xml version="1.0"?> <robot name="m2wr" xmlns:xacro="http://www.ros.org/wiki/xacro"> <material name="black"> <color rgba="0.0 0.0 0.0 1.0"/> </material> <material name="blue"> <color rgba="0.203125 0.23828125 0.28515625 1.0"/> </material> <material name="green"> <color rgba="0.0 0.8 0.0 1.0"/> </material> <material name="grey"> <color rgba="0.2 0.2 0.2 1.0"/> </material> <material name="orange"> <color rgba="1.0 0.423529411765 0.0392156862745 1.0"/> </material> <material name="brown"> <color rgba="0.870588235294 0.811764705882 0.764705882353 1.0"/> </material> <material name="red"> <color rgba="0.80078125 0.12890625 0.1328125 1.0"/> </material> <material name="white"> <color rgba="1.0 1.0 1.0 1.0"/> </material> <gazebo reference="link_chassis"> <material>Gazebo/Orange</material> </gazebo> <gazebo reference="link_left_wheel"> <material>Gazebo/Blue</material> </gazebo> <gazebo reference="link_right_wheel"> <material>Gazebo/Blue</material> </gazebo> <gazebo> <plugin filename="libgazebo_ros_diff_drive.so" name="differential_drive_controller"> <alwaysOn>true</alwaysOn> <updateRate>20</updateRate> <leftJoint>joint_left_wheel</leftJoint> <rightJoint>joint_right_wheel</rightJoint> <wheelSeparation>0.4</wheelSeparation> <wheelDiameter>0.2</wheelDiameter> <torque>0.1</torque> <commandTopic>cmd_vel</commandTopic> <odometryTopic>odom</odometryTopic> <odometryFrame>odom</odometryFrame> <robotBaseFrame>link_chassis</robotBaseFrame> </plugin> </gazebo> <gazebo reference="sensor_laser"> <sensor type="ray" name="head_hokuyo_sensor"> <pose>0 0 0 0 0 0</pose> <visualize>false</visualize> <update_rate>20</update_rate> <ray> <scan> <horizontal> <samples>720</samples> <resolution>1</resolution> <min_angle>-1.570796</min_angle> <max_angle>1.570796</max_angle> </horizontal> </scan> <range> <min>0.10</min> <max>10.0</max> <resolution>0.01</resolution> </range> <noise> <type>gaussian</type> <mean>0.0</mean> <stddev>0.01</stddev> </noise> </ray> <plugin name="gazebo_ros_head_hokuyo_controller" filename="libgazebo_ros_laser.so"> <topicName>/m2wr/laser/scan</topicName> <frameName>sensor_laser</frameName> </plugin> </sensor> </gazebo> <link name="link_chassis"> <!-- pose and inertial --> <pose>0 0 0.1 0 0 0</pose> <inertial> <mass value="5"/> <origin rpy="0 0 0" xyz="0 0 0.1"/> <inertia ixx="0.0395416666667" ixy="0" ixz="0" iyy="0.106208333333" iyz="0" izz="0.106208333333"/> </inertial> <!-- body --> <collision name="collision_chassis"> <geometry> <box size="0.5 0.3 0.07"/> </geometry> </collision> <visual> <origin rpy="0 0 0" xyz="0 0 0"/> <geometry> <box size="0.5 0.3 0.07"/> </geometry> <material name="blue"/> </visual> <!-- caster front --> <collision name="caster_front_collision"> <origin rpy=" 0 0 0" xyz="0.35 0 -0.05"/> <geometry> <sphere radius="0.05"/> </geometry> <surface> <friction> <ode> <mu>0</mu> <mu2>0</mu2> <slip1>1.0</slip1> <slip2>1.0</slip2> </ode> </friction> </surface> </collision> <visual name="caster_front_visual"> <origin rpy=" 0 0 0" xyz="0.2 0 -0.05"/> <geometry> <sphere radius="0.05"/> </geometry> </visual> </link> <link name="link_right_wheel"> <inertial> <mass value="0.2"/> <origin rpy="0 1.5707 1.5707" xyz="0 0 0"/> <inertia ixx="0.000526666666667" ixy="0" ixz="0" iyy="0.000526666666667" iyz="0" izz="0.001"/> </inertial> <collision name="link_right_wheel_collision"> <origin rpy="0 1.5707 1.5707" xyz="0 0 0"/> <geometry> <cylinder length="0.04" radius="0.1"/> </geometry> </collision> <visual name="link_right_wheel_visual"> <origin rpy="0 1.5707 1.5707" xyz="0 0 0"/> <geometry> <cylinder length="0.04" radius="0.1"/> </geometry> </visual> </link> <joint name="joint_right_wheel" type="continuous"> <origin rpy="0 0 0" xyz="-0.05 0.15 0"/> <child link="link_right_wheel"/> <parent link="link_chassis"/> <axis rpy="0 0 0" xyz="0 1 0"/> <limit effort="10000" velocity="1000"/> <joint_properties damping="1.0" friction="1.0"/> </joint> <link name="link_left_wheel"> <inertial> <mass value="0.2"/> <origin rpy="0 1.5707 1.5707" xyz="0 0 0"/> <inertia ixx="0.000526666666667" ixy="0" ixz="0" iyy="0.000526666666667" iyz="0" izz="0.001"/> </inertial> <collision name="link_left_wheel_collision"> <origin rpy="0 1.5707 1.5707" xyz="0 0 0"/> <geometry> <cylinder length="0.04" radius="0.1"/> </geometry> </collision> <visual name="link_left_wheel_visual"> <origin rpy="0 1.5707 1.5707" xyz="0 0 0"/> <geometry> <cylinder length="0.04" radius="0.1"/> </geometry> </visual> </link> <joint name="joint_left_wheel" type="continuous"> <origin rpy="0 0 0" xyz="-0.05 -0.15 0"/> <child link="link_left_wheel"/> <parent link="link_chassis"/> <axis rpy="0 0 0" xyz="0 1 0"/> <limit effort="10000" velocity="1000"/> <joint_properties damping="1.0" friction="1.0"/> </joint> </robot>
This file defines the physical parameters of our robot and the type of controller that we want to use.
We’ll create a launch file to launch this description. We name it spawn_urdf.launch and put it under the launch folder.
<?xml version="1.0" encoding="UTF-8"?> <launch> <param name="robot_description" command="cat '$(find my_robot_urdf)/urdf/m2wr.urdf'" /> <node name="mybot_spawn" pkg="gazebo_ros" type="spawn_model" output="screen" args="-urdf -param robot_description -model m2wr" /> </launch>
You can see that the launch file try to find the description file from the my_robot_urdf package.
Now we have to compile it with the following command
Now you can launch an empty world simulation from Simulations->Empty, then use the command roslaunch my_robot_urdf spawn_urdf.launch to spawn the robot!
If you are interested in this topic and want to learn more about URDF, please check our Robot Creation with URDF course.
Related resources and links:
- Robot Ignite Academy
- ROS Development Studio
- My 2 wheeled robot model repository:https://bitbucket.org/theconstructcore/two-wheeled-robot-simulation
- Original question: http://answers.gazebosim.org/question/19959/how-to-create-launch-file-for-my-urdf-file-and-open-it-in-gazebo/
