[ROS Q&A] 195 – How to know if robot has moved one meter using Odometry
How to know if robot has moved 1 meter using odometry
Written by Alberto Ezquerro
13/09/2019
Learn how to know if the robot has moved one-meter using Odometry.  You’ll learn how to:
  • create a Python program for calculating the distance moved by the robot using the Odometry topic and publish it into a topic.
  • create a Python program for testing that we can move the robot depending on the Odometry data.
Step 1: Get your development environment ready and grab a copy of the code
  1. Click here to grab a copy of the ROSject already containing the project. This requires an account on the ROS Development Studio (ROSDS), an online platform for developing for ROS within a PC browser. If you don’t have an account, you will be asked to create one.
  2. To open a “terminal” on ROSDSpick the Shell app from the Tools menu.
  3. You can find the IDE app on the Tools menu.
Step 2: Start a Simulation
We are going to use the TurtleBot 2 simulation.
  1. Click on Simulations from the main menu.
  2. Under Launch a provided simulation, leave “Empty world” selected and click on Choose a robot.
  3. Type “turtle” into the search box and select TurtleBot 2.
  4. Click Start Simulation.
  5. A window showing the TurtleBot 2 in an empty world should show up.
Step 3: Examine the structure of Odometry messages
Let’s see the structure of an Odom message. Open a terminal and run:
user:~$ rostopic echo /odom -n1
header:
  seq: 14929
  stamp:
    secs: 748
    nsecs: 215000000
  frame_id: "odom"
child_frame_id: "base_footprint"
pose:
  pose:
    position:
      x: 0.00668370211388
      y: 0.00010960687178
      z: -0.000246865753431
    orientation:
      x: 0.000389068511716
      y: -0.00720626927928
      z: 0.000354481463316
      w: 0.999973895985
  covariance: [1e-05, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 1e-05, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 1000000000000.0, 0.0, 0.0, 0.0, 0.0,0.0, 0.0, 1000000000000.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 1000000000000.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.001]
twist:
  twist:
    linear:
      x: 2.30945682841e-05
      y: 0.000390977104083
      z: 0.0
    angular:
      x: 0.0
      y: 0.0
      z: -0.000507764995516
  covariance: [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0]
The part of the message that stores the current position of the robot is the pose.pose.position:
pose:
  pose:
    position:
      x: 0.00668370211388
      y: 0.00010960687178
This part is what is used in the Python script that calculates the distance moved.
Step 4: Understand the Python scripts
1. Open the IDE and browse to the src folder. You will find two packages odom_movement_detector and test_movement. Each of these projects contains a Python script, each explained with comments in the code
odom_movement_detector/src/odom_movement_detector.py
class MovementDetector(object):
        """Initialize an object of the MovementDetector class."""
        # _mved_distance is for stored distance moved
        # create and initialize it here. Initial value is 0.0
        self._mved_distance = Float64()
        self._mved_distance.data = 0.0
        # Get the inital position. This will be a reference point for calculating
        # the distance moved
        self.get_init_position()
        # Create a publisher for publishing the distance moved into the topic '/moved_distance'
        self.distance_moved_pub = rospy.Publisher('/moved_distance', Float64, queue_size=1)
        # create a subscriber for getting new Odometry messages
        rospy.Subscriber("/odom", Odometry, self.odom_callback)
    def get_init_position(self):
        """Get the initial position of the robot."""
        Structure of the odom position message:
        header:
        seq: 14929
        stamp:
            secs: 748
            nsecs: 215000000
        frame_id: "odom"
        pose:
        pose:
            position:
            x: 0.00668370211388
            y: 0.00010960687178
        data_odom = None
        # wait for a message from the odometry topic and store it in data_odom when available
        while data_odom is None:
                data_odom = rospy.wait_for_message("/odom", Odometry, timeout=1)
            except:
                rospy.loginfo("Current odom not ready yet, retrying for setting up init pose")
        # Store the received odometry "position" variable in a Point instance
        self._current_position = Point()
        self._current_position.x = data_odom.pose.pose.position.x
        self._current_position.y = data_odom.pose.pose.position.y
        self._current_position.z = data_odom.pose.pose.position.z
    def odom_callback(self, msg):
        """Process odometry data sent by the subscriber."""
        # Get the position information from the odom message
        # See the structure of an /odom message in the `get_init_position` function
        NewPosition = msg.pose.pose.position
        # Calculate the new distance moved, and add it to _mved_distance and
        self._mved_distance.data += self.calculate_distance(NewPosition, self._current_position)
        # Update the current position of the robot so we have a new reference point
        # (The robot has moved and so we need a new reference for calculations)
        self.updatecurrent_positin(NewPosition)
        # If distance moved is big enough, publish it to the designated topic
        # Otherwise publish zero
        if self._mved_distance.data < 0.000001:
            aux = Float64()
            aux.data = 0.0
            self.distance_moved_pub.publish(aux)
            self.distance_moved_pub.publish(self._mved_distance)
    def updatecurrent_positin(self, new_position):
        """Update the current position of the robot."""
        self._current_position.x = new_position.x
        self._current_position.y = new_position.y
        self._current_position.z = new_position.z
    def calculate_distance(self, new_position, old_position):
        """Calculate the distance between two Points (positions)."""
        x2 = new_position.x
        x1 = old_position.x
        y2 = new_position.y
        y1 = old_position.y
        dist = math.hypot(x2 - x1, y2 - y1)
        return dist
    def publish_moved_distance(self):
        # spin() simply keeps python from exiting until this node is stopped
    # create a node for running the program
    rospy.init_node('movement_detector_node', anonymous=True)
    # create an instance of the MovementDetector class and set the code
    # in motion
    movement_obj = MovementDetector()
    movement_obj.publish_moved_distance()
test_movement/src/test_movement.py
def my_callback(msg):
    """Callback function that processes messages from the subscriber."""
    # get the distance moved from the message
    distance_moved = msg.data
    # If distance is less than 2, continue moving the robot
    # Otherwise, stop it (by pubishing `0`)
    if msg.data < 2:
        move.linear.x = 0.1
    if msg.data > 2:
        move.linear.x = 0
    pub.publish(move)
rospy.init_node('test_movement')
# create a subscriber that gets the distance moved
sub = rospy.Subscriber('/moved_distance', Float64, my_callback)
# Create a publisher that moves the robot
pub = rospy.Publisher('/cmd_vel', Twist, queue_size="1")
# Create a global variable for publising a Twist ("cmd_vel") message
move = Twist()
# Keep the program running
Step 5: See the Python scripts in action
Open a terminal and run the movement detector:
user:~$ rosrun odom_movement_detector odom_movement_detector.py
Open another terminal and check the distance being published to the /moved_distance:
user:~$ rostopic echo /moved_distance
data: 0.00280330822873
data: 0.00280530307334
You can see from above that the distance is not changing (more or less) because the robot is stationary. Now let’s move the robot:
user:~$ rosrun test_movement test_movement.py
Now you should see the robot moving and moved_distance increasing. It should stop when moved_instance > 2.0.
data: 1.00280330822873
data: 2.00280330822873
And that’s it. I hope you had some fun!
Extra: Video of the post
Edited by Bayode Aderinola
Topics: odometry | ROS Q&A
