[ROS Q&A] How to convert quaternions to Euler angles
18/10/2017
About
In this tutorial, we are going to answer a question found at ROS answers – How to convert quaternions to Euler angles?
We’ll explain this with the following example in ROS Development Studio (ROSDS), where you can easily follow the steps and understand how to use the conversion from quaternions provided by an Odometry message to Euler angles (Roll, Pitch, and Yaw).
Step1. Create a Project in RDS
If you haven’t had an account yet, register here for free.
We’ll use a simulation we built previously, you can find some information here and build it in 5 mins with RDS.
Launch the Turtlebot 3 empty world simulation with the following command
$ roslaunch turtlebot3_gazebo turtlebot3_empty_world.launch
Step2. Create Package
We then create another package called my_quaternion_pkg for this example  under the ~/catkin_ws/src using
$ catkin_create_pkg my_quaternion_pkg rospy
Create a quaternion_to_euler.py file under my_quaternion_pkg. Now the source tree may look like the following picture
Step3. Transform Quaternion to Euler
As our first attempt, copy the following code into the quaternion_to_euler.py file
def get_rotation (msg):
    print msg.pose.pose.orientation
rospy.init_node('my_quaternion_to_euler')
sub = rospy.Subscriber ('/odom', Odometry, get_rotation)
r = rospy.Rate(1)
    r.sleep()
To run the file, simply type
$ rosrun my_quaternion_pkg quaternion_to_euler.py
Now you can see the code prints the odometry message in quaternion format. Now, we’d like to transform it to Euler angles. We use the euler_from_quaternion function provided by tf.transformations, you can find more detail here
from tf.transformations import euler_from_quaternion, quaternion_from_euler
    global roll, pitch, yaw
    orientation_q = msg.pose.pose.orientation
    orientation_list = [orientation_q.x, orientation_q.y, orientation_q.z, orientation_q.w]
    (roll, pitch, yaw) = euler_from_quaternion (orientation_list)
    print yaw
r = rospy.Rate(1)
    r.sleep()
We only print yaw values here. You can check it by typing the following command to control the Turtlebot.
$ roslaunch turtlebot3_teleop turtlebot3_teleop_key.launch
If you turn the robot, you’ll see the yaw angle change accordingly.
Step4. Transform Euler to Quaternion
Similarly, we can use the quaternion_from_euler function provided by tf.transformations to transform the Euler back to the quaternion with the following code.
roll = pitch = yaw = 0.0
    print yaw
r = rospy.Rate(1)
    quat = quaternion_from_euler (roll, pitch,yaw)
    print quat
    r.sleep()
The quaternion will print every 1 second since we specified the rate for 1 Hz and the odometry topic is published in 100 Hz.
Takeaway Today:
You can transform between Euler and quaternion using the quaternion_from_euler and euler_from_quaternion function provided by the tf.transform.
Edit by Tony Huang
Related Courses
TF ROS Course Cover - ROS Online Courses - Robot Ignite Academy
TF ROS Course
ROS for Beginners (Python)
MASTERING WITH ROS: TurtleBot 3 (Python)
Alternatives to ROS
Alternatives to ROS
1 Comment
  1. Alexander Rössler
    I noticed that the tf.conversions don’t deal with singularities which can occur when converting quaternions to Euler angles. For example try:
    quat = quaternion_from_euler(1, 2, 3, axes=’sxyz’)
    x, y, z, w = quat
    euler = euler_from_quaternion(quat, axes=’sxyz’)
    a, b, c = euler
    quat2 = quaternion_from_euler(a, b, c, axes=’sxyz’)
    x2, y2, z2, w2 = quat2
    You will see that a, b, c is different than the input angles 1,2,3, but the quaternion representation is the same.
    Any ideas how to solve this problem with ROS?
Trackbacks/Pingbacks
  1. [ROS Projects] OpenAI with Moving Cube Robot in Gazebo Step-by-Step Part3 | The Construct - […] Video On Quaternions to Euler: https://www.theconstruct.ai/ros-qa-how-to-convert-quaternions-to-euler-angles/ […]
