- How to only source one ROS distro at a time
- How to create new ROS2 workspaces
- Robot Ignite Academy –▸ https://www.robotigniteacademy.com
- ROS2 Tutorials –▸
- This video answers the following question asked on ROS Answers: https://answers.ros.org/question/389464/why-does-ros2-installsetupbash-source-ros1-and-ros2/
Creating a rosject
In order to learn how to create conditional publishers, let’s start by creating a publisher and a subscriber in Python. We are going to use The Construct (https://www.theconstruct.ai/) for this tutorial, but if you have ROS2 installed on your own computer, you should be able to do ~everything on your own computer, except this creating a rosject part.
Once inside, let’s create My Rosjects and then, Create a new rosject:
For the rosject, let’s select ROS2 Foxy for the ROS Distro, let’s name the rosject as ROS Q&A 224. You can leave the rosject public.
Checking enviroment configuration
Open a webshell and go to the installation folder of ROS, like shown below:
You can see there are installed two ROS distros, ROS 1 Noetic and ROS 2 Foxy
That means both systems are installed, like the user shown his workspace. Now, open the code editor and check the workspaces:
There are two main workspaces, catkin_ws (for ROS noetic) and ros2_ws (for ROS 2 foxy)
Configuring an environment with both setups
The quickest way to have a ROS environment with both ROS and ROS2 is by creating a new workspace. In the webshell, execute the following:
Open in the IDE the file ~/new_ros2_ws/install/setup.bash. This is a fresh new ROS2 workspace, it does not have ROS noetic attached to it. It is shown in the image below, no ROS commands (e.g: roscore) are available:
You can have as many ROS 2 workspaces as you want and the fresh new workspace built does not have the setup to attache ROS 1 to it, unless you configure to do so.
