[ROS Q&A] 150 – How to publish data changed in Dynamic Reconfigure
[ROS Q&A] 150 - How to publish data changed in Dynamic Reconfigure
Written by Marco Arruda
27/08/2018
This video shows how to use dynamic reconfigure client to change or receive updates about dynamic parameter value updates inside your node. Using a dynamic reconfigure client allows you to interact with these parameters outside the server node.
ROSDS helps you follow our tutorial in a fast pace without dealing without setting up an environment locally. If you haven’t had an account yet, you can create a free account here. Let’s create a new project and call it dynamic_reconfigure.
Step 1. Create the package
We’ll put our code in a new package called mypkg
catkin_create_pkg mypkg rospy
cd mypkg
mkdir cfg
mkdir scripts
We’ll create a Tutorials.cfg file under the cfg folder with the following content.
PACKAGE = "dynamic_tutorials"
from dynamic_reconfigure.parameter_generator_catkin import *
gen = ParameterGenerator()
gen.add("int_param",    int_t,    0, "An Integer parameter", 50,  0, 100)
gen.add("double_param", double_t, 0, "A double parameter",    .5, 0,   1)
gen.add("str_param",    str_t,    0, "A string parameter",  "Hello World")
gen.add("bool_param",   bool_t,   0, "A Boolean parameter",  True)
size_enum = gen.enum([ gen.const("Small",      int_t, 0, "A small constant"),
                       gen.const("Medium",     int_t, 1, "A medium constant"),
                       gen.const("Large",      int_t, 2, "A large constant"),
                       gen.const("ExtraLarge", int_t, 3, "An extra large constant")],
                     "An enum to set size")
gen.add("size", int_t, 0, "A size parameter which is edited via an enum", 1, 0, 3, edit_method=size_enum)
exit(gen.generate(PACKAGE, "dynamic_tutorials", "Tutorials"))
We also need a server.py file under the scripts folder to publish these parameters.
from dynamic_reconfigure.server import Server
from dynamic_tutorials.cfg import TutorialsConfig
def callback(config, level):
    rospy.loginfo("""Reconfigure Request: {int_param}, {double_param},\
          {str_param}, {bool_param}, {size}""".format(**config))
    return config
if __name__ == "__main__":
    rospy.init_node("mypkg", anonymous = True)
    srv = Server(TutorialsConfig, callback)
Step 2. rqt_reconfigure tool
Then we can launch the rqt_reconfigure tool from another shell
rosrun rqt_reconfigure rqt_reconfigure
Go to Tools->Graphical tool to open the GUI.
Since the parameters have not been published yet, you’ll see nothing on it.
Let’s run the server
rosrun mypkg server.py
You’ll see the parameters are in the gui now.
Step 3. Client
If you want to get the updated value from the tool, you’ll need a client. Let’s create a client.py under the scripts folder.
import dynamic_reconfigure.client
def callback(config):
    rospy.loginfo("Config set to {int_param}, {double_param}, {str_param}, {bool_param}, {size}".format(**config))
    rospy.init_node("dynamic_client")
    client = dynamic_reconfigure.client.Client("mypkg", timeout=30, config_callback=callback)
    r = rospy.Rate(0.1)
    x = 0
    b = False
        x = x+1
        if x>10:
            x=0
        b = not b
        #client.update_configuration({"int_param":x, "double_param":(1/(x+1)), "str_param":str(rospy.get_rostime()), "bool_param":b, "size":1})
        r.sleep()
After giving the file permission, you can run it with
rosrun mypkg client.py
You should receive the parameter now. If you want to update the parameters with the client. Please uncomment the client.update_configuration line in the script.
If you are interested in learning ROS, please check our ROS Basic in 5 Days course.
RELATED LINKS
Robot Ignite Academy
Original question
We Love Feedback!
129. ros2ai
129. ros2ai
1 Comment
  1. zbt
    hello, I’m having a problem while running “rosrun rqt_reconfigure rqt_reconfigure”. When I run in it in the terminal it says “Segmentation fault (core dumped)”. I don’t know what is causing the problem. I need your help. help me, please!
