- How to launch ros1_bridge
- How to use available topics that don’t show up
- How to connect to The Construct’s Real Robot Lab RoBoX
- RoBoX Real Robot Lab: https://app.theconstructsim.com/#/RealRobot
- Repositories:
- This post answers the following question asked on ROS Answers: https://answers.ros.org/question/359969/ros2-foxy-ros1_bridge-topics-missing/
Creating a rosject
In order to learn how to use hidden topics with ros1_bridge, let’s start by creating a rosject (ROS project). We are going to use The Construct (https://www.theconstruct.ai/) for this tutorial, but if you have ROS2 installed on your own computer, you should be able to do ~everything on your own computer, except this creating a rosject part.
Once inside, let’s create My Rosjects and then, Create a new rosject:
For the rosject, let’s select ROS2 Foxy for the ROS Distro, let’s name the rosject as Turtlebot3 hidden topics. You can leave the rosject public.
Cloning the required repositories with the simulations
After we have created our rosject and opened it, let’s now open a web shell as we can see in the image below:
After that, let’s enter into the ~/simulation_ws/src directory and clone three repositories there with the following commands:
cd ~/simulation_ws/src/ git clone https://github.com/ROBOTIS-GIT/turtlebot3 git clone https://github.com/ROBOTIS-GIT/turtlebot3_msgs git clone https://github.com/ROBOTIS-GIT/turtlebot3_simulations
Starting the simulation
Once we have correctly cloned the repositories that contain the simulation and ROS messages needed to simulate Turtlebot with ROS, we now need to start the simulation.
The rosject that we created comes by default with ROS2 Noetic and ROS2 Foxy installed.
In order to test the simulation in ROS2, let’s first launch it with ROS1 to make sure the simulation is working properly at least in ROS1. We will then use ROS1 Bridge to be able to see the topics in ROS2.
Let’s start by sourcing ros1 noetic with, and sourcing our simulation_ws/devel folder as follows:
cd ~/simulation_ws source /opt/ros/noetic/setup.bash source devel/setup.bash
After having sourced the workspace that contains the simulation, we should now be able to launch it with the following commands:
export TURTLEBOT3_MODEL=burger roslaunch turtlebot3_gazebo turtlebot3_empty_world.launch
Now that the simulation has been launched, we can open gazebo in order to see it. For that, hover your mouse over the button that has the icon of gazebo and click Open Gazebo. After that, you should be able to see the turthebot3 simulation in ROS1, which means the simulation is well defined, and the meshes are correct.
Launching ROS1 Bridge
Let’s start by sourcing the ros workspaces in order. Let’s start by sourcing ROS1, then ROS2, and finally, run the bridge. For that, open a second web shell and type the following:
source /opt/ros/noetic/setup.bash source /opt/ros/foxy/setup.bash ros2 run ros1_bridge dynamic_bridge --bridge-all-topics
If everything went well, you should have seen some logs like the following:
created 1to2 bridge for topic '/clock' with ROS 1 type 'rosgraph_msgs/Clock' and ROS 2 type 'rosgraph_msgs/msg/Clock' created 1to2 bridge for topic '/gazebo/link_states' with ROS 1 type 'gazebo_msgs/LinkStates' and ROS 2 type 'gazebo_msgs/msg/LinkStates' created 1to2 bridge for topic '/gazebo/model_states' with ROS 1 type 'gazebo_msgs/ModelStates' and ROS 2 type 'gazebo_msgs/msg/ModelStates' created 1to2 bridge for topic '/imu' with ROS 1 type 'sensor_msgs/Imu' and ROS 2 type 'sensor_msgs/msg/Imu' created 1to2 bridge for topic '/joint_states' with ROS 1 type 'sensor_msgs/JointState' and ROS 2 type 'sensor_msgs/msg/JointState' created 1to2 bridge for topic '/odom' with ROS 1 type 'nav_msgs/Odometry' and ROS 2 type 'nav_msgs/msg/Odometry' created 1to2 bridge for topic '/rosout' with ROS 1 type 'rosgraph_msgs/Log' and ROS 2 type 'rcl_interfaces/msg/Log' created 1to2 bridge for topic '/rosout_agg' with ROS 1 type 'rosgraph_msgs/Log' and ROS 2 type 'rcl_interfaces/msg/Log' created 1to2 bridge for topic '/scan' with ROS 1 type 'sensor_msgs/LaserScan' and ROS 2 type 'sensor_msgs/msg/LaserScan' created 1to2 bridge for topic '/tf' with ROS 1 type 'tf2_msgs/TFMessage' and ROS 2 type 'tf2_msgs/msg/TFMessage' Created 2 to 1 bridge for service /gazebo/clear_body_wrenches Created 2 to 1 bridge for service /gazebo/clear_joint_forces Created 2 to 1 bridge for service /gazebo/delete_light Created 2 to 1 bridge for service /gazebo/delete_model Created 2 to 1 bridge for service /gazebo/get_joint_properties Created 2 to 1 bridge for service /gazebo/get_light_properties Created 2 to 1 bridge for service /gazebo/get_link_properties Created 2 to 1 bridge for service /gazebo/get_link_state Created 2 to 1 bridge for service /gazebo/get_model_properties Created 2 to 1 bridge for service /gazebo/get_model_state Created 2 to 1 bridge for service /gazebo/get_physics_properties Created 2 to 1 bridge for service /gazebo/get_world_properties Created 2 to 1 bridge for service /gazebo/pause_physics Created 2 to 1 bridge for service /gazebo/reset_simulation Created 2 to 1 bridge for service /gazebo/reset_world Created 2 to 1 bridge for service /gazebo/set_joint_properties Created 2 to 1 bridge for service /gazebo/set_link_properties Created 2 to 1 bridge for service /gazebo/set_link_state Created 2 to 1 bridge for service /gazebo/set_model_configuration Created 2 to 1 bridge for service /gazebo/set_model_state Created 2 to 1 bridge for service /gazebo/set_physics_properties Created 2 to 1 bridge for service /gazebo/spawn_sdf_model Created 2 to 1 bridge for service /gazebo/spawn_urdf_model Created 2 to 1 bridge for service /gazebo/unpause_physics Created 2 to 1 bridge for service /imu_service [INFO] [1641212256.136511189] [ros_bridge]: Passing message from ROS 1 rosgraph_msgs/Clock to ROS 2 rosgraph_msgs/msg/Clock (showing msg only once per type) [INFO] [1641212256.138899978] [ros_bridge]: Passing message from ROS 1 gazebo_msgs/LinkStates to ROS 2 gazebo_msgs/msg/LinkStates (showing msg only once per type) created 2to1 bridge for topic '/gazebo/link_states' with ROS 2 type 'gazebo_msgs/msg/LinkStates' and ROS 1 type 'gazebo_msgs/LinkStates' [INFO] [1641212256.140508214] [ros_bridge]: Passing message from ROS 1 gazebo_msgs/ModelStates to ROS 2 gazebo_msgs/msg/ModelStates (showing msg only once per type) created 2to1 bridge for topic '/rosout' with ROS 2 type 'rcl_interfaces/msg/Log' and ROS 1 type'rosgraph_msgs/Log' [INFO] [1641212256.141466301] [ros_bridge]: Passing message from ROS 1 sensor_msgs/Imu to ROS 2sensor_msgs/msg/Imu (showing msg only once per type) [INFO] [1641212256.142755982] [ros_bridge]: Passing message from ROS 1 sensor_msgs/JointState to ROS 2 sensor_msgs/msg/JointState (showing msg only once per type) removed 2to1 bridge for topic '/gazebo/link_states' [INFO] [1641212256.144608098] [ros_bridge]: Passing message from ROS 1 nav_msgs/Odometry to ROS2 nav_msgs/msg/Odometry (showing msg only once per type) [INFO] [1641212256.146602236] [ros_bridge]: Passing message from ROS 1 tf2_msgs/TFMessage to ROS 2 tf2_msgs/msg/TFMessage (showing msg only once per type) [INFO] [1641212256.160265245] [ros_bridge]: Passing message from ROS 2 rcl_interfaces/msg/Log to ROS 1 rosgraph_msgs/Log (showing msg only once per type) [INFO] [1641212256.466793392] [ros_bridge]: Passing message from ROS 1 sensor_msgs/LaserScan toROS 2 sensor_msgs/msg/LaserScan (showing msg only once per type) [INFO] [1641212256.469177152] [ros_bridge]: Passing message from ROS 1 rosgraph_msgs/Log to ROS2 rcl_interfaces/msg/Log (showing msg only once per type)
Checking the /cmd_vel topic
Now that ros1_bridge is up and running, let’s open a third terminal and list the ros2 topics with:
ros2 topic list
You should have seen at least the following topics:
/clock /gazebo/link_states /gazebo/model_states /imu /joint_states /odom /parameter_events /rosout /rosout_agg /scan /tf
If we look carefully at the list of topics above, we cannot see any /cmd_vel topic. But the topic exists in ROS1. To ensure the topic exists in ROS1, let’s open a fourth terminal and list the topics with:
source /opt/ros/noetic/setup.bash rostopic list
The list should contain something like the output below, showing that indeed we have a topic called /cmd_vel (the second one in the list below).
