Written by 박진석
22/08/2024
What we are going to learn:
How to send a message using Topic Publisher and Subscriber using Python
To ensure stability, I’ll guide you through ROS2 Foxy on Ubuntu 20.04 system. I’ll be using Docker images for installation, but the process is similar to a local Ubuntu setup.
Prerequisites:
Ubuntu 20.04 installed on your computer.
We will actually create and run a ROS2 package that sends and receives messages through Publisher and Subscriber.
If you want to learn ROS 2 Python in a practical, hands-on way, check out the course ROS 2 Basics in 5 Days: https://app.theconstruct.ai/courses/132
1. Make Package:
The command to create a package is as follows:
ros2 pkg create [package_name] --build-type [build_type] --dependencies [dependent package1][dependent package2]
Lets’ make ros2_ws and create the ros_topic_pkg package
mkdir ~/ros2_ws/src
cd ~/ros2_ws/src
ros2 pkg create ros_topic_pkg --build-type ament_python --dependencies rclpy std_msgs
2. Write Publisher and Subscriber script
Firstly, we will make empty script publisher.py, subscriber.py in ros_topic_pkg_folder
cd ~/ros2_ws/src/ros_topic_pkg/ros_topic_pkg
touch publisher.py
touch subscriber.py
After make empty script, Using Vim or VsCode, write down this publisher and subscriber code
publihser.py
from rclpy.node import Node
from rclpy.qos import QoSProfile
class Publisher(Node):
super().__init__('Publisher')
qos_profile = QoSProfile(depth=10)
self.publisher = self.create_publisher(String, 'topic', qos_profile)
self.timer = self.create_timer(1, self.publish_msg)
self.count = 0
def publish_msg(self):
msg = String()
msg.data = 'Number: {0}'.format(self.count)
self.publisher.publish(msg)
self.get_logger().info('Published message: {0}'.format(msg.data))
self.count += 1
def main(args=None):
rclpy.init(args=args)
node = Publisher()
rclpy.spin(node)
except KeyboardInterrupt:
node.get_logger().info('Keyboard Interrupt')
finally:
node.destroy_node()
rclpy.shutdown()
subscriber.py
from std_msgs.msg import String​
class Subscriber(Node):
super().__init__('Subscriber')
self.subscriber = self.create_subscription(
String,
'topic',
self.subscribe_topic_message,
qos_profile)
def subscribe_topic_message(self, msg):
self.get_logger().info('Received message: {0}'.format(msg.data))​
node = Subscriber()
rclpy.spin(node)
finally:
node.destroy_node()
rclpy.shutdown()​
3. Write a Python package configuration file
Lastly, we have to write down this setup.py file to build Ros2 package
from setuptools import find_packages, setup
package_name = 'ros_topic_pkg'
setup(
name=package_name,
version='0.0.0',
packages=find_packages(exclude=['test']),
data_files=[
zip_safe=True,
maintainer='user',
tests_require=['pytest'],
entry_points={
'console_scripts': [
'publisher = ros_topic_pkg.publisher:main',
'subscriber = ros_topic_pkg.subscriber:main'
4 Build package:
If you write down all the code correctly, Now we will build ros2_topic pkg
cd ~/ros2_ws && colcon build --symlink-install
If the build is completely normal, you must load the configuration file and set the node for the executable package to run the build node
You can see the file that writes a lot of commands, at the end of the file, Input i to change insert mode and write
Now let’s run the publisher and subscriber we created
First, run publisher to issue a topic
ros2 run ros_topic_pkg publisher
Then Run a new terminal and run the Subscriber after proceeding with the configuration file load
If you wrote the code correctly, you can see that the subscriber is properly subscribing to the numbers issued by the publisher.
Congratulations. You have now learned how to send a message using Topic Publisher and Subscriber using Python.
To learn more about ROS 2, have a look at the course below:
We hope this tutorial was really helpful to you.
This tutorial is created by Robotics Ambassador Park.
129. ros2ai
129. ros2ai
