[ROS Q&A] 148 – ROS CPP Time and Duration arithmetics build error
[ROS Q&A] 148 - ROS CPP Time and Duration arithmetics build error
Written by Marco Arruda
11/08/2018
In this video we are going to explain about a problem trying to build a ROS C++ node using ros::Time and ros::Duration.
It is because the order of the terms in sum operation matters. You can check in the video it is simple to solve but it can be a trap if you do not pay attention to that during the development.
ROSDS helps you follow our tutorial in a fast pace without dealing without setting up an environment locally. If you haven’t had an account yet, you can create a free account here. Let’s call the project ros time error.
Step 2. Create a package
Let’s start by creating a ROS package for our code
catkin_create_pkg mypkg roscpp geometry_msgs
Then we call the source file mypkg_node.cpp and put it under the mypkg/src folder with the content from the question.
// This program publishes randomly-generated velocity
// messages for turtlesim.
#include <ros/ros.h>
#include <geometry_msgs/Twist.h>  // For geometry_msgs::Twist
#include <stdlib.h> // For rand() and RAND_MAX
  ros::init(argc, argv, "publish_velocity");
  ros::NodeHandle nh; // handles node
  ros::Publisher pub = nh.advertise<geometry_msgs::Twist>(
    "turtle1/cmd_vel", 1000); //links publisher to the node
  while(ros::ok()) {
    geometry_msgs::Twist msg; //Object msgs
    msg.linear.x = 0.5;
    msg.angular.z = 0;
    msg.linear.z = 0.5;
    // Time tracking
    ros::Time beginTime = ros::Time::now();
    ros::Duration MessageTime = ros::Duration(3);
    ros::Time endTime = MessageTime + beginTime;
    while(ros::Time::now() < endTime){
        pub.publish(msg);
        ROS_INFO_STREAM("Sending velocity command:"
          << " linear=" << msg.linear.x
          << " angular=" << msg.angular.z
           <<"linearZ="<<msg.linear.z);
        ros::Duration(0.3).sleep();
To compile the code, we need to at first uncomment the add_executable and target_link_libraries in the CMakeLists.txt. After that, we can compile it with
However, some error related to ROS time occurs. After checking the documentation ROS C++ Time and Duration, we found out that the order is not quite right. The following part should be changed.
    ros::Time endTime = beginTime +  MessageTime;
If we compile again, the problem is solved.
If you are interested in using ROS with C++, please check our ROS Basics in 5 days(C++) course for more information.
RELATED LINKS
The original question on ROS_Answers
Robot Ignite Academy
We love feedback!
Topics: ROS C++