/clock /cmd_vel /gazebo/link_states /gazebo/model_states /gazebo/parameter_descriptions /gazebo/parameter_updates /gazebo/performance_metrics /gazebo/set_link_state /gazebo/set_model_state /imu /joint_states /odom /rosout /rosout_agg /scan /tf
And this is what confuses some users. How is that /cmd_vel is available in ros1 but it is not available on ros2? Well, we still do not have a definite answer on why this happens, but we know that if in ROS2 we start publishing in that topic, it will be received by ROS1 and the robot will move accordingly, even though we are not able to see the topic with ros2 topic list. Let’s try that.
First, if we were to publish messages in the /cmd_vel topic using ROS1, the command would be as follows (you do not need to run the command below):
rostopic pub /cmd_vel geometry_msgs/Twist "linear: x: 0.0 y: 0.0 z: 0.0 angular: x: 0.0 y: 0.0 z: 0.0"
For ros2, the message instead of geometry_msgs/Twist would be geometry_msgs/msg/Twist. Since ros2 does not auto-complete because it does not know the /cmd_vel topic, we can copy the auto-completed values for geometry_msgs/Twist in ROS1 and pass it to ros2.
Let’s go back to the third terminal where ROS2 Foxy is sourced by default and run the following command:
ros2 topic pub /cmd_vel geometry_msgs/msg/Twist "linear: x: 0.0 y: 0.0 z: 0.0 angular: x: 0.0 y: 0.0 z: 0.3"
You should have seen something like what we have below:
publisher: beginning loop publishing #1: geometry_msgs.msg.Twist(linear=geometry_msgs.msg.Vector3(x=0.0, y=0.0, z=0.0), angular=geometry_msgs.msg.Vector3(x=0.0, y=0.0, z=0.3)) publishing #2: geometry_msgs.msg.Twist(linear=geometry_msgs.msg.Vector3(x=0.0, y=0.0, z=0.0), angular=geometry_msgs.msg.Vector3(x=0.0, y=0.0, z=0.3)) publishing #3: geometry_msgs.msg.Twist(linear=geometry_msgs.msg.Vector3(x=0.0, y=0.0, z=0.0), angular=geometry_msgs.msg.Vector3(x=0.0, y=0.0, z=0.3)) publishing #4: geometry_msgs.msg.Twist(linear=geometry_msgs.msg.Vector3(x=0.0, y=0.0, z=0.0), angular=geometry_msgs.msg.Vector3(x=0.0, y=0.0, z=0.3)) publishing #5: geometry_msgs.msg.Twist(linear=geometry_msgs.msg.Vector3(x=0.0, y=0.0, z=0.0), angular=geometry_msgs.msg.Vector3(x=0.0, y=0.0, z=0.3))
And the robot should now be rotating.
As you can see, with ROS2 we are able to move the robot that is running with ROS1, even if we cannot list the topic with ros2.
By looking at the logs of the second web shell, where ros1_bridge was launched, we can also confirm that the message is being correctly interchanged from the ROS2 to the ROS1 /cmd_vel topic:
created 2to1 bridge for topic '/cmd_vel' with ROS 2 type 'geometry_msgs/msg/Twist' and ROS 1 type '' [INFO] [1641214498.129565691] [ros_bridge]: Passing message from ROS 2 geometry_msgs/msg/Twistto ROS 1 geometry_msgs/Twist (showing msg only once per type) removed 2to1 bridge for topic '/cmd_vel' created 2to1 bridge for topic '/cmd_vel' with ROS 2 type 'geometry_msgs/msg/Twist' and ROS 1 type ''
So, that is it. We just learned that even when some topics are not visible in ROS2 through ros1_bridge, we can still publish messages on them using ROS2.
