In this episode of ROS2 Tutorials Series, you will learn how to create a simple ROS2 custom message for Topics.
We are going to use a ROS2 (Dashing) installation for this, but you don’t need to install ROS, as we will use the ROS Development Studio (ROSDS), an online platform that provides access to ROS2 and ROS2 computers and other powerful ROS tools within a browser!
Now let’s get to work without further ado!
Step 1: Create a Project (ROSject) on ROSDS
Head to http://rosds.online and create a project with a similar configuration as the one shown below. You can change the details as you like, but please ensure you select “Ubuntu 18.04 + ROS2 Dashing” under “Configuration”.
Once the ROSject is open, head to the Tools menu and pick the Shell tool (a terminal) and run the following command to source the workspace:
user:~$ source /opt/ros/dashing/setup.bash ROS_DISTRO was set to 'melodic' before. Please make sure that the environment does not mix paths from different distributions. user:~$
If you get that ROS_DISTRO warning, just ignore it.
Step 3: Create a ROS2 C++ package in your ROS2 workspace
We are creating a C++ package (ament_cmake) and adding dependencies rclcpp (ROS C++ client) and std_msgs (in-built standard messages type, on which our new message will be based).
user:~$ mkdir -p ros2_ws/src user:~$ cd ros2_ws/src user:~/ros2_ws/src$ user:~/ros2_ws/src$ ros2 pkg create ros2_msg --build-type ament_cmake --dependencies rclcpp std_msgs going to create a new package package name: ros2_msg destination directory: /home/user/ros2_ws/src package format: 3 version: 0.0.0 description: TODO: Package description maintainer: ['user <user@todo.todo>'] licenses: ['TODO: License declaration'] build type: ament_cmake dependencies: ['rclcpp', 'std_msgs'] creating folder ./ros2_msg creating ./ros2_msg/package.xml creating source and include folder creating folder ./ros2_msg/src creating folder ./ros2_msg/include/ros2_msg creating ./ros2_msg/CMakeLists.txt user:~/ros2_ws/src$
Step 3: Create the definition of the ROS2 custom message
user:~/ros2_ws/src$ cd ros2_msg user:~/ros2_ws/src/ros2_msg$ mkdir -p msg user:~/ros2_ws/src/ros2_msg$ cd msg/ user:~/ros2_ws/src/ros2_msg/msg$ touch MyMsg.msg
Pick the “IDE” tool from the Tools menu, locate the MyMsg.msg file, and paste in the following code:
int32 day string month int32 year
Next, open up the CMakeList.txt file in the IDE and add the required dependencies:
- Add these two dependencies under “#find package”, right after the three that are already there:
- Add the following function to
CMakeList.txt.This function tells the ROS system to generate a new message from the specified message definition, using the specified interface.
Next, open up the package.xml file in the IDE and make the following changes:
- Change the package format from “2” to “3”, if not already “3” (in this case it was already 3):
- Add the dependencies that complement the ones we have in
CMakeList.txt:
Step 4: Compile the package
Whew, a couple of ingredients had to be added there; now it is time to compile the message and taste the “soup”!
Get back to the terminal and run the following commands:
user:~$ cd ~/ros2_ws user:~/ros2_ws$ colcon build --symlink-install Starting >>> ros2_msg Finished <<< ros2_msg [14.1s] Summary: 1 package finished [14.3s] user:~/ros2_ws$ source install/setup.bash ROS_DISTRO was set to 'dashing' before. Please make sure that the environment does not mix paths from different distributions. ROS_DISTRO was set to 'melodic' before. Please make sure that the environment does not mix paths from different distributions. user:~/ros2_ws$
Step 5: Find and test the new custom message:
user:~/ros2_ws$ ros2 msg list | grep MyMsg
ros2_msg/msg/MyMsg
user:~/ros2_ws$ ros2 msg show ros2_msg/msg/MyMsg
int32 day
string month
int32 year
user:~/ros2_ws$ ros2 topic pub /test_topic ros2_msg/MyMsg "{day: '7', month: 'October', year: '2019'}"
publisher: beginning loop
publishing #1: ros2_msg.msg.MyMsg(day=7, month='October', year=2019)
publishing #2: ros2_msg.msg.MyMsg(day=7, month='October', year=2019)
publishing #3: ros2_msg.msg.MyMsg(day=7, month='October', year=2019)
Pick another Shell from the Tools menu and check the message being published (PS: you need to source ROS Dashing and the workspace first):
user:~$ source /opt/ros/dashing/setup.bash ROS_DISTRO was set to 'melodic' before. Please make sure that the environment does not mix paths from different distributions. user:~$ source ros2_ws/install/setup.bash ROS_DISTRO was set to 'dashing' before. Please make sure that the environment does not mix paths from different distributions. ROS_DISTRO was set to 'melodic' before. Please make sure that the environment does not mix paths from different distributions. user:~$ ros2 topic list /parameter_events /rosout /test_topic user:~$ ros2 topic echo /test_topic day: 7 month: October year: 2019 --- day: 7 month: October year: 2019 --- day: 7 month: October year: 2019 --- day: 7 month: October year: 2019 --- day: 7 month: October year: 2019 --- day: 7 month: October year: 2019 --- ^Cuser:~$
Great, it ran! We’re done here!!
