Learn how to trigger an event in order to execute some action when our ROS program ends. This is an answer to the following question on ROS Answers: https://answers.ros.org/question/309529/how-can-i-perform-some-actions-after-the-program-ends/.
- Use the ROS Development Studio (ROSDS), an online platform for developing for ROS within a PC browser. Easy-peasy. I’m using this option for this post.
- Once you log in, click on the New ROSject button to create a project that will host your code. Then Click on Open ROSject to launch the development/simulation environment.
- To open a “terminal” on ROSDS, pick the
Shell
app from the Tools menu. - You can find the
IDE
app on the Tools menu.
- You have ROS installed on a local PC. Okay, skip to Step 2.
Next step!
Step 2: Create a package with the code given in the post
1. If you are working on ROSDS, please create a ROSject first, as indicated in Step 1.
2. Open a terminal and create a package that holds the Python code:
user:~$ cd catkin_ws/src user:~/catkin_ws/src$ catkin_create_pkg test_shutdown rospy Created file test_shutdown/CMakeLists.txt Created file test_shutdown/package.xml Created folder test_shutdown/src Successfully created files in /home/user/catkin_ws/src/test_shutdown. Please adjust the values in package.xml. user:~/catkin_ws/src$ cd test_shutdown/src user:~/catkin_ws/src/test_shutdown/src$ touch test_shutdown.py user:~/catkin_ws/src/test_shutdown/src$ chmod +x test_shutdown.py
3. Open test_shutdown.py
in the IDE and paste in the following code:
#!/usr/bin/env python import rospy from std_msgs.msg import String def talker(): pub = rospy.Publisher('chatter', String, queue_size=10) rospy.init_node('talker', anonymous=True) rate = rospy.Rate(10) # 10hz while not rospy.is_shutdown(): hello_str = "hello world %s" % rospy.get_time() rospy.loginfo(hello_str) pub.publish(hello_str) rate.sleep() try: talker() except rospy.ROSInterruptException: rospy.loginfo("TEST")
4. Compile and run the code: go back to the catkin_ws
directory and run the following commands
user:~/catkin_ws$ catkin_make user:~/catkin_ws$ source devel/setup.bash user:~/catkin_ws$ rospack profile user:~/catkin_ws$ rosrun test_shutdown test_shutdown.py
(PS: Please run nohup roscore &
to start ROS master in the background if you get an error that says “cannot connect to master”)
5. Stop the program with Ctrl + C
Nothing happened? Yes, nothing happened like the OP explained. The OP expected that the word “TEST” would be printed, but it wasn’t. Let’s fix that next.
Step 3: Modify the code so that it triggers some actions when our ROS program ends
The key tool here is the rospy.on_shutdown()
hook, which takes a function that should be called when ROS gets the shutdown signal.
Replace the code in test_shutdown.py
with the following code that creates the shutdown hook function and registers it.
#!/usr/bin/env python import rospy from std_msgs.msg import String def talker(): pub = rospy.Publisher('chatter', String, queue_size=10) rospy.init_node('talker', anonymous=True) rate = rospy.Rate(10) # 10hz while not rospy.is_shutdown(): hello_str = "hello world %s" % rospy.get_time() rospy.loginfo(hello_str) pub.publish(hello_str) rate.sleep() def my_shutdown_hook(): rospy.loginfo("It's shutdown time!") try: rospy.on_shutdown(my_shutdown_hook) talker() except rospy.ROSInterruptException: rospy.loginfo("TEST")
Now run the program again and then stop it with Ctrl + C
user:~/catkin_ws$ rosrun test_shutdown test_shutdown.py [INFO] [1586198566.464600]: hello world 1586198566.46 [INFO] [1586198566.564763]: hello world 1586198566.56 ^C[INFO] [1586198568.326002]: It's shutdown time!
And that was it! Of course, the shutdown hook could perform more useful tasks, like stopping the robot for example.
Extra: Video of the post
Edited by Bayode Aderinola
