- How to create a package in ROS2
- How to write a python launch file
- How to define a static transform
- Robot Ignite Academy –▸ https://www.robotigniteacademy.com
- Question asked on ROS Answers –▸ https://answers.ros.org/question/372752/static_transform_publisher-in-ros2-launch-file/
Creating a rosject
In order to learn how to use a static transform, we need a ROS2 Python package. We are going to use The Construct (https://www.theconstruct.ai/) for this tutorial, but if you have ROS2 installed on your own computer, you should be able to do ~everything on your own computer, except this creating a rosject part.
Once inside, let’s create My Rosjects and then, Create a new rosject:
For the rosject, let’s select ROS2 Foxy for the ROS Distro, let’s name the rosject as static_tf_publisher. You can leave the rosject public.
Creating a ROS2 package named static_tf_transform
Once the rosject is open, we can now create a package that will be used to publish the static transform.
Let’s open a new terminal by clicking on the Open a new shell window button:
Once the terminal is open, we can list the files with the ls command:
user:~$ ls ai_ws catkin_ws notebook_ws ros2_ws simulation_ws webpage_ws
We can see a workspace named ros2_ws. Let’s enter that workspace using cd ros2_ws/:
user:~$ cd ros2_ws/ user:~/ros2_ws$
Let’s now source our workspace with:
Let’s now enter our src folder:
cd ~/ros2_ws/src/
And create a package named static_tf :
ros2 pkg create --build-type ament_python static_tf
The output should be similar to:
going to create a new package package name: static_tf destination directory: /home/user/ros2_ws/src package format: 3 version: 0.0.0 description: TODO: Package description maintainer: ['user <user@todo.todo>'] licenses: ['TODO: License declaration'] build type: ament_python dependencies: [] creating folder ./static_tf creating ./static_tf/package.xml creating source folder creating folder ./static_tf/static_tf creating ./static_tf/setup.py creating ./static_tf/setup.cfg creating folder ./static_tf/resource creating ./static_tf/resource/static_tf creating ./static_tf/static_tf/__init__.py creating folder ./static_tf/test creating ./static_tf/test/test_copyright.py creating ./static_tf/test/test_flake8.py creating ./static_tf/test/test_pep257.py
If you now list your src folder using ls, you should be able to see our package:
user:~/ros2_ws/src$ ls static_tf
We can now enter into this static_tf package using cd static_tf/ and create a launch folder there, and a file named static_tf_launch.py on that folder:
cd ~/ros2_ws/src/static_tf/ mkdir launch touch launch/static_tf_launch.py
We can now open that static_tf_launch.py file using the Code Editor, and add the following content to it:
from launch import LaunchDescription from launch_ros.actions import Node def generate_launch_description(): return LaunchDescription([ Node( package="tf2_ros", executable="static_transform_publisher", output="screen" , arguments=["0", "0", "0", "0", "0", "0", "odom", "laser"] ) ])
Once the static_tf_launch.py file is ok, let’s now open again our setup.py file (~/ros2_ws/src/static_tf/setup.py), and add our static_tf_launch.py file to data_files, so that our launch file will be included in the install folder when we compile our workspace. By doing this we will be able to execute it:
The bit we have to add to data_files is (os.path.join(‘share’, package_name, ‘launch’), glob(‘launch/*.py’)), so that data_files looks like:
data_files=[
(os.path.join('share', package_name, 'launch'), glob('launch/*.py')),
Just to make sure you have everything correctly imported, the final setup.py file should look like this:
from setuptools import setup
import os
from glob import glob
package_name = 'static_tf'
setup(
name=package_name,
version='0.0.0',
packages=[package_name],
data_files=[
zip_safe=True,
maintainer='user',
tests_require=['pytest'],
entry_points={
'console_scripts': [
Launching our ROS2 static tf publisher
Awesome. Our files are all in place. Let’s now build our ros2 workspace with:
cd ~/ros2_ws colcon build
If everything went ok, the compilation should have raised no errors:
Starting >>> static_tf Finished <<< static_tf [1.03s] Summary: 1 package finished [1.20s]
Now let’s source our workspace again and run our launch file that runs the static tf publisher.
source ~/ros2_ws/install/setup.bash ros2 launch static_tf static_tf_launch.py
After launching the static_tf_launch.py file, the output should be similar to the following:
[INFO] [launch]: All log files can be found below /home/user/.ros/log/2021-11-08-23-10-55-010925-2_xterm-6136 [INFO] [launch]: Default logging verbosity is set to INFO [INFO] [static_transform_publisher-1]: process started with pid [6138] [static_transform_publisher-1] [INFO] [1636413056.712927342] [static_transform_publisher_uKqntZ5iDxRToFQR]: Spinning until killed publishing transform from 'odom' to 'laser'
As we can see in the logs, we have the static_transform_publisher publishing a static transform from the odom to the laser frame.
We can now go to a second terminal and check the transforms between the frames with:
ros2 run tf2_ros tf2_echo odom laser
Assuming everything went as expected, the output you should get should be similar to the following:
[INFO] [1636413489.330173729] [tf2_echo]: Waiting for transform odom -> laser: Invalid frame ID "odom" passed to canTransform argument target_frame - frame does not exist At time 0.0 - Translation: [0.000, 0.000, 0.000] - Rotation: in Quaternion [0.000, 0.000, 0.000, 1.000] At time 0.0 - Translation: [0.000, 0.000, 0.000] - Rotation: in Quaternion [0.000, 0.000, 0.000, 1.000] At time 0.0 - Translation: [0.000, 0.000, 0.000] - Rotation: in Quaternion [0.000, 0.000, 0.000, 1.000]
Congratulations. You now know how to publish a static transform between two frames in ROS2 using Python. In addition to that, you have also learned how to create a python package as well as a launch file along the way. Feel free to terminate the scripts you have executed by pressing CTRL+C in the terminals. You can also for sure spend more time using this great online platform, The Construct.