Extra 1: ROSject link
Get the ROSject containing all code used in the post in the following link: http://www.rosject.io/l/c3f3784/
Extra 2: Video
Post edited by Bayode Aderinola
#ROS2 #ROS #ROS2tutorials #Robot
CMake Error at /usr/share/cmake-3.10/Modules/FindPackageHandleStandardArgs.cmake:137 (message):
Could NOT find FastRTPS (missing: FastRTPS_INCLUDE_DIR FastRTPS_LIBRARIES)
Call Stack (most recent call first):
/usr/share/cmake-3.10/Modules/FindPackageHandleStandardArgs.cmake:378 (_FPHSA_FAILURE_MESSAGE)
/opt/ros/dashing/share/fastrtps_cmake_module/cmake/Modules/FindFastRTPS.cmake:95 (find_package_handle_standard_args)
/opt/ros/dashing/share/rosidl_typesupport_fastrtps_c/cmake/rosidl_typesupport_fastrtps_c-extras.cmake:7 (find_package)
/opt/ros/dashing/share/rosidl_typesupport_fastrtps_c/cmake/rosidl_typesupport_fastrtps_cConfig.cmake:38 (include)
/opt/ros/dashing/share/rosidl_default_generators/cmake/rosidl_default_generators-extras.cmake:21 (find_package)
/opt/ros/dashing/share/rosidl_default_generators/cmake/rosidl_default_generatorsConfig.cmake:38 (include)
CMakeLists.txt:17 (find_package)
what if I need to include the msg file from another folder in the same package. how to equip the CMakeLists and package.xml?
I tried to include the .msg file from other folder but got:
CMake Error at /home/miao/ros2_install/ros2-linux/share/rosidl_cmake/cmake/rosidl_generate_interfaces.cmake:93 (message):
rosidl_generate_interfaces() the passed file ‘msg/JointCommand.msg’ doesn’t
exist relative to the CMAKE_CURRENT_SOURCE_DIR
‘/home/miao/ros2_pendulum_ws/src/ros2_pendulum_pkg/minimal_publisher’
CMakeLists.txt:23 (rosidl_generate_interfaces)
How should I handle this problem?
I have the same question as Miao :
‘/home/la/dev_ws/src/ros2_pendulum_pkg/minimal_publisher’
r
r
Could build successfuly, but getting
r Could build it successfully,, but this command is giving following error, ros2 topic pub /test_topic ros2_msg/msg/String “{day: ‘7’, month: ‘October’, year: ‘2019’}”
>>> [rcutils|error_handling.c:108] rcutils_set_error_state()
This error state is being overwritten:
‘Failed to find library ‘ros2_msg__rosidl_typesupport_fastrtps_c’
, at /tmp/binarydeb/ros-foxy-rosidl-typesupport-c-1.0.2/src/type_support_dispatch.hpp:73′
with this new error message:
‘Handle’s typesupport identifier (rosidl_typesupport_c) is not supported by this library
, at /tmp/binarydeb/ros-foxy-rosidl-typesupport-c-1.0.2/src/type_support_dispatch.hpp:116’
rcutils_reset_error() should be called after error handling to avoid this.
<<>> [rcutils|error_handling.c:108] rcutils_set_error_state()
‘type support not from this implementation, at /tmp/binarydeb/ros-foxy-rmw-fastrtps-cpp-1.3.0/src/publisher.cpp:86’
Failed to create publisher: type support not from this implementation, at /tmp/binarydeb/ros-foxy-rmw-fastrtps-cpp-1.3.0/src/publisher.cpp:86, at /tmp/binarydeb/ros-foxy-rcl-1.1.13/src/rcl/publisher.c:180
