About
In this post, you will learn how to create a simple ROS2 package for C++. You don’t need a ROS2 installation for this, as we will use the ROS Development Studio (ROSDS), an online platform that provides access to ROS (1 or 2) computers and other powerful ROS tools within a browser!
PS: If you have ROS2 installed locally on your machine, you can skip Step 1.
Step 1: Create a Project (ROSject) on ROSDS
Head to http://rosds.online and create a project with a similar configuration as the one shown below. You can change the details as you like, but please ensure you select “Ubuntu 18.04 + ROS2 Crystal” under “Configuration”.
Once the ROSject is open, head to the Tools menu and pick the Shell tool (if on your local PC just fire up a terminal) and run the following command to source the workspace:
user:~$ source /opt/ros/crystal/setup.bash ROS_DISTRO was set to 'melodic' before. Please make sure that the environment does not mix paths from different distributions. user:~$
If you get that ROS_DISTRO warning, just ignore it.
Step 3: Create a ROS2 package in your ROS2 workspace
The syntax for creating a ROS2 package is ros2 pkg create <package_name> --build-type <build_type> --dependencies <dependencies_separated_by_single_space>.
In the same terminal as in Step 2, change to your ROS2 workspace src directory and create a package there:
user:~$ cd ros2_ws/src user:~/ros2_ws/src$ ros2 pkg create ros2_cpp_pkg --build-type ament_cmake --dependencies rclcpp going to create a new package package name: ros2_cpp_pkg destination directory: /home/user/ros2_ws/src package format: 2 version: 0.0.0 description: TODO: Package description maintainer: ['user <user@todo.todo>'] licenses: ['TODO: License declaration'] build type: ament_cmake dependencies: ['rclcpp'] creating folder ./ros2_cpp_pkg creating ./ros2_cpp_pkg/package.xml creating source and include folder creating folder ./ros2_cpp_pkg/src creating folder ./ros2_cpp_pkg/include/ros2_cpp_pkg creating ./ros2_cpp_pkg/CMakeLists.txt user:~/ros2_ws/src$
Step 4: Create C++ code inside the package
Create a file named ros2_cpp_code.cpp inside the new package:
user:~/ros2_ws/src$ cd ros2_cpp_pkg/src user:~/ros2_ws/src/ros2_cpp_pkg/src$ touch ros2_cpp_code.cpp user:~/ros2_ws/src/ros2_cpp_pkg/src$
Pick the IDE from the Tools menu, locate the C++ file and paste in the following code:
#include "rclcpp/rclcpp.hpp"
rclcpp::init(argc, argv);
auto node = rclcpp::Node::make_shared("ObiWan");
RCLCPP_INFO(node->get_logger(),
"Help me Obi-Wan Kenobi, you're my only hope");
rclcpp::shutdown();
In the IDE, open up the CMakeLists.txt and paste the following line at the bottom of the file. We are doing this to ensure the C++ file will be properly detected and compiled.
add_executable(cpp_code src/ros2_cpp_code.cpp)
ament_target_dependencies(cpp_code rclcpp)
install(TARGETS
cpp_code
Step 5: Compile and test-run the package
Now your package is ready to compile…so compile it and source the workspace!
user:~/ros2_ws/src/ros2_cpp_pkg/src$ cd /home/user/ros2_ws user:~/ros2_ws$ colcon build --symlink-install Starting >>> ros2_cpp_pkg Finished <<< ros2_cpp_pkg [21.9s] Summary: 1 package finished [22.0s] user:~/ros2_ws$ source install/setup.bash # source the workspace ROS_DISTRO was set to 'crystal' before. Please make sure that the environment does not mix paths from different distributions. ROS_DISTRO was set to 'melodic' before. Please make sure that the environment does not mix paths from different distributions. user:~/ros2_ws$
Great. Now test-run it. You should have the string mentioned in the C++ code printed to the terminal output:
user:~/ros2_ws$ ros2 run ros2_cpp_pkg cpp_code [INFO] [ObiWan]: Help me Obi-Wan Kenobi, you're my only hope user:~/ros2_ws$
Done!
Extra 1: ROSject link
Get the ROSject containing all code used in the post in the following link: http://www.rosject.io/l/bce4ffd/!
Extra 2: Video
If you want to learn about other ROS topics, please let us know in the comments area and we will do a video or post about it 🙂
Amazing tutorial, thanks
C++ code is invalid. main function need to return value
C++ code `return ;` is invalid. main function need to return value, e.g. `return 0;`
